Author Topic: TSO Parallel Guide System FlipStop 2.0  (Read 4202 times)
Offline Mike Goetzke
« on: December 07, 2020, 11:03 AM »
I received my upgrade kits last week and applied them over the weekend. The version 2.0 includes a stop collar so if you remove the stop you don't need to recalibrate it and a spring under the tightening knob.
I thought the collar was needed on day one but this spring addition is ingenious! This spring holds the stop in place while tightening the knob saving you time and increasing the accuracy. Kudos to @TSO_Products !
@TSO_Products - a set of stop collars for the narrow stock rods would make this a total winner. Please offer these on you site.
Mike
Offline Rick Herrick
Re: TSO Parallel Guide System FlipStop 2.0
« Reply #1 on: December 07, 2020, 01:18 PM »
This is good news.  I have wanted another set of stops and guide adapters but availability (and some confusion on my part) has kept me from pulling the trigger.
So, you bought the upgrade kits that turn your original flip stops into the 2.0 versions?.  If I read it right, thats $20 and a new, V2.0 flip stop is $40?  Just trying to decide which way I would want to go.  I want to leave my originals on the TPG guides and get another set, and a set of guide adapters for smaller work.  But again, availability is still up in the air, I think.
Offline Josh2
« Reply #2 on: December 07, 2020, 01:44 PM »
Can you describe more what exactly version 2 does? I thought v2 allows you to change between the standard rods and the longer rods for cutting narrow stop without recalibrating each time you switch. Is that correct? Your comment about the narrow stock rods "stop collars for the narrow stock rods" confused me a little.
Thanks!
Mike
Online MikeGE
« Reply #3 on: December 07, 2020, 01:51 PM »
I'm confused.  At the end of July this year, I ordered my TSO TPG-50 Complete Kit, which is apparently no longer available.  Aside from the stop collar, my flip stops are the same as the v2.0.  What does the original flip stop look like?
@TSO_Products , can you explain this?  Am I missing the stop collars from my flip stops?
Offline Mr_Stop
« Reply #4 on: December 07, 2020, 01:51 PM »
I have been looking at the same setup, but have also held back due to the unavailability of items.
@Josh2 You are partially correct about the recalibration. The upgrade only includes one stop to my knowledge.  Therefore, assuming you put it on the standard rod, that wouldn't need recalibrating.  However, the narrow stock would need calibrating.  An extra stop would, in theory, allow you to swap both rods out without recalibration.
I set TSO an email about adding another calibration collar, but I haven't heard back.
I'm curious to those who have swapped track lengths.  Have you had to recalibrate when going from say the 30" to 50"?  I haven't tried it yet so just wondering other peoples experience.
« Reply #5 on: December 07, 2020, 02:06 PM »
My stops were on my TPG 30s as its the only length I really needed at the time.  I then wanted to try the 20s.  I don't know if I had to recalibrate but I did anyway because there is play when you attach the new length so I wanted to make sure I had things set up correctly.  Another reason I want several sets of stops and guide adapters but cost really adds up.  Convenience can get expensive.. [wink]
« Reply #6 on: December 07, 2020, 02:14 PM »
OK - I'll try again. The new 2.0 (below) has the collar for the short adjustable depth stop and a counterbore in the body to accept the newly added spring (pic captured from TSO):
Upgrade kit includes the following (from TSO):
Would be nice to be able to purchase a pair of the collars for the thin stock rods because there would be no need for a second pair of stops (at least for me).
Offline Mr_Stop
« Reply #7 on: December 07, 2020, 02:25 PM »
Yes on the expense of convenience.  I'm have been looking at another set of adapters and fllip guides to dedicate my 20" bars for narrow rips.  $175 + shipping/tax and I already have the T-tracks. [eek]
« Reply #8 on: December 07, 2020, 02:29 PM »
I have all three lengths of t-tracks (I was one of the first to purchase this system). The 50" one has a high quality Sterrett rule applied and the other two are laser etched. I was told 50" wasn't laser etched due to capability of the machine. My 20" and 30" match well but the 50" was off a bit. I worked with Hans and was able to adjust the rule on the 50" to match the other two.
Ugh (the price to pay for early adoption and great innovation) - looks like they found a way to laser etch the 50" t-track so all three tracks probably don't require flip stop adjustment. Also, noticed they now machine additional holes in the track so you can use a new connector to attach them for a longer track. They do offer a fixture to add the holes on the older style but since I have the 50" t-track probably not needed.
Online MikeGE
« Reply #9 on: December 07, 2020, 03:01 PM »
I can't levitate the components of my Flip Stop, so a flat exploded view will have to do.  Here is what I received in my July order.  Aside from the stop collar for the short positioning rod, what is the difference between my stop collars and the original version?  Also, I did receive the LASER engraved 50-inch rails, so I am pleased with that.
Offline Josh2
« Reply #10 on: December 07, 2020, 03:19 PM »
The stop collar seems to be part of the upgrade kit. Do they work on the narrow stock guide? If they do, purchasing two additional upgrade kits would give you stop collar for both the standard and narrow stop guides with easy swapping between the two. Is that correct?
A little less elegant but would it also be possible to simply use a drill bit stop collar in the correct size?
(Attachment Link)
(Attachment Link)
« Reply #11 on: December 07, 2020, 03:25 PM »
(Attachment Link)
You are correct - looks like you have the latest hardware except for the stop collar.
The original flip stops did not have that spring or counterbore in the block to accept the spring.
Mike (this is my opinion, please check with TSO for exact answer)
« Reply #12 on: December 07, 2020, 03:27 PM »
(Attachment Link)
(Attachment Link)
Yeah, but you would be paying $40 plus shipping for two stop collars. I'm sure since more than one of us would like additional stop collars TSO will more than likely offer them.
Online MikeGE
« Reply #13 on: December 07, 2020, 03:30 PM »
@TSO_Products has been mentioned several times in this thread, so I eagerly await a reply from Hans sometime next Spring.  Maybe.
« Last Edit: December 07, 2020, 08:23 PM by MikeGE »
« Reply #14 on: December 07, 2020, 08:04 PM »
@TSO_Products has been mentioned several times in this thread, so I eagerly await are reply from Hans sometime next Spring.  Maybe.
Don't think TSO is a big company but they produce high quality, unique, and useful tools. I started this post to report on my positive experience with the improvements to the flipstops.
One more improvement I thought would be if they offered two more stop collars for the narrow stock rods. I'm sure they will but I see I can tide myself over for $3 at Amazon for some not so good looking aluminum collars. Maybe you have a similar source?
Online MikeGE
« Reply #15 on: December 07, 2020, 08:23 PM »
I am no stranger to TSO Products and do like the products they market.
However, when it comes to communications, TSO Products has a lot of room for improvement.
Offline jobsworth
  • Festool Baby.....
« Reply #16 on: December 08, 2020, 09:23 AM »
@MikeGE
Wow Mike thats a cool like ya made.
 I like it.
I might end up using that idea.
Offline TSO_Products
    • TSO Products LLC
« Reply #17 on: December 08, 2020, 01:49 PM »
- TSO hears you -
We will prepare a new SKU on our website
61-377 Clamping Collar, Calibration Memory, pair $ 9.95 net
We will announce the availability when it is available to order on our website. We do have stock to supply all foreseeable demand at this discounted price.
This unique assembly includes a custom Socket Head Cap Screw with a 2.5mm thread but a non-standard Socket Head to fit your regular 3mm Hex Driver so one tool now fits all principal user adjustments including the TPG Adapters.
The Upgrade Kit also includes a replacement Screw for the securing the calibrations rods in the FlipStop arm using the same Hex Driver and replacing the former 2.5mm Hex L-wrench requirement.
Look for a separate response on the StarKnob question for those Makita users who would prefer that optional accessory for the TPG ADAPTER.
Hans and Team Tuesday morning
Offline Mr_Stop
« Reply #18 on: December 11, 2020, 12:43 PM »
FYI - It looks like all the accessories are back in stock and I just placed an order.  Extra bonus, free shipping started back today!
The extra collars haven't been listed yet to my knowledge.
Offline Packard
« Reply #19 on: January 26, 2021, 08:22 AM »
I hope someone can help me with calibrating my parallel guide system.  The minimum calibration would be the stock directly against the aluminum stop.  That yields a cut that is about 1/8" larger than indicated.
I probably have something installed incorrectly, but I have been staring at the stops for a couple of hours and nothing seems out of place.  There is only one way to mount the arms onto the rail square and there seems to be just one way to install the stops onto the arms.
I have attached some photos.  If someone could point out where I have made a mistake it would be greatly appreciated.
Offline 08G8V8
« Reply #20 on: January 26, 2021, 08:34 AM »
Your plunger in your 2nd picture is installed backwards. Flip it around. That is what your material butts up to, and what you calibrate to.
Actually, I think you have the flip stop for the other hand rail installed.
« Last Edit: January 26, 2021, 08:41 AM by 08G8V8 »
Offline 08G8V8
« Reply #21 on: January 26, 2021, 08:37 AM »
Check out their calibration video on their website.
https://tsoproducts.com/tso-parallel-guide-system/tpg-parallel-guide-system/
Also, Dave Stanton just released a video for an alternate method of calibrating.
« Reply #22 on: January 26, 2021, 08:42 AM »
Ugh - missed this (and offering collars was my suggestion). If I add them to my cart for $10 shipping is $14  [eek].
I called TSO asking if there was a better way to ship small items and was told they are stuck with the auto-calculator - this needs some help @TSO Products
    • TSO Products LLC
« Reply #23 on: January 26, 2021, 09:39 AM »
small items shipping at TSO :
thanks to multiple customer comments we became aware of the problem with ourt shipping system calculating and selecting less than optimal shipping container and cost.
We have launched an all-out attack on this multi-layered problem rooted in shipping software on the one hand and the complexities of carrier rate structures and selection.
Thanks for speaking up! - that's how we can improve.
Hans
Offline Packard
« Reply #24 on: January 26, 2021, 09:53 AM »
Thanks for that!  I am looking at the picture now and I think it will address the problem.  When I get home I will try it out.
Offline DynaGlide
« Reply #25 on: January 26, 2021, 10:07 AM »
@08G8V8 Thanks for the video. For some reason I'm not subscribed to Dave anymore and I missed out on quite a few videos. A worn splinter guard is probably the reason some of my long rips were ever so slightly off on full sheets. I just upgraded to the 2.0 flipstops and need to calibrate anyway, how timely.
Instagram @matts.garage
Offline Packard
« Reply #26 on: January 27, 2021, 10:42 AM »
In image 1, I am showing the flip stop set at 20".
326603-0
In image 2, I am showing that the cut would be at 19-3/4" despite the flip stop at 20" and no further room for adjustment.
326605-1
In image 3, I am showing where the flip stop would have to be in order to get a 20" cut.
326607-2
In image 4, I am showing the ruler registering zero at the starting edge of the while melamine particle board
326609-3
« Last Edit: January 27, 2021, 10:56 AM by Packard »
Offline 08G8V8
« Reply #27 on: January 27, 2021, 10:54 AM »
Did you follow the TSO video by setting the flag stop to 10”, then use a combination square set at 10” against the rail cut edge, and the adjust the plunger to hit the square to lock in the calibration at 10”?
Offline Bugsysiegals
« Reply #28 on: January 27, 2021, 11:46 AM »
@Packard ... you've set your TPG's up all wrong. You've the flip stops on the wrong rails and you've put the stop collar on the wrong side which completely defeats the purpose of it.  Please have a look at the photo below for the correct setup.
Offline Packard
« Reply #29 on: January 27, 2021, 11:49 AM »
The calibration attempt was originally made at 10 inches.  However, when I went to photograph it, the unsupported parallel arms were unstable and would fall off the board before I could take the photographs.  If I had someone with me to hold it down I would have stuck with the 10" setup.
The results were identical for both settings.  It was 1/4" off in both cases.
In any case, the instructions suggested "an easy to use dimension such as 10".  The 20" dimension was easier to use for photographing and would not affect the results.
