Author Topic: What - non Festool - tool / workshop related gizmo/stuff did you buy today?  (Read 270440 times)
Offline ChuckS
You're right, JINRO. The CT26 is not good enough for those machines.
I use my DC with an auto switch for my SawStop - https://www.leevalley.com/en-ca/shop/tools/workshop/dust-collection/parts-and-accessories/63013-ivac-automatic-vacuum-switch?item=03J6210
So there is no need to turn on the DC separately. When the SawStop is turned on, the DC and the shop vac (for the overarm dust collection) also come onboard, with three tools working at the same time.
« Last Edit: December 21, 2022, 05:51 PM by ChuckS »
Offline JINRO
Awesome! This switch seems to be much reasonable for my need.  This will save me extra step to turn on the DC whenever it's in use. Thanks!!!
Offline JINRO
Get the dimensions for the plastic bag.  You will find 6 mil thick pclear plastic bags from Uline and others for less than Jet charges.
Perfect! I'll look into buying them separately! I'm also thinking about adding ~55gal can. But we will see :P
Offline Packard
I bought one of those switches, but I forgot that I had my electrician change my table saw over to 220 volts, so I was not able to use it as my dust collector is 120 volts.
Offline ChuckS
The iVac switch is the only auto-switch I could find that provides two 15A power sources simultaneously, not one 15A source for two outlets. I have three iVacs in my shop, one for the table saw, one for the Kapex, and one for the drill press/sanding station. I really enjoy the convenience (and protection in terms of instant dust collection and lighting) the switches offer.
Offline ChuckS
Not sure if this will allow you to turn on the dust collector with the table saw automatically:
https://www.ivacswitch.com/ivac-pro-auto-sensor/
The iVAC site is full of products and solutions. but the info. and multiple links included make it hard to digest for a layman like me. If they can use more diagrams or illustrations to present their products and uses, I'm sure I'll benefit from more of their offers. For now, I can only use their switch boxes.
I also came across on Amazon (but not on the iVAC site) this relevant info. about the iVAC switch boxes:
Edit - Just found this more useful explanation about their various products (start from 2:10):
« Last Edit: December 24, 2022, 01:43 PM by ChuckS »
Offline hdv
I have been looking at this great dowel maker for some time now. Today they had a nice 10% discount on everything at Fine Tools (Dieter Schmidt), which was the perfect excuse for me to finally give in and buy it.  [embarassed]
This system is flexible with adapters from 6 up to 26 mm and a cutting iron that can be sharpened or even replaced. I have seen it at a friends and it produces really nice dowels. Now I just have to think of a project to use it on...  [tongue]
Offline Crazyraceguy
I'm pretty sure that they have one that can be triggered by 220 volts and only out-put 110 volts to your collector, if that is what it requires. We had one in the old shop, before the big central collector system was installed. The Powermatic 66 turned on the Jet collector.
That's the one I had at my bench to run a cheap shop-vac from my first Domino. It worked flawlessly for several years, until the fire killed it. I bought a CT26 as a replacement, mostly because it was more portable. My I-vac was attached to the apron of my bench, which was a bit limiting.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
TS55, FS1080, FS1400/ LR32, FS1900, FS 2424/ LR32, FS3000
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
Offline Packard
Re: Crazy
I will do a Google search for this.  Thanks.
Packard
Offline pixelated
A Lie-Nielsen rabbet block plane showed up under the tree today, a joint effort from my wife and sister.
Now I need to make something with it.
Offline woodbutcherbower
An exquisite Sanjo Minemura 600mm stainless steel rule from Japan, to replace my ancient Rabone Chesterman one - it was so well-used that I'd practically worn all of the face etching away. Really happy with this.
Kevin
Offline Richard/RMW
A pack of Dogs!
From Axminster.
RMW
Offline GoingMyWay
I picked up a bunch of new toys from Lee Valley just before Christmas.
Squirrel tail plane, surface clamp, right angle saw guide, flushing chisel, set of 3 Japanese saws, pin style marking gauge, 2 planing stops, and a wooden hand screw clamp.
Inquiring Minds Want to Know
Offline Richard/RMW
Magswitch fence for the drill press has been on my list for a while, Santa came through finally.
I think it is going to be super handy.
RMW
« Last Edit: January 04, 2023, 07:28 AM by Richard/RMW »
Offline festal
(Attachment Link)
RMw
I got the same.  Was yours 90 to the table?  my first one was off, got the replacement and it was also off but by less. I shimmed it with blue tape.
Offline Richard/RMW
(Attachment Link)
RMW
Haven't checked yet but now I will, Thanks.
RMW
Offline ChuckS
Something this basic was out of square, and shim is used? That was a surprise to hear about the product.
Offline festal
Yep. i called them and they said a batch was sent out with the issue.  new one was sent out (took over 2 weeks to get) and had similar issue but was able to fix it via shim.  Might be design flaw.  Magnets are fixed in place, there is a gasket on the bottom to assist with holding power and screws that attach magnets to the fence are kind of self alligning so not much you can do to fix the issue at least nothing in the manual about it
Online tsmi243
How you like the Evolution magdrill in the background?  I've got some gift cards to burn, and that thing keeps showing up in my Amazon ads....
Offline six-point socket II
  • formerly @the_black_tie_diyer
Japanese tool for made to measure cable ties/ cable ties without waste/ large cut offs.
Nirei Industry Co LTD NT45CKB - also available via Walraven, there it is called the "Starlock I" -> https://www.walraven.com/us/products/tool-and-accessories/
352510-0
Kind regards,
Oliver
Kind regards,
Oliver
OLIVER! Great to see you again! Happy New year!
Offline hdv
Hallo Oliver! Schön dich wieder zu sehen hier am Forum.
Offline rst
Happy New years Oliver
Offline Richard/RMW
@tsmi243 It works great, no complaints. I would however probably spend the extra $$ for the Dewalt after learning how much I use it. I cheaped out and kinda regret it now.
Evolution is absolutely a great drill for infrequent use. DW has 2-speed and quick release chuck.
RMW
Offline rst
6" Metabo 601737830 WPB 18 LT BL 11-150 Quick 6" Angle Grinder, to complement my WF 18 LTX 125 QUICK (601306660) CORDLESS FLAT-HEAD ANGLE GRINDER and AS 18 L PC (602021860) CORDLESS VACUUM CLEANER
I finally got around to getting a metal cutting circular saw. Metal is like a foreign language is the cabinet shop. Everyone seems to cringe at the thought of having to deal with it?
The company has one of the cheap horizontal cut-off type band saws, and a few of us have portable bandsaws, but sometimes that just won't get it. A jig saw can do some things that a bandsaw can't, but long straight lines aren't really the thing there either.
We have always seemed to work it out in the past, but it usually took more time and effort than it should have. Hopefully this is the cure.
I am trying to be more mindful of the potential use of the things I buy, as far as in the future. With retirement getting closer all the time, it would be nice to have a use for this stuff. This one is a simple yes. I have been a metal worker for far longer than with wood. It should fit right in.
I'm very much in the process of improving my garage with plan of bringing all of my stuff home this summer. The weather has been great for it too.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
Thank you very much! Happy New Year! :)
Kind regards,
Oliver
Kind regards,
Oliver
Offline rst
Battery powered steel cutting saws are a result of blade technologies, I have been using them to modify steel doors and frames for 20 years or more. I originally was using a PC Sawboss with a router speed controller as steel cutting requires slow speeds.  I have a Milwaukee 6.5” 18v cordless now.  The cuts are so smooth that filing is almost not necessary,  The newer steel cutting Milwaukees have a smaller blade size, I assume to reduce torque and thus battery time.  The saw I have was Milwaukee's original with the old massive 18v batteries.  I bought an adaptor the will allow the saw to use the current batteries.  That couples with some Magwitch allows me to clamp a straight edge on steel doors  in order to retro fit lite kites.
,  as
« Last Edit: January 05, 2023, 03:10 PM by rst »
Online Cheese
Re: What non-Festool gizmo did you buy today?
« Reply #1198 on: January 04, 2023, 09:57 PM »
I finally got around to getting a metal cutting circular saw. Metal is like a foreign language in the cabinet shop. Everyone seems to cringe at the thought of having to deal with it?
I purchased the 8" Milwaukee 6370-21 circular saw when it was first introduced in 2004. This saw is corded and was specifically designed to cut metal profiles and sheets. It works well, however, after Festool released their aluminum blade for the TS 55 saws, I made a conscious decision to try something different.
I still use the Milwaukee saw for fairly thick aluminum sheet (3/8"-5/8") and stainless but the TS 55 really shines with the thinner profiles. Throw in the Festool guide rail and all cuts are absolutely straight.
The Milwaukee doesn't have a vac port so small metal chips can migrate to between the saw base and the sheet material you're cutting, leaving nasty scratches in the sheet material. I added a HDPE strip to the bottom of the saw base and that helps considerably, but sooner or later you need to pick out the metal chips that have imbedded themselves into the HDPE.
I'm curious that with the recent additions of the Festool aluminum blade & CMT metal blade for the TS 55, why you didn't go that route and gain the precision/straightness when using the guide rail?
Offline Packard
I only cut bar stock in steel.  I have a right angle grinder so I knew about the sparks and dust the chop/cutoff saws with a grinding wheel make.
I bought a small “chop” band saw.  It probably cuts a little slower than the grinding type cutoff saws do, but no sparks and it will complete the cuts unattended leaving a small pile of oily chips behind.
Obviously not for cutting sheet goods, just for aluminum and steel profiles.
