The sawfence cursor is a rough tool to me. I find the factory cursor (with a magnifying lens or not) more than good enough.
For precision cuts, I don't rely on the cursor or the saw scale/tape. If I want to cut identical stock of 12" width, it doesn't matter whether the saw fence is set at 12" 1/64 strong or weak, as long as all the cuts are done with the same fence setting.
When I need to cut a stock that must fit exactly, say, an opening, I measure the opening with a steel rule or tape and then set the fence using that very same rule or tape, which may or may not give the same measurement as the tape on the saw.
