Author Topic: What - non Festool - tool / workshop related gizmo/stuff did you buy today?  (Read 292164 times)
Offline WillAdams
This might be the inspiration for that Metmo driver.  The original brought back to life.
Yes, I believe so.
I wrote up a lengthy set of initial thoughts (can't call it a review since I've yet to actually use it) on the Metmo Cube Club Forums, which reminds me that I didn't post about my Christmas present to myself, a pair of Malco Eagle Grip vice grips (had to get a large to replace a pair of vintage Irwin's that my father had "borrowed" from his brother's welding shop --- apparently they were ultimately returned, along w/ the bowie knife forged from a truck leaf spring borrowed from another brother for my father's tours in Vietnam).
Unfortunately, the Eagle Grips have been discontinued, so if anyone has any interest, I'd recommend buying sooner rather than later.
Online Cheese
Re: What non Festool tool did you buy today? Malco Eagle Grip
« Reply #1291 on: March 07, 2023, 10:31 AM »
...which reminds me that I didn't post about my Christmas present to myself, a pair of Malco Eagle Grip vice grips (had to get a large to replace a pair of vintage Irwin's that my father had "borrowed" from his brother's welding shop.....
Just curious what the difference is between the Malco and a standard pair of Vise-Grips? They seem almost identical except for an extra pin/rivet/stud in the top jaw.
Offline Joelm
I went out and picked up the Mirka Deco Sander today. When I got it home I plugged it into my CT SYS and was able to sand dust free my kids bedroom in about 10-15 minutes.
I bought this as I need to sand and paint all the bedrooms in the house and our basement after I finish building some bulkheads.
Not as cheap as a pole sander from a big box store but it really was dust free so I'm happy.
« Reply #1293 on: March 07, 2023, 03:23 PM »
That, and they’re made in America.
Offline rst
Ordered two Pica 9mm pencil from Toolnut, managed to lost my original at work, actually think I left it lay, and someone evaporated it.  Evaporation tends to be a thing where I work part time.  Company tools sometimes disappear and them suddenly reappear later. I generally am very careful with my tools and have lost very few in the 53 years of working in shops and sites.
Offline Coen
The new 0.9mm?
I have worked at a final testing department, and the assembly guys left tools inside the installations they build too often. At some point we got fed up and we didn't return their tools but we collected them in a crate for the whole week, then gave it to the assembly team leader  [tongue]
Offline Packard
I bought a new (at that time) 1970 Chevrolet Caprice station wagon.  It had a bad rattle in the driver’s door.
I brought it to the dealer for repair and was told that “rattles are not covered by the warranty.”  I told them to go ahead and make the repair anyway.
They removed the door card while I was watching.  The rattle was a beer can installed  during manufacture.
Apparently, a supervisor wallked the production line and the worker had no other place to hide the beer.
The dealer “generously” volunteered, “There will be no charge for this repair.”
(He probably realized that he had zero chance of getting paid for that repair.)
So, things go missing.
Nurse:  We are missing one sponge
Surgeon:  Oops!
Online Cheese
About 12 years ago I ordered the smallest Aloris quick change tool post they made for a small Atlas 618 metal lathe. Unfortunately, when it arrived it was huge and was just not practical to use.
So time marches on and I recently stumbled upon a version that is only 2/3 the size of the Aloris. It's perfect for rapid tooling changes on a small lathe.
The tool post itself is in the rear center of this photo while left to right the tool holders are for: cut-off blade, 3/8" lathe tool, 1/2" lathe tool, a 3/8" boring bar and a holder for a 1/2" boring bar that has not been installed yet.
For those that are unfamiliar with lathe tooling, I'll give a very brief history of how we've landed where we have. The lathe dates back to 1300 BC but I'm interested in "modern" metal lathes driven with an electric motor so that starts right around 1900.
Left to right:
1. Original lantern tool post used with a single lathe tool, when tools are changed out, everything needs to be readjusted
2. A square tool post that can accept multiple lathe tools, to change tools, release the handle and spin the tool into position.
3. The modern quick change tool post, release the handle and mount what ever tool you want to use. Everything is pre adjusted.
One thing all tool posts must have is the ability to adjust the height of the lathe tool relative to the centerline of the material being turned.
For the lantern tool post, the thickness of the black bar that sits between the silver tool bit on the top and the "rocker" on the bottom needs to change. Either the bar thickness needs to change or there needs to be the addition/subtraction of shims.
For the square multi-tool tool post, the lathe tool is raised/lowered through the use of metal shims.
For the modern quick change tool post, it's a simple twist of a thumbwheel which allows for fine tweaking of the lathe tool height.
I also want to give a quick visual on how lathe tooling has changed over the years.
From right to left;
1. A Cleveland HSS tool circa 1900 to 1950, ALL geometries are hand ground on a blue or white wheel.
2. A Carboloy cemented carbide tool with a brazed tungsten tip circa 1950 to 1980, minor geometries can be hand ground on a green wheel.
3. An early, cheap carbide insert tool with a replaceable carbide insert circa 1980 to current, ready to use as is.
4. A modern Seco Carboloy tool with a replaceable carbide insert circa 2000 to current, ready to use as is.
All of these tools perform the same function and yet you can see the tip geometries become smaller and more precise as time goes by. That Carboloy cemented carbide tool was really cutting edge in its day and it took a while before they became affordable to the small machine shop/home machinist. The Carboloy material, just for the brazed tip (cemented tungsten carbide) was priced at $450 per pound in the 1950's. Compare that to the small silver carbide insert in the Seco holder at the top of the photo...that insert was $6.
« Last Edit: March 09, 2023, 02:36 PM by Cheese »
Offline squall_line
@Cheese,  I recognize the profile on the back end of the "oldest" tool in the lineup as the same profile we put on our tool when I took a metalworking class at the local community college.  I still have the mild steel practice tool as well as the hardened one that I profiled.
Unfortunately, travel and other work obligations reared up and prevented me from finishing that class, but I kept those tools for whatever reason.  Fortunately, I didn't pay for it (I worked at the college at the time and we got credit towards a portion of a class  every semester for free).
“The Carboloy material, just for the brazed tip (cemented tungsten carbide) was priced at $450 per pound in the 1950's. Compare that to the small silver carbide insert in the Seco holder at the top of the photo...that insert was $6.”
How many of those little $6 bits to the pound?
Thanks for the tooling lesson!
Online Cheese
Probably a couple of hundred...but compare 1# of anything in 1950's dollars to the same pound of anything in 2020 dollars and you'll probably go blind...or wish you would have purchased the futures.  [smile]
I've always been surprised at how slowly the non-industrial groups move forward and it seems like forever for them to fully embrace new ideas...I've never understood the recalcitrance on their part. If it's better and a bit more expensive then embrace it...if it's better and somewhat more expensive then embrace it...if it's better and really more expensive, then understand the technology, reduce the cost and then embrace it.
I've never considered myself to be a history buff but if we don't learn from the past...we're doomed to repeat our failures of the past, and that's depressing.
The Carboloy material was actually invented in Germany and arm wrestled to a standoff in the US by GE during the 30's. It's an interesting story and has a lot of intrigue including a federal court case. Hey...that's what we're good at.  [smile]
Offline luvmytoolz
Nice collection of QCTP's there Cheese!
My first lathe came with the old style square post but I had them change it to a QCTP, makes life so much easier!
I will add that metal working on the lathe is a real joy, I love it!
Online Cheese
Thanks... [smile] ...when I replaced the lantern style tool post with the square style tool post, I thought I died and went to heaven. What an insane difference it made for tool changes and it really reduced the fabrication time and made me want to spend time at the lathe. I fully expect that the addition of the new QCTP will further enhance the lathe turning experience by a factor of 2X-3X.
I wanted to purchase a few additional Alvin Draft/Matic mechanical pencils. When I went to the local art supply store, they informed me that Alvin, after being family owned for 70 years, had sold out to a "management" firm in 2020 located in Utah. [sad]  Worse yet, they've had Alvin pencils on back order since that time and have yet to receive any.  [eek]
They suggested I look at the Koh-I-Noor offering. The Alvin Draft/Matics were made in Germany while the Rapidomatics are made in Japan. Here's a comparison, tough to tell the difference.
I also picked up a Rotring 2 mm lead holder that I use for making very precise lines. Here's a comparison of a Rotring .5 mm pencil and the Rotring 2 mm pencil. The new Rotring 2 mm pencil is also made in Japan as opposed to Germany.
Here's a comparison of lead point sizes after the 2 mm pencil has been sharpened. That 2 mm point is down to .15 mm compared to the .5 mm lead.
Another nice touch is that in an emergency, the end cap of the Rotring comes off and it contains an internal lead pointer. It's emergency only because it is messy. For normal 2 mm lead sharpening, I prefer this Faber Castell sharpener for its enclosed lead containment. It sharpens both 2 mm & 3 mm leads.
Offline Muttley000
Those are some sweet looking marking devices Cheese, I may give some of those a shot!
ETS EC 150
TS55 FEQ
CT 36
Offline Packard
I just got Garrett Wade’s self-centering dowel jig.
I already have a self-centering dowel jig, but it has one hole each for 1/2” (which I often use), 7/16” , 3/8” (which I often use), 5/16”, 1/4” and 3/16”.
So if I want to put three dowels in a miter of a 2-1/2” x 3/4” stock, I have to make three separate index marks and move the jig 3 times.
This G-W jig has four tapped holes and comes with four each of the following bushings:  1/4”, 5/16” (which I think will work with 8mm dowels) and 3/8”.
The jig came adjusted and the holes are nicely in the center.
There are two sets of two holes, divided in the middle by the clamping screw.
I bought a while back a similarly spec’ed and designed jig from Harbor Freight.  But the holes were not centered.  Centering was a tedious (and undocumented) process.  But even after adjusting for center, the jaws were not parallel, so the stock was never securely held in position.  I tried it, but never used it.
With the G-W jig, I can make 4 holes with one index mark and one clamping.  But if I want three equally spaced holes (what I usually use for 3” wide stock) I have to drill two holes, use a dowel to index for a third hole.
So this is an improvement, but still not ideal.   I would like for all 4 holes to be equally spaced.  I cannot figure out how to do that.
I do have a dowel jig that will make 8 equally spaced holes, but it is not self-centering, so I have to keep the jig facing the correct direction all the time.  It seems I become dyslexic when faced with this and I prefer not to use it.
https://garrettwade.com/product/improved-self-centering-jig
Offline kmickey
Re: What non Festool tool did you buy today? Wera miniature ratchet.
« Reply #1305 on: March 16, 2023, 12:16 PM »
Thanks to a recent post by Ron @rvieceli , I was made aware that KC Tool had a sale on Wera products this week.
I purchased this Wera Zyklop Mini 1 ratchet. Instead of having a 1/4" male square drive on the end, it has a 1/4" female hex drive so that it will accept hex bits directly without needing an adapter. This thing is absolutely tiny and will fit in very small spaces, exactly what I needed. Another really nice feature is the black thumb wheel at the top of the ratchet for the rapid insertion of longer screws.
I’ve got one of those, love how the ratchet lever is shipped like a wera handle. Small detail, but indicative of the care they put into their products.
Offline jeffinsgf
  • Woodpeckers Marketing Department
« Reply #1306 on: March 16, 2023, 12:51 PM »
I've had one of these: https://products.wera.de/en/zyklop_ratchets_and_accessories_zyklop_mini_zyklop_mini_1_tool-check_plus.html
for several years. It has the mini-ratchet, a screwdriver handle, a nice set of small sockets and a gaggle of driver bits in a clever little case that keeps it all together. That little ratchet is the handiest thing ever for working in tight quarters.
« Last Edit: March 18, 2023, 05:31 PM by jeffinsgf »
Offline Richard/RMW
I can't recall where I saw these but someone suggested them and, you know...
I've got a bunch of the Irwin quick clamps that I use all the time, these are beefier in addition to being more versatile.
RMW
Offline ChuckS
Snip.
At that price, it's a steal! I paid about $55 US many many years ago.
Online Cheese
Re: What non Festool tool did you buy today? Snap-on wrenches
« Reply #1309 on: March 17, 2023, 12:36 AM »
I've been using this small Atlas metal lathe for the last 15 years or there about. A sweet little lathe that's very precise and accurate but some of the features are cumbersome which makes sense as it was originally released almost 80 years ago when life was simple.  [smile]  One of the major annoyances is the supplied Atlas wrench that's used on the adjustment of the tail stock. It's short but it's an open end wrench which means if you place it on the hex nut, it falls off. The alternative option is to use a box end wrench but that is a long wrench and is constantly in the way, which means the wrench also needs to be removed after each adjustment because it interferes with the adjustments & functioning of the lathe.
I finally found a solution to this conundrum. Snap-on "midget" combination wrenches.
I originally started looking at the Wera wrenches when they were recently on sale. The price was reasonable but they were the long style as is usual, had a funky bad chrome finish and were made in Taiwan...and they were asking $20 each for the wrenches.
So... I needed to spend $20 per wrench for something that didn't really fit my needs? I put them in my cart but then decided to revaluate the situation.
After a couple of days of evaluation and visiting many websites, I returned once again to Snap-on. I didn't want to spend the $$ but it soon became obvious that they offered the solution I wanted and for a reasonable price, all things considered.
Bottom line, I couldn't be happier, these are some extremely nice tools, you get what you pay for. Buy once...cry once, I'd spend the $$ again in a heart beat.
Here are the 3 Snap-on midgets I purchased, all dedicated for use on the Atlas lathe. These small lathes don't need a lot of torque to lock down the features, and too much torque applied can become an issue because they can damage the gibs and the mating surfaces.
Here's the original Atlas tail stock wrench. The square end is for adjusting the original lantern style tool holder bolt.
Interestingly enough, way back when, this lathe wrench was manufactured for Atlas in the 50's/60's by Armstrong Tools which is now owned by...wait for it...Snap-on.  [smile]
And here's how it fits on the lathe, really sweet, short and out of the way and it no longer needs to be removed to perform basic lathe functions.
« Last Edit: March 17, 2023, 01:04 AM by Cheese »
(Attachment Link)
RMW
Have you tried them? According to Bessey the clamping force is only 100 pounds.
Offline Packard
(Attachment Link)
RMW
I have a pair of the Harbor Freight knock offs.  The holding power has to be substantially less than the 100 pounds of the competition.  I only use it to. Hold pieces down for sanding or routing.  But very cheap.
Offline Richard/RMW
(Attachment Link)
RMW
Nope, not yet. By "beefier" I was referring to the feel/construction only. I'll give them a go this weekend. They are also limited to <6" depending on the configuration.
I mostly use the Irwin quick clamps and Bessey klik clamps for light duty, i.e. sanding, or where I'm clamping one-handed. For more aggressive needs I'll use Festool ratchet clamps (my overall favorite) or the Bessey Tradesman.
I did slip the new clamps into a guide rail and tighten them up. The reversed setup where the upper foot presses against the rail while the lower/movable foot presses against the stock has a really secure feel. They may replace the Festool ratchet/F-clamps for this use.
RMW
Offline guybo
@Cheese welcome to the poor house  [big grin]
Online Cheese
« Reply #1314 on: March 17, 2023, 10:28 AM »
Nice selection @guybo... [big grin] ...those look like all short pattern wrenches?  Snap-on has always been expensive, heck they were expensive when I first started to purchase them over 50 years ago. I always hate writing the check but once that painful experience is over, they're just a pure pleasure to use.
Not unlike the feeling of using a Lie Nielsen hand plane or a Starrett combination square. [smile] [smile]
« Last Edit: March 17, 2023, 12:06 PM by Cheese »
Offline rst
Just received Stabila's short elevator tripod.  I have a regular builders elevator tripod and a couple light duty camera tris but they are pretty light duty and wanted a heavier one for the Milwaukee 12v green laser I have.  The Stabilas as beastial as the builders.
Offline six-point socket II
  • formerly @the_black_tie_diyer
Knipex non-conductive long-nose pliers.
Kind regards,
Oliver
Kind regards,
Oliver
Offline SRSemenza
Kind regards,
Oliver
Hmmmm, I've been thinking about getting those.
If you have questions, fire at will. ;)
I will say that these are build with a very particular task in mind (hooking up meters and manipulating live wires without risk of creating a short) and are not exactly thin (jaws) or very versatile in that regard.
But they are way ahead of the Cimco ones, quality wise.
Kind regards,
Oliver
Kind regards,
Oliver
Offline rst
Milwaukee's 18v 1/2 x 18 band filer (sander).  I've  keep a corded one in van for years.  It's great for commercial locksmithing repair and modifying on aluminum or steel doors using 3m Cubitron and Trizact belts.  I also use the file sanders for glass notching using silicon carbide belts.  I also have the Makita 1x 21" for glass and wood applications.  Anyone looking for a corded one should let me know as I have three.
