Author Topic: Yet another parallel guide system, this time from KREG  (Read 5727 times)
« on: February 01, 2019, 01:28 AM »
ToolNut mail includes  info about several new products from Kreg.
This is their parallel guide offering.
Actually they have two.
This is the other.
Documentation is poor but it looks like TSO has nothing to worry about.
Offline Grev
Re: Yet another parallel guide system, this time from KREG
« Reply #1 on: February 01, 2019, 07:11 AM »
Apparently they came up with new products/accessories to compliment their new Track Saw/MFT Table setup.  You can see a photo of it on Toolnuts website .. Also saw it on Instagram last night ... price for the package is about $899.
Kreg Tracksaw
Offline box185
« Reply #2 on: February 01, 2019, 07:15 AM »
I like their approach . . .
Online DynaGlide
« Reply #3 on: February 01, 2019, 09:14 AM »
Kreg Tracksaw
It's the Kreg ACS1000 if you google it more pics come up. I didn't know Kreg was getting into the game I'm a bit surprised they did the whole deal with plunge saw and all. I can see this finding a home in a lot of hobbyists garages. Bet it's finicky to use.
I see they put what looks like a vertical hinge at both ends like the front hinge on the MFT/3. Makes sense for raising and lowering the guide rail onto material if you're using dogs for alignment.
« Last Edit: February 01, 2019, 09:24 AM by DynaGlide »
Instagram @matts.garage
Offline nvalinski
« Reply #4 on: February 01, 2019, 09:30 AM »
Interesting thing to note on the plunge saw... it appears to be the first blade left plunge saw I'm aware of. Rest of the system looks fairly intriguing as well. Almost like a manual inverted beam saw.
Offline JimH2
« Reply #5 on: February 01, 2019, 09:45 AM »
Not to redirect the conversation, but on Toolnut's page there is quite the zinger:
Note: Person shown in the photo is not included. You must provide your own person.
https://www.toolnut.com/kreg-acs-tbase-adaptive-cutting-system-track-saw-project-table-base.html
Offline Grev
« Reply #6 on: February 01, 2019, 09:53 AM »
Darn ... If it came with a helper in the shop it might be worth considering!  I'll pass ... They now have the full product listed with video.
Kreg ACS3000
Offline box185
« Reply #7 on: February 01, 2019, 10:13 AM »
It’s larger, includes wheels and handles, includes stabilizers, built in parallel guides with extensions, large size protractor, easily increase the table size. . .
There’s a lot to like in this tool ( table ). It does use an imperial measurement scale though . . .
Online DynaGlide
« Reply #8 on: February 01, 2019, 10:27 AM »
Now that the video is up we get a look at the hinge. That is a cool design. It looks like you set it to the material height then it sort of pivots up and back an inch and stays there when you need to take out or put a new board in.
I recently mounted my GRS-16PE to the rear hinge to try it out and one of my concerns is that the hinge flips up and back. This introduces to me a couple issues. Since the fence (GRS-16PE) is rotating back you have to lower it almost until the rail is touching the material to push the material against the fence. Throw in a parallel guide that you also have to register against and it's a little awkward. Now if you had a hinge design like the Kreg on the table I could see it pivoting up and back a hair to let the material register and slide freely before bringing the rail down.
« Last Edit: February 01, 2019, 10:30 AM by DynaGlide »
Offline RKA
« Reply #9 on: February 01, 2019, 10:38 AM »
I like it!  They clearly studied the existing solution(s) and thought about what's wrong with them and improved upon many of the niggles.  Without using it, I think it's a pretty good effort.  The price is a little steep for the average DIYer, but the capabilities could convince a number of them that a table saw isn't needed and this folds away quite neatly when not in use.
-Raj
Offline JimH2
« Reply #10 on: February 01, 2019, 11:04 AM »
It's good in terms of bringing the price of a tracksaw down to a reasonable number for casual users. For almost everyone in that category this is infinitely safer than a cheap tablesaw or a non-track circular saw.
Offline Svar
« Reply #11 on: February 01, 2019, 11:26 AM »
This is great! Several significant improvements over previous offerings. They surely did their homework. I only hope the construction quality is as great as the concept.
Offline blaszcsj
« Reply #12 on: February 01, 2019, 01:33 PM »
Did anyone notice how much dust the saw was kicking out, and the multiple "cuts" with a non moving blade? Otherwise, the table system looks like a solid concept. The hinge up track is novel
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro
Offline Svar
« Reply #13 on: February 01, 2019, 01:38 PM »
... and the multiple "cuts" with a non moving blade?
It's a new Stationary BladeTM cutting technology from Kreg.
Offline Svar
« Reply #14 on: February 01, 2019, 01:45 PM »
EZSmart from EurekaZone have been using double hinge for 10-15 years, but their hinges allow the track to drop all the way down (i.e. there no rigid support at the ends).
Offline GoingMyWay
« Reply #15 on: February 01, 2019, 01:49 PM »
I did notice all of the dust that wasn't being captured.  I wonder if the dust extraction would be better with a vacuum attached.  All of the clips with actual cutting only use the dust bag.
I'm a little concerned with how most of the Kreg products are made out of plastic.  Doesn't seem like it's that rigid or durable.  Their In-Line Clamp looks like a toy to me.
Inquiring Minds Want to Know
Offline ColossusX
« Reply #16 on: February 01, 2019, 02:37 PM »
The only issue with the mft style table is they expect you to cut in the same spot.  According to the Kreg rep on FB.  Seems like it wastes most of the table top.  I do like they sell the table frame/legs separately.
Offline Richard/RMW
« Reply #17 on: February 01, 2019, 02:47 PM »
Leave it to Kreg... 8 billion 20mm dogs/accessories out there and they go with 3/4".  [dead horse]
RMW
Offline GoingMyWay
« Reply #18 on: February 01, 2019, 03:06 PM »
Kreg posted a YouTube video of how to setup the table including the hinged brackets:
Offline JimH2
« Reply #19 on: February 01, 2019, 03:19 PM »
RMW
Like you I cannot understand why they did not go with 20mm holes. They probably would have picked up sales from the rest of the world that uses 20mm tables.
It looks good for the cost, but I am super iffy on the tapes maintaining their positions and I would have liked to see a little bit more metal, but it is what it is and I am sure lots of great projects will be made with it. If keeps occasional users from buying cheap table saws then the product will be a success.
Online DynaGlide
« Reply #20 on: February 01, 2019, 03:24 PM »
It's actually pretty well thought out. Sure some people demand higher precision than what this provides but that's not their target market. This is leaps and bounds better than all the folks using either the Kreg rip guide or other solutions for guided circular saw cuts.
The biggest head scratcher to me is the left side blade saw. Why would they not want to sell the table to all the existing track saw owners.
Offline box185
« Reply #21 on: February 01, 2019, 03:30 PM »
RMW
I’m sure someone has already thought about making a 20/96mm hole MFT/3 top for this.
Offline Svar
« Reply #22 on: February 01, 2019, 03:31 PM »
I don't see a problem. It's the same track and will work with other track saws just fine, just cut in the opposite direction.
« Last Edit: February 01, 2019, 04:38 PM by Svar »
Offline pixelated
« Reply #23 on: February 01, 2019, 04:32 PM »
re: the 19mm (3/4"  [wink]) holes, their existing project center uses 3/4" dog holes, so compatibility there was probably a concern for them.
But the table had me thinking of what the practicality would be of reaming the holes to 20mm. A quick google search shows prices of 50-80 USD for the tool, so not much benefit vs just buying an MFT. I don't currently own an MFT, but I do have a DeWalt work table which uses 20mm dog holes, so I am partially invested in the 20mm standard already.
Offline ben_r_
« Reply #24 on: February 01, 2019, 05:23 PM »
Just got the email from ToolNut on this. Thats quite a lot of product they just released. Looks like their gunnin for more than just a parallel guide system. They're after the whole track saw and MFT solution.
Offline Richard/RMW
« Reply #25 on: February 01, 2019, 08:03 PM »
Yeah, I know. Veritas got themselves caught straddling the .75"/20mm divide and their dog/jig offerings have always been something of a jumble. Just sayin' sometimes you gotta to admit you goofed and make the painful correction.
For the record I still think in Imperial but have forced myself to work in Metric, give me headaches sometimes.  [doh]
RMW
Offline SilviaS7
« Reply #26 on: February 02, 2019, 08:01 AM »
I am super stoked for this from Kreg, and I'll be buying the track saw for sure.  I am a fangirl and I love everything I have from them, and their customer service is amazing.
Offline mrB
« Reply #27 on: February 05, 2019, 06:17 AM »
NICE!  Great to have Kreg making compatible accessories for the track saw game!  I'd love some of those 'tape measure' type parallel guides!!! Their compact nature really sells it to me! Can't find them in the UK?EU though :(
Offline Kafarn
  • Building Beyond the Birdhouses
« Reply #28 on: April 04, 2019, 01:42 AM »
After getting emails about this prior to its release, I really wanted one - then our local Woodcraft had a full display - legs were very sturdy and felt more solid than the MFT - also with the Kreg sawhorse and connectors this would hold and break down a full 4x8 sheet easier than the MFT - wheels to move it around, the double hinge track saw guide system, . . . I was sold, the only problem was I didn’t like the saw (why Kreg went with a propiotory saw blade instead of a standard track saw blade size 160 or 165mm, was irritating) - also why not allow those with existing track saws to use the table.
So I got the table, then modified it to accept a Festool TS 55 R, using a FS 1900 75” Track (cut down to the 62” length, yep that hurt) - swapped the hinges so they fold to the right, re-drilled the track mount on the hinge 7/8” in from the Kreg hole and Wall-a! It works!!! Great table and with the Festool TS great cuts and dust control.
Notes: with the hinges going the other way, when you stand the table up the track will want to flop down, so I use a small bungee on the top end to hold it up for transport, as previously noted the 3/4” holes are a pain instead of the 20mm - but I already had some 3/4 dogs as well, just can’t use my MFT clamps (considering reaming the holes or CNC’ing a new water resistant MDF top with 20mm holes)
The man who is swimming against the stream knows the strength of it. - Woodrow Wilson
You can be wise and happy, or stupid and miserable, the choice is yours. - Gordon B. Hinckley
ETS 125 REQ (DE) [N], ETS EC 150/5 EQ Plus (DE) [N],DF 700 EQ-Set w/Seneca Small Mortise Kit (DE) [N], DS 4/5/6/8/10 1060 BU, TS 55 REQ-F-Plus USA (DE) [N] w/ FS 1400/2-LR 32 (x2) & Betterley SLC23 StraightLine Connector & Kreg Adaptive Cutting System adapted using FS 1900 track, FS-SYS/2, SYS-MFT, CT26 E, D 27/D 36 K-RS Plus, CT Wings,
Want (next) list: Kapex Miter Saw, Domino DF 500, Carvex Jigsaw (barrel grip) & acc, OF 1100 EQ Router, OF 2200 Router, HL 850 E Planer, Rotex 90, LS 130 Linear Sander
Offline ben_r_
« Reply #29 on: April 06, 2019, 11:40 AM »
Post some pics or better yet make a new thread on your mods. I would love to see how that turned out! Never been a fan of the MFT.
