Author Topic: IVAC System  (Read 1198 times)
Offline Birdhunter
IVAC System
« on: January 28, 2019, 12:30 PM »
I just installed an IVAC system to automatically turn on a Festool vac when I fire up my SawStop table saw. The Festool vac connects to the saw’s overarm blade guard and dust collector. I have a 220v big cyclone vac connected to the saw’s 4“ port.
The IVAC current sensor clamps onto the table saw’s 220v power cord and the Festool vac plugs into the IVAC’s switching box.
At first, the IVAC system didn’t work. The current sensor seemed to be working correctly but the switching box wasn’t.
I tried unplugging both IVAC units then plugging them back in. Presto! It all worked.
Dust collection has always been very good, but now it is excellent.
Birdhunter
Offline blaszcsj
Re: IVAC System
« Reply #1 on: January 28, 2019, 12:55 PM »
I also have the iVac pro system. I have used it successfully for the past year on my onieda V3000 and K3. Only difference is that I had to purchase the high hp contactor version of the iVac switch so I can run 3+hp motor. It works flawlessly. Only time I have to reset it is after a power outage.
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro
Offline Birdhunter
Re: IVAC System
« Reply #2 on: January 28, 2019, 05:28 PM »
Although my IVAC system is working now, it bothers me that I don't know what caused it to start working after it was initially inoperative. What do you do to restart your system after a power failure?
Birdhunter
Offline Mario Turcot
Re: IVAC System
« Reply #3 on: January 29, 2019, 12:27 PM »
Do you have the standard system or the Pro?
Standard
Pro
I believe in both case you might have to switch off and on from the picture below
« Last Edit: January 29, 2019, 12:30 PM by Mario Turcot »
Mario
Re: IVAC System
« Reply #4 on: January 29, 2019, 12:32 PM »
I found another model, the Pro magnetic switch. For that one, with no doubt you have to flip off & on.
Mario
Offline blaszcsj
Re: IVAC System
« Reply #5 on: January 29, 2019, 07:32 PM »
I would have to reset the mag switch on the Oneida.
Offline Birdhunter
Re: IVAC System
« Reply #6 on: January 29, 2019, 08:30 PM »
I bought the Pro version. The IVAC only switches a 110v Festool vac.
The system is working flawlessly. If it malfunctions, I will cycle that switch.
Thanks.
Birdhunter
Offline DeformedTree
Re: IVAC System
« Reply #7 on: January 30, 2019, 09:20 PM »
Pro
Wow,  you posted a Unicorn, a device with a 20A plug in the wild.  Closest I have seen before is a spec sheet for a special microwave the used one, but they showed no picture of it.
