Author Topic: UJK parf guide mk1 guestion  (Read 697 times)
Offline Paul Wells
« on: February 25, 2021, 03:05 PM »
Hi all,
I've just purchased the mk1 guide system, and noticed that the new rules, have both 3mm and 6mm holes for the drill guides, I assume, this so only need to produce one rule for both kits, also the guide pins seem to fe the same as used in the mk11, as is the 20mm jig,
My question is, as I've not had the chance to use this yet due to work commitments,and being away from the set, does anyone know if you can use these new rules to drill offset holes, using the 3mm hole positions. I havnt got any pictures of the new rules, but they have the 6mm holes and also a set of 3mm holes.
Thanks in advance.
Offline Paulhoward
Re: UJK parf guide mk1 guestion
« Reply #1 on: March 03, 2021, 10:01 PM »
I would like to know the answer, because I have the mark 1 system also have the mark 2 system. I would like to know if the sticks can be used for both systems?
Offline cubevandude
« Reply #2 on: March 06, 2021, 05:08 PM »
Can you post some pictures please?
Offline imdking
  • Tropical woodworking hobbyist
« Reply #3 on: May 14, 2021, 10:43 PM »
Please watch "New Brit workshop" videos on Parf guide system, then Parf guide mark ii. You'll then understand the differences between the two. Just searc on YouTube.
TS55 REBQ, FS 1400/2, FS 800, Festool carrying bag for rails, FS-AW Cable Deflector, Kapex KS 120 REB, CTM Midi, Domino DF 500, FS-HZ 160 ratchet lever clamps x2.
