Author Topic: Plugin issue on my CT26  (Read 10165 times)
Offline sigmatango
  • Challenge Accepted
« on: June 20, 2016, 02:31 PM »
So, the other day, i was having issues with my TS55 cutting out on a long cut. I noticed that my plugin on my CT 26 wasn't securely holding the plug into itself. Turns out that the spring loaded cover pushes down on the plugin and disconnects it. I used some tape to hold it in the proper position, but that seems to be a funny issue to have. I have had this happen when I was routing Corian seams with the OF 1400. That wasn't fun either... Any suggestions?
TS55REQ - OF1400 - RO150 - CXS - T18+3 - CT26E - BR10 - KAL - MFT3 - SYS2(x1) - SYS-StorageBox - SYS-Toolbox2 -Dewalt DWS709 - Ryobi  P854 - Milwaukee 5616-20 - Kreg PRS2100 - Fuji Semi-Pro 2
Offline ear3
Re: Plugin issue on my CT26
« Reply #1 on: June 20, 2016, 03:19 PM »
That was the case with my CT26 from the beginning.  Super annoying.
My dealer was cool and threw me another socket gratis.  But up until then, what I did was get a short heavy gauge three outlet extension cord and plugged it into the socket.  Extra benefit of having three plugs so I don't have to swap out when I'm switching back and forth between pug-it tools and corded tools:
http://www.homedepot.com/p/2-ft-12-3-Extension-Cord-AW62629/100661445
EDIT: @Peter Halle or @SRSemenza might want to move this to the main tool problem subforum.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • Planex Easy • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 36AC w/BT module • CT Sys w/Long-Life Bag • CT-VA 20 • MFT/3 • STM 1800
Offline Shane Holland
  • Festool Dealer
« Reply #2 on: June 20, 2016, 03:31 PM »
Contact Festool service if the outlet's not holding the plug tight.
Also, I've known some folks to remove the four screws holding the socket into the CT and flip it upside down. So it flips down rather than up.
The Tool Nut
ToolNut.com
877-866-5688
Offline DB10
« Reply #3 on: June 20, 2016, 05:17 PM »
 That's standard issue on all new CT's in Australia.. [big grin]
Offline sigmatango
« Reply #4 on: June 20, 2016, 06:47 PM »
Thanks for the prompt responses folks!
