Author Topic: Woodpecker Paolini Pocket Rules Stainless or Aluminum  (Read 2831 times)
Offline JimH2
« on: January 28, 2018, 11:51 PM »
Any advantage to one over the other?
Offline live4ever
Re: Woodpecker Paolini Pocket Rules Stainless or Aluminum
« Reply #1 on: January 29, 2018, 12:19 AM »
I prefer the stainless because it’s thinner, so marking feels more accurate.  It’s a matter of personal preference though.
Offline Sparktrician
« Reply #2 on: January 29, 2018, 09:21 AM »
I have both (different generations).  The older, aluminum one is more likely to deform if I drop it on the concrete.  The new ones are both stainless, with no regrets.
- Willy -
« Reply #3 on: January 29, 2018, 10:01 AM »
I sold the original aluminum version because it was too thick and I never used it.  [sad]
I've since purchased 2 stainless versions. I like the stainless version, I use them a lot.  [big grin]
Offline rst
« Reply #4 on: January 29, 2018, 01:28 PM »
I have the s/s and use them constantly.
Offline Gerald_D
« Reply #5 on: January 29, 2018, 01:46 PM »
I will second this- I have two that are aluminum models and one drop on the concrete will deform the edge and not allow the stop to slide off the ruler until fixed.  Looking at getting the stainless models since it sounds like they are more durable.
Regards,
Gerald
Gerald
I have Festools- Big and Small and a few other tools
Offline McNally Family
  • Festool Atomic Phaser Particle Blaster (APPB Set)
« Reply #6 on: January 29, 2018, 03:31 PM »
@live4ever
@Sparktrician
@Cheese
@rst
@Gerald_D
Seems the consensus is for the stainless.....but what size is considered the most practical?  Or, is the complete stainless set ideal?
« Last Edit: January 29, 2018, 03:34 PM by McNally Family »
GREEN: In order of purchase = | CT26  |  RS 2 E | Hose w/ Sleeve 3.5m | 115mm X 226mm Hand Sanding Block | 80mm X 133mm Hand Sanding Block | HSK D21.5 5m hose | CT Boom Arm Bundle Set | 1080 Plate for custom MFT | OF 1400 EQ Router (metric) w/accessories | SYS-Rock BR10 | Cordless Sander RTSC 400 Set |  Cordless Delta Sander DTSC 400 Basic | Linear Sander LS 130 | PDC 18/4 set | CXS  2.6Ah Set | Installer Cleaning Set (2018 version) |  New style Festool hose D 27/32 x 3,5m AS/CT | Replacement Hose Garage | Remote control CT-F I/M-Set | MFH1000 work stool | Next purchase: TBD
RED: // Mafell P1cc  //  MT55cc  // Next purchase: TBD
« Reply #7 on: January 29, 2018, 03:49 PM »
Here’s my vote...in one photo.  [big grin]
Actually check out the marked divisions between the two rulers. One was mfd in 2014, one was mfd in 2016. Those markings are identical, not a point to be overlooked. In the past this was one of the hallmarks of Starrett measurement scales/rulers.
Offline live4ever
« Reply #8 on: January 29, 2018, 04:09 PM »
@live4ever
@Sparktrician
@Cheese
@rst
@Gerald_D
I had gotten the 6" imperial and the 12" combo.  The 6" fits in a pocket and is used very frequently.
I also wanted a metric scale (I have very few metric measurement tools) so I got a combo in 12".  It is not used often unless I need a quality metric scale.  If I'm measuring in inches in that range, I tend to prefer a standard combo square.  I have a 16" Swanson that I prefer, having now verified (after accumulating much more expensive tools) it's dead nuts accurate and square.
The 8" size made less sense to me - too small and too big at the same time as opposed to "just right."
« Last Edit: January 29, 2018, 04:11 PM by live4ever »
« Reply #9 on: January 29, 2018, 04:45 PM »
@live4ever
@Sparktrician
@Cheese
@rst
@Gerald_D
I prefer the stainless version in 8" size.  It's just long enough for most of the stuff I use it for, yet at the same time, it's a touch too long for pocket carry.  The seat in my car will show you why it's a touch too long, dangit!  That said, I'd still choose the 8" size every time.
- Willy -
Offline ProCarpenterRVA
« Reply #10 on: January 30, 2018, 07:06 AM »
I had to go with the 6 stainless, shirt pocket size...
Sent from my Pixel XL using Tapatalk
Offline ben_r_
« Reply #11 on: January 30, 2018, 04:02 PM »
I have the aluminum blade one and would have rather gone with the stainless. Wasnt an option when I bought mine.
Offline egmiii
« Reply #12 on: January 30, 2018, 06:26 PM »
I couldn't decide on what to buy, so just overbought. I'll eventually sell what isn't used.
6" Stainless Imperial
6" Stainless Metric
8" Stainless Combo
12" Stainless Imperial
12" Stainless Metric
« Reply #13 on: January 30, 2018, 06:43 PM »
6" Stainless Metric
8" Stainless Combo
"My name is egmiii, and I'm a stainless-holic."   [poke]  [poke]
- Willy -
Offline egmiii
« Reply #14 on: January 30, 2018, 06:45 PM »
It's funny because it's true! [big grin]
« Reply #15 on: January 30, 2018, 07:17 PM »
 [thumbs up] [thumbs up]
