Author Topic: Do you change blades for ripping/crosscutting?  (Read 914 times)
Offline Bugsysiegals
« on: October 11, 2020, 09:28 PM »
I’ve whatever stock blade comes with the TS55 and use it to rip and crosscut sheet goods. Do you change your blades to the smaller # of teeth for ripping versus crosscutting?
Offline manuc
Re: Do you change blades for ripping/crosscutting?
« Reply #1 on: October 11, 2020, 09:42 PM »
I use the universal 28-Tooth Saw Blade to do both.
Offline rmhinden
« Reply #2 on: October 11, 2020, 10:00 PM »
For sheet goods, I just use the stock blade.  Ripping hardwood, I have a panther rip blade for my TS75.
Bob
Offline CeeJay
« Reply #3 on: October 11, 2020, 10:13 PM »
I mostly use the TS55 for sheet goods and leave the 48T blade on.
If I happen to be ripping hardwood (rare - usually use table saw for this) I change to a 20T blade.
Offline RussellS
« Reply #4 on: October 11, 2020, 11:08 PM »
For plywood, I don't think there is such a thing as ripping and crosscutting.  Because the plys are perpendicular, you are always doing both whenever you cut plywood.  So using the Universal blade makes perfect sense.  And 3/4" plywood isn't thick enough to cause any strength issues with the 55.  For cutting real, solid wood, I do switch between the ripping and Universal blade for ripping and crosscutting.  Universal is the crosscut blade.  Panther is the rip blade.
« Reply #5 on: October 11, 2020, 11:13 PM »
I’ve only used the TS55 on plywood and hardwood in the table saw ... I’m not sure I’d ever cut hardwood on the TS55 unless I was doing some side project on site someday but good to know these facts, thanks guys!!
Offline ear3
« Reply #6 on: October 11, 2020, 11:52 PM »
While there is no real difference between ripping and crosscutting for sheet goods when it comes to the load on the machine (because of the alternating grain of the plys), changing to the finer blade for crosscutting may reduce some of the tearout and splintering on certain veneers.  The best prophylactic for tearout on plywood regardless of blade is the green splinterguard, though.
For crosscutting hardwood, the finer blade can make a huge difference for the cut quality on that endgrain, and save a boatload of edge sanding.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 26 w/BT module • CT Sys w/Long-Life Bag • MFT/3 • STM 1800
Offline Birdhunter
« Reply #7 on: October 12, 2020, 05:05 AM »
I normally use my Festool track saw for cutting Baltic Birch plywood so leave the stock blade in all the time. If I’m cutting hardwood with the track saw, it’s usually only short cuts. If I was ripping lots of hard wood, I’d definitely switch to a rip blade. Lots less stress on the saw ripping with fewer teeth in the wood.
On my SawStop Industrial table saw, I leave the Forrestt all purpose blade in unless I’m doing a lot of ripping.
Birdhunter
Offline Bert Vanderveen
« Reply #8 on: October 12, 2020, 05:43 AM »
Don’t forget that often it is more important that the blade is sharp, than which type you use. IMO you need to always have a fresh blade as backup.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400 · Hammer HS950 | TaigaTools VacPods Pro Set
Wishlist: ETS EC 125 w 150 pad, DTS
Offline cpw
« Reply #9 on: October 12, 2020, 10:19 AM »
I found that the panther rip blade made a noticeable difference straight line ripping 8/4 white oak with my TS75.  With the stock blade, the saw would bog down.  With the panther it would not.  The stock blade did have 3 years of hobbiest use on it, so it isn't a totally fair comparison.
Offline RussellS
« Reply #10 on: October 12, 2020, 06:01 PM »
I work mainly with 3/4 and 4/4.  And sometimes 6/4 and 8/4.  Hardwood.  3/4 plywood.  Table saw does most of the work with hardwood and the smaller pieces of plywood.  But for ripping hardwood, you need to get one edge straight first.  Track saw, the 55, is used to straight line rip one edge.  I have the 3 meter track to rip long hardwoods.  And cut plywood lengthwise.  Then the table saw rips the hardwood to the correct width.  And if working with doors, you may need to rip a little off the bottom to make it fit after putting in new carpet.  Track saw, the 55, would get the job instead of trying to rip/cross a 30" wide door on the table saw.
Offline ear3
« Reply #11 on: October 14, 2020, 06:30 PM »
Here, here. And clean from pitch.  I can no longer count the times I thought I was due to take a blade for resharpening, only to find it still cut perfectly well after a good cleaning.
« Reply #12 on: October 14, 2020, 06:38 PM »
Excellent advice I'll remember to change to a rip blade if I'm ever ripping hardwood.
