Here is an extremely simple rig that works good enough for long enough…
I need to glom a panel onto my kitchen pantry so that I can scribe three edges at once. There may be other ways to do this but space is tight and I don’t want clamps or poles in the way nor tape that would interrupt the scribe marks, and I just want to use vacuum.
I have the Festool Vac Sys but don’t have fittings to go beyond the closed system. I do have a DIY system I built a decade ago based on the Joe Woodworker site and it has a simple 3/8” hose (from JW) that is very adaptable.
But I will need more hose and fittings so Amazon delivered this
Tailonz kit.The Tailonz PU tube is much stiffer than the Joe Woodworker stuff but the push connect fittings work with both hoses. I connected the Joe hose to the 100 foot loop of PU hose with a push connect T fitting and the pump evacuated the hose in a couple of seconds and shut off. After a few minutes I hit the off switch and proceeded with the glom test.
I used a step drill with long steps to make a 3/8” hole in a scrap piece of pre finished plywood. On the opposite side made a rough ring of 1/8” closed cell self adhesive foam around the hole. Back at the front just stuck the 3/8” PU hose into the hole (it felt more secure than the Joe hose).
Switched on the pump and pushed the plywood against a cabinet side and it worked. The pump kept running because of the leakiness of this extremely crude rig but it held firm.
