I'm looking for one too. I have one car garage shop and I'm thinking of 1.5hp, ~1200 cfm. Will it be enough for me to use it for Miter, Table, Planer and Jointer? Or do I have to go larger? I know 2hp jumps price pretty high...
Forget the HP rating and buy the unit that has the biggest impeller. The HP rating means zip unfortunately as a 2 or 3HP on a 12" impeller will flow the same amount of air as long as the motor is at full speed.
All DE's with bags either plastic or cloth leak dust, I have never seen one that doesn't.
Never believe the advertised CFM numbers, they are all BS apart from a few noticeable exceptions such as Oneida or Clearvue and the latter does not quote flow numbers or didn't but I have not checked lately
If all you want is to keep the floor clean and pick up the big stuff just about any high volume DE will do that job and so will a broom but it won't collect the fine sub .5 and under particles that permanently stay in you lungs and cause long term health issues.
Vacuum cleaners do not capture the fine dust and the cheapies smash what they do collect into smaller particles and they all leak.
To collect the fine dust a high volume DE using 4+ inch ducts is required
Cyclones of any size are inefficient and reduce the airflow because that is how they work
The retail industry has not got a clue about dust extraction apart from the few companies such as Oneida and Clearvue etc.
Flexible hose kills air flow in a major way
Buy a dust monitor and use it to minimise the airborne dust, information is knowledge
Depressing isn't it, people think they are doing the right thing and they are literally being given the wrong information which then has long term health effects that can't be reversed. You are better off buying a powered respirator and forgetting tiny DE's, no floor space issues, no hoses etc.
