Author Topic: Where to Buy Bosch 35mm Hose End?  (Read 1226 times)
Offline Bugsysiegals
« on: November 30, 2020, 05:53 PM »
I cut my 35mm Bosch hose in half and would like to find another hose end like the one which connects it to the vacuum.  For those of you who have the Bosch hose and cut it in half, were you able to find another vacuum hose end?  I can't find anything which would insert inside and have the little rib to hold it on ... I'm wondering if there's a pool hose vacuum end which threads over the outside of the hose which might work?
323676-0
Offline rst
Re: Where to Buy Bosch 35mm Hose End?
« Reply #1 on: November 30, 2020, 07:03 PM »
I replaced my antistatic Bosch hose ends with Festool's, they fit just fine.
« Reply #2 on: November 30, 2020, 07:58 PM »
I was sort of hoping the Festool hose end wouldn't fit since it's probably close to the cost of another hose but thanks for confirming, good to know as a last resort there's an option! :)
Online afish
« Reply #3 on: November 30, 2020, 09:08 PM »
Not sure about the Bosch but it seems similar to the Cen-tec check these and see what you think.  The centec is great hose for the money
Offline xedos
« Reply #4 on: December 01, 2020, 10:35 AM »
(Attachment Link)
have you tried Bosch directly ?   Pretty sure both ends are available from spare parts.
https://www.boschtoolsservice.com/Order/IPL/IPLDetails.aspx?tn=0601988160&mn=3931A-PB&RelatedTools=&init=1
Think you'll find the more economical route is the trash what you've got and buy the cen-tec fish recommends.
« Reply #5 on: December 01, 2020, 10:47 AM »
It's to bad I can't find a cheaper end adapter for the hose I have but this is a good price, thanks for sharing!
Online afish
« Reply #6 on: December 01, 2020, 10:55 AM »
With the centec you can buy just the ends or hose kit.  Its a good quality hose I dont know for sure but I think they might have made the hoses for Fein since the hose that came on my 20 year old Fein vac is identical and still in good shape.  But I keep one dedicated to a cut station that I have plumbed with 2" pvc to a shop vac in an accessory building. and one loose for whatever. If you need better measurements of the hose to see if it matches with the bosch let me know. I will also say the ends in that pack have fit everything I have its super handy to be able to pop off the end and switch since I use multiple tools from many different manufactures.
Online afish
« Reply #7 on: December 01, 2020, 11:17 AM »
I went ahead and took the measurements just in case.  I will also add the hose is threaded in reverse so if you are looking at the open end of the hose you turn the fitting to the right to unscrew it. Its a little tricky to measure since the hose is somewhat spongy but its close.
« Reply #8 on: December 01, 2020, 02:49 PM »
Thanks for sharing!  The OD is 45mm, ID is 38mm, and the port fitting into the vacuum is about 58mm on the Bosch hose.  Maybe you have the smaller Centec hose ... I'll have to see if I can find a larger one...
Offline Peter_C
« Reply #9 on: December 01, 2020, 03:35 PM »
You didn't mention which Bosch hose you have?? If it is one of these hoses below, the ends listed below them from Festool will fit the hoses. But it just be cheaper to buy an entire hose as you suggest since you will need two fittings anyhow. Did you want a 27mm tool end fitting or a 36mm tool end fitting?
Bosch hoses. (Blue anti-static hose needs a new fitting on the vacuum side to use with most shop vacs or Festool.)
https://www.amazon.com/gp/product/B0000AV79B/
https://www.amazon.com/gp/product/B0000AV78B/
Hose fitting to vacuum.
https://www.amazon.com/Festool-202860-Coupling-Sleeve-DAG-As/dp/B079S29X67/
36mm tool end fitting.
https://www.amazon.com/Festool-500670-Coupling-Sleeve-DM-As/dp/B079S5F2RL/
« Reply #10 on: December 01, 2020, 05:06 PM »
I didn't know there was more than one Bosch 35mm hose ... it's the VAC005.  About the end adapter, I need one which can attach it to the vacuum and the other to fit my SawStop overhead dust collection and Incra router table fence.  The SawStop dust collection is 33mm ID and 39mm OD while the Incra router table fence is 57mm ID.  FWIW - My Shop Vac fits this so I could always just use it instead of the CT 36.
