Author Topic: The Mighty Sword!  (Read 21289 times)
Offline Deansocial
Re: The Mighty Sword!
« Reply #60 on: July 26, 2012, 04:40 PM »
Offline jmbfestool
« Reply #61 on: July 26, 2012, 05:05 PM »
I agree!!
Not worth the money if your going to use it for roofing.
The other things like I have demonstrated like cutting oak curves etc its perfect  cutting using the rail can be very handy.
JMB
« Last Edit: July 26, 2012, 05:13 PM by jmbfestool »
*********************************************************************** [thumbs up]UK members click me
Offline Deansocial
« Reply #62 on: July 26, 2012, 05:08 PM »
Thats why i said for what i use it for
Offline jmbfestool
« Reply #63 on: July 26, 2012, 05:13 PM »
and thats why I said I agree! but just backing up wa u was saying!
JMB
Offline Deansocial
« Reply #64 on: July 26, 2012, 05:14 PM »
Good tool tho.
« Reply #65 on: July 26, 2012, 08:31 PM »
Well i used jmbs sword saw today, my conclusion is that he needs to buy a cross cutting chain and the the bar imho is a little short for what we used it for but dont think the saw could handle much more. Also using it to gang cut rafters it tilts the wrong way as it sits on the offcut whcich means your cut starts to twist as you go along. Fine piece of kit but dont think i could invest that amount of money into it the way it is fordoing what i want to do with it.
Dean, couldn't you just turn the job over in your mind (or the boards if they already had some other joints cut) so that the pointy side was up? Then the guide rail could have stayed on the solid boards.
Offline Deansocial
« Reply #66 on: July 27, 2012, 02:11 AM »
Birdsmouth further dow the rafter to cut
Offline leecab
« Reply #67 on: November 21, 2021, 12:11 AM »
I have the 200mm sword saw.
The bar is not getting lubrication. That is despite the bar being clean and the 2 holes are not clogged. The oil pump is working as oil flows out.
The oil flows around the bar face and inside and around the plastic support surface, but wont go into the bar holes as the chain is always dry.
Yes I tested the red knob that selects oil 1,2 and full position.
Im using standard bar oil, even tried thinning it with kero.
NOTHING WORKS!!!
What is there left to consider anyone???
