Author Topic: Temp gun vs Thermal Imager which one? Plus a little on wall scanners.  (Read 3037 times)
Offline SRSemenza
Looking at a temp gun or thermal imager for general use. Not any type of specific task. Which is more useful for general stuff. If you were choosing just one (don't factor the cost difference ).  Not interested in the cellphone type.
Can the camera / imager do everything the gun does?   Is one better at some things than the other?
EX- Klein TI250  , Klein IR10
Offline Reed Hoyer
« Reply #1 on: February 09, 2023, 08:33 PM »
I have used a couple of flir thermal imagers (one cell phone operated and one stand alone unit) and they’re great for exploring broad areas to find things like leaks or insulation issues. You can get fairly accurate pinpoint temperature measurements with them but a temp gun is likely more accurate for that task. On the whole I think the imagers are significantly more versatile. You can walk around a house and just find all sorts of issues. Duct disconnected in a wall? You’ll see a hot or cold spot. Window frame poorly sealed? Insulation missing in a wall or ceiling area? Some random electrical thing burning up inside a wall? Unless you know exactly where an area of interest is you’ll probably never shoot it with a temperature gun. You walk around any house for 10 minutes with an imager and you’ll find 5 things that’ll need fixing.
I know you said you’re not interested in the cell phone options but you save a lot of money letting your phone be a much better computer than what’s in literally any unit you can buy. If you’ve got the money, though, might as well spend it.
Reed
Offline six-point socket II
  • formerly @the_black_tie_diyer
« Reply #2 on: February 09, 2023, 08:58 PM »
Generally speaking, the temp gun will give you a pinpoint temperature reading whereas the thermal imager will give you a temperature reading for every pixel it displays. This makes assessing/capturing a situation as a whole much easier.
A lot of the simple temp guns have a fixed emissivity grade, meaning that they are most accurate when whatever you aim for/ want to measure fits that emissivity grade. If not, your readings are going to be off, they don't have to be dramatically off, but will still be off.
Most thermal imagers can be set to specific emissivity grades you need for the task at hand, that requires you to familiarize yourself with typical emissivity grades for different surfaces/ applications. And when/if necessary to come up with corrective measures. Like a pitch dark black sticker, for example.
The ones I know come with thick manuals and to make the most of a thermal imager, it's reading time first. :)
Here's a pretty comprehensive list of collected emissivity grades/levels in english:
https://www.transmetra.ch/images/transmetra_pdf/publikationen_literatur/pyrometrie-thermografie/emissivity_table.pdf
Only one, definitely the imager.
Reality, the classic temp gun sees far more use, since it is less fuss to use and more often than not, I don't need a full image but rather a spot/ small area. And if I would get out the imager when checking the temperature of my salt blocks on the BBQ, my better half would probably eye-roll and vanish back inside the house ... ;)
However, looking at a breaker panel, radiant (floor) heating, insulation, water leaks, (...) the thermal imager is king.
Kind regards,
Oliver
« Last Edit: February 09, 2023, 09:09 PM by six-point socket II »
Kind regards,
Oliver
« Reply #3 on: February 09, 2023, 10:48 PM »
Definitely a thermal imager guy...I own both and the thermal imager documents the condition while the gun only records the condition.
Like Reed suggested, don't dismiss the capabilities of a phone based imager, they are a great bang for your buck despite the recent issues. [sad]
Offline SRSemenza
« Reply #4 on: February 10, 2023, 12:23 AM »
As far as the phone imagers go ..............  it is not the capabilities or the price. The prices of the few that I have looked at (phone vs whole unit) don't seems that much different at least within the same brand. I just prefer a dedicated "tool".
Offline afish
« Reply #5 on: February 10, 2023, 08:56 AM »
I agree with previous comments, I already own a temp gun and it is handy to have and if you are trying to use it to find energy deficiencies in your home. It can and will help but as others say its more of a pinpoint vs broad picture.  I have a few energy deficiencies I need to address at my home as well especially now that electricity is much more expensive.  For example I have a lot of south facing glass probably about 75% of total area, with no shade and knew it was a big issue but the temp gun will give you a better picture of just how bad a situation is. In my case the south glass was reading 126° while my shaded windows were in the 79-80 range. As I said I knew it was an issue but when you see the discrepancy in black and white it can be eye opening. So I think the best solution is to add a large continuous awning to shade all that glass. I also had my attic spray foamed a few years ago and while it made a huge difference I have some suspicions that it is not as air tight as it could or should be. So, I want to scan my attic with a thermal camera to see if there are any hot spots or spots along the eaves that might be leaking air,  I have very little access to my attic so a temp gun would never give me the full picture as the thermal camera.  A thermal camera will quickly identify issues in a situation like this.  I am most likely looking at the HIT-19 and I also prefer a stand alone tool to phone apparatus.  Its on my short list as soon as I finish up some other projects.
Offline SRSemenza
« Reply #6 on: February 10, 2023, 09:01 AM »
What brand is this?  Link?
Offline afish
« Reply #7 on: February 10, 2023, 09:09 AM »
Sorry, dyslexia kicked in HTI not HIT
LINK
Offline SRSemenza
« Reply #8 on: February 10, 2023, 09:58 AM »
   Thanks.  If I go with thermal imager it will be in the under $300 price range. The Klein seems nice and is only a bit more than Kleins cell phone version. Are there others worth considering that are under $300?
Online Michael Kellough
« Reply #9 on: February 10, 2023, 09:59 AM »
This one is interesting too.
Oops, at double your price range…
« Reply #10 on: February 10, 2023, 10:15 AM »
The thing I liked about the phone mount imager is that it's small and I just keep it in my pocket, nothing extra to carry around really, it's about 2.5" x 1" x .5" These photos are from the Gen one version which came out in 2014. The resolution of the new imagers is quite a bit better.
HVAC leaks
AC duct in-wall
Surface temperature of a black car on a sunny 85º day
« Last Edit: February 10, 2023, 10:26 AM by Cheese »
Offline afish
« Reply #11 on: February 10, 2023, 12:08 PM »
10-4 if you get the Klein report back how you like it, Im not excited about spending 600 for one.
Offline SRSemenza
« Reply #12 on: February 11, 2023, 07:14 PM »
So another question.....................
              How well ( if at all ) does a thermal imager see into a wall? Probably a pipe with hot water will show? How about other things? Electric cable?
Offline PaulMarcel
    • Voilà, my blog
« Reply #13 on: February 12, 2023, 02:17 AM »
Oh I love my Flir (iPhone model). Not the most expensive and it's an older model, but I use it regularly to see into walls. Hot water would be easy. I don't think you'll see electric cables, but I honestly haven't tried to find any.
In these samples, you can see the studs in my dining room. The purple blobs on the ceiling shows where water got into a damaged soffit. Can't see it from the inside anymore without the imager so I'm leaving it until I replace the roof.
The second photo is of a second-floor room's outside wall. You can see the horizontal bracing clearly.
One thing I like about the phone-based Flir is that it takes a thermal image as well as a regular photo simultaneously. When you review photos, you can use an opacity slider to locate anomalies better.
This is the only imager I have any experience with so maybe all the others do the same  [tongue]
Offline festal
« Reply #14 on: February 12, 2023, 06:56 AM »
@Cheese  @PaulMarcel what model of the flir are you using with iphones?  looking to get one and can't decide which one to go with
« Reply #15 on: February 12, 2023, 07:20 AM »
Seth,
if you have an acute thermal issue with any electrical cables/wires/stuff the thermal imager will most likely make it visible immediately.
If you just want to follow/find a circuit/line, hook up a vac, iron, fan heater, (...), to the corresponding outlet, let it run for a bit. The minimal rise in temperature of the outlet and circuit feeding it will most likely make it visible to the thermal imager.
I have to add, in case someone else later on reads this and tries it: you only do this when you have absolutely no reason to believe the circuit/line is compromised in any way. This is to find/isolate an intact & trustworthy circuit/line only!
I've had good results with this technique.
Kind regards,
Oliver
« Last Edit: February 12, 2023, 07:24 AM by six-point socket II »
Kind regards,
Oliver
Offline Sparktrician
« Reply #16 on: February 12, 2023, 09:21 AM »
Seth,
Kind regards,
Oliver
I would use this method ONLY in conjunction with a clamp-on ammeter placed at the breaker panel to assure that current on the circuit in use does not exceed the capabilities of the wiring and/or breaker.   [unsure]
- Willy -
Offline SRSemenza
« Reply #17 on: February 12, 2023, 09:54 AM »
Are all of these imagers FLIR or are there different types of thermal imagers? I see some using "FLIR" and some not, in descriptions.
« Last Edit: February 12, 2023, 10:46 AM by SRSemenza »
Offline SRSemenza
« Reply #18 on: February 12, 2023, 09:58 AM »
Seth,
Kind regards,
Oliver
I would not be using this idea to find bad wiring. It would be to find good wiring so as to avoid hitting it during an install.  I don't see why it wouldn't be safe to plug something in and run it just as normal everyday.
I realize there are wall scanners too. Just want to know how far the imager capabilities go.
« Last Edit: February 12, 2023, 10:06 AM by SRSemenza »
« Reply #19 on: February 12, 2023, 10:04 AM »
Seth,
Ya I agree with Oliver, these Flir units seem pretty sensitive to small temperature differences so I'd just load the line you want to trace with a heat gun or soldering iron and it'll probably become pretty evident. I'd also take a before and after photo of the area in question because that may be easier to isolate exactly where the wiring travels.
@festal I've used the original Gen one with an iPhone 5, 6 & 10, then the Flir battery went south.  [sad]   I'm now looking at purchasing either one of these but I can't make up my mind. It'll be coupled to a 14 Pro.
The Flir One Pro is nice because of its size, it easily fits in a shirt or jeans pocket. The Flir One Pro works with iPhone 14 thru iPhone 7.
https://www.flir.com/products/flir-one-pro/?model=435-0006-03&vertical=condition%20monitoring&segment=solutions
The Flir One Edge Pro is nice because it operates attached to or detached from the phone...think remote applications like holding it over something or around a tight corner. Because this is detachable, it communicates with BlueTooth and it can be used with either iOS or Android
https://www.flir.com/products/flir-one-edge-pro/?vertical=condition%20monitoring&segment=solutions
« Last Edit: February 13, 2023, 09:48 AM by Cheese »
« Reply #20 on: February 12, 2023, 10:05 AM »
If the wall will be covered with cabinets another option is to drill a hole and insert a borescope and have a look around inside the cavity.
« Reply #21 on: February 12, 2023, 10:09 AM »
The Flir One Edge Pro will not be orphaned when future iPhones have USB-C ports rather than Lightning.
Online MikeGE
« Reply #22 on: February 12, 2023, 10:12 AM »
I use the Bosch D-tect 150 to identify the location of wiring, plumbing, and rebar in my concrete walls.  I tried the inexpensive stud finders, but they all failed miserably.
The D-tect 150 has been replaced with the D-Tect 200, but the changes are not worth upgrading for me.  The D-tect 150 and 200 use microwave technology (RADAR) to penetrate walls and alert when live conductors are detected, as well as a visual indication of the depth in wall.
« Reply #23 on: February 12, 2023, 11:03 AM »
Are all of these imagers FLIR or are there different types? I see some using "FLIR" and some not, in descriptions.
They are all Flir images, note the first photo I posted "HVAC leaks", in the upper LH corner you can just barely see the Flir logo.
One more thing to dig into is how large does the final image size become on the Klein?  With the original Flir Gen One, the resolution was around 5000 pixels (80 x 60) and that would be enlarged to a standard VGA 640 x 480 image.
The Klein has 10,000 pixel resolution while the new Flirs have 19,200 pixel resolution.
« Reply #24 on: February 12, 2023, 11:09 AM »
The D-TECT 200 seems to not be available in NA, and if it was, the price would be upwards of $750, near as I can tell.   [eek]
- Willy -
« Reply #25 on: February 12, 2023, 11:36 AM »
Highly sophisticated & reliable product for when rebar (or other stuff) absolutely must not be cut. Comparable to Hilti's PS 85 and the likes.
It allows you to understand depth, shape & material including even plastic piping & water filled plastic piping.
Miles ahead of any regular stud finder or even less sophisticated/reliable alternatives like the Bosch D-tect 120 -> https://www.bosch-professional.com/gb/en/products/d-tect-120-wallscanner-0601081370
Paid by for itself when it prevented a single hit. For example, I used a less sophisticated tool and it gave me the green light. Went ahead and drilled, hit an old-school lead-sheathed low-/ no-voltage telecommunication line. (Shouldn't have been there, not the slightest indication that it could be there.) But nothing special really - not even the repair. Repair costs still exceeded a little over 1000,-. Insurance covered it, but still. GMS-120 didn't find it. Would have most likely found it with the D-tect 120, with the "older" 150 or now the 200 for sure.
Kind regards,
Oliver
Kind regards,
Oliver
Offline tsmi243
« Reply #26 on: February 12, 2023, 11:58 AM »
Some guys call any thermal imager a "FLIR".  Like saying Channellocks or Skilsaw.  I don't think the core technology differs between brands, just the refresh rate, resolution, etc.
The actual sensor in some brands could be made by FLIR, that may be what you're seeing in the product listing.
Offline SRSemenza
« Reply #27 on: February 12, 2023, 12:37 PM »
Aah, it's brand name. Got it now.
Offline SRSemenza
« Reply #28 on: February 12, 2023, 12:47 PM »
The  D-TECT 200 is on Amazon for about $1,100.000 USD I can't find any good reviews that really show what it will see. Even earlier version reviews are sparse and most show them working on perfect fake walls.
In any case seems that for looking into a wall a scanner will be much more effective than thermal imager?
I realize they are different tools but I am just thinking of the extended use of the thermal imager.
« Reply #29 on: February 12, 2023, 01:59 PM »
It's too sophisticated for the average youtuber/influencer, they lack the experience with this type of tool to really convey what it will do/ not do. It's not a "magic trick" that suddenly allows the user to really look inside the wall, you need to interpret what the readings mean/ tell you, besides the over obvious warning when you're over a life circuit with it.
Filming actual use of such a tool, to make the audience really understand the product's capabilities, would require screen in screen times 3 and voice over. You need to see the display, movement on the wall and at best also the wall in "open state" with pipes/wire/rebar to see.
No clicks because it would be boring as heck to the general audience, no sparks, no dust, no ranking, no failing tools, (...). ;)
It would resemble professional training (that can be had from various manufacturers/distributors) and those youtuber/influencer don't have the audience for it nor the experience with the actual tool or use of it.
And the fun only starts with the Bosch.
Take a look at the 15k$ Leica Geosystems C-Thrue for example:
https://leica-geosystems.com/products/detection-systems/concrete-scanner-c-thrue
https://shop.leica-geosystems.com/buy/utility-detection/ids-c-thrue-concrete-scanner
Kind regards,
Oliver
Kind regards,
Oliver
Online MikeGE
« Reply #30 on: February 12, 2023, 03:44 PM »
To add onto what Oliver wrote, unless you are able to see one of the D-tect sensors in operation, it is difficult to explain or demonstrate in 90-second video.  The closest analogy I can think of is a SONAR fish finder used by fishermen on a boat.  The display will show a graphic return of something at a distance, except instead of water of varying temperatures, the medium is concrete, drywall, or any of the pre-programmed settings in the sensor, and the distances are in millimeters, not feet.
I've been using my D-tect 150 for over 11 years and trust it when the sensor detects rebar, water pipe, or electrical cables.  Prior to using it, my success rate with missing rebar was about 75-percent.  Now that I use it for every project that requires drilling into the wall or ceiling slabs, my success rate is 100-percent.  If I find rebar, but it is beyond the depth that I want to drill, I can drill in confidence that I will not hit it.
When I drilled the mounting holes for my clamp rack and tool boards, I scanned the wall vertically and horizontally to identify the location of the rebar grid in the areas I wanted to put anchors.  This allowed me to adjust my drilling location as needed and put enough bolts into the wall to handle the shear load.
At one of the facilities I supported before I retired, the maintenance personnel were drilling into a concrete wall to mount eight large screen displays for a video wall.  No one on the team bothered to scan the wall before drilling the dozens of holes for the brackets.  The facility manager had considering buying a D-tect 150, but hadn't been able to justify the expense, so they were relying on luck with every hole.  On the third monitor bracket, the technician hit an undocumented high-pressure water pipe that immediately started flooding the mission floor.
The pipe later turned out to be part of the abandoned fire suppression system that had been capped somewhere in the wall instead of being removed.  The sudden flow of water also triggered the fire alarm system, which caused everyone in the building to evacuate.  The resulting drama resembled a U-boat that had been hit while they scrambled around trying to find any valve that would shut off the high-pressure water.  The cost to repair the wall, and replace the damaged furniture, flooring, and equipment was over €30K, which was significantly less than the cost of the D-tect 150.  The facility manager now had the justification to buy a D-tect 150 for each team.
Offline PaulMarcel
    • Voilà, my blog
« Reply #31 on: February 12, 2023, 04:53 PM »
My images were from the first gen Flir for iPhone that @Cheese linked. I had an iPhone 6 when I first got it. I don't recall the price, but it was inexpensive enough to make it worth picking up and has been invaluable (and sobering...) to learn how poorly insulated and sealed my house is.
I'm definitely interested in a newer model that would use the iPhone for additional/on-site capabilities but is detached enough to not require the phone to take scans.
Funny, too, that you guys were talking about bad electrical circuits... yesterday, one circuit in my house was going full-on Poltergeist. Another breaker went bad. The original breakers in my house are 36 years old so I guess they are due.
Offline PaulMarcel
    • Voilà, my blog
Re: Temp gun vs Thermal Imager which one? Plus a little on wall scanners.
« Reply #32 on: February 13, 2023, 02:51 AM »
Well, since we were talking about "running a circuit to detect it via heat, but don't run a faulty circuit!"... my Poltergeist service panel heard and the main breaker died. I'm at a friend's house for the night or more given 200A breaker shipping estimates...
So here are some fun photos I took before "the event" and a photo of the service panel with a hot af main breaker. While the image scanner is cool to verify the breaker is hot, the blackened side was a bit of a give-away...
First up, a scan of a wall in the shop. You can see the drain from my shower running vertically. This was maybe 20 minutes after the shower:
354199-0
Next is a random shot into my gym. You can see the subwoofer bottom right, Sonos One top middle, and on the cabinet, the edge of a bucket of tea and the flat thing is an induction charger. Not useful for seeing into walls, but it is interesting that even some devices in standby glow:
354201-1
Lastly, my Poltergeist main breaker; again, not something you need a scan for but felt like a record:
354203-2
« Reply #33 on: February 13, 2023, 10:19 AM »
...Not useful for seeing into walls, but it is interesting that even some devices in standby glow:
That 2nd photo is exactly what I was referring to when I mentioned in an earlier post that the Flir's are very sensitive to temperature changes. Any small temperature differential is usually recorded.  [smile]
When I first purchased my Flir in 2015, I did a quick test and if I remember correctly (and that was a long time ago) it would recognize a temperature differential of only 1.5º to 2º.
Offline eschumac
« Reply #34 on: February 13, 2023, 11:14 PM »
I use a FLIR E4 weekly. There is a firmware hack out there to make it an E8. The internals are the same so the E4 was limited in the firmware only.
The thing can see residual footprints of someone walking a normal pace. Very sensitive.
So many off label uses for these things. Well worth the money and time to update the firmware.
Offline AofD
FLIR stands for Foward Looking InfraRed. FLIR the company, cleverly trademarked it as a brand name when they formed. FLIR is now the Kleenex of the thermal imaging industry. If money isn't an issue, I'd get a thermal imager with at least VGA (640 x 512 pixels) resolution. Here's an image of an unsuspecting wife [smile].
« Last Edit: March 18, 2023, 09:28 PM by AofD »
TS55REQ, CT26, MFT/3, OF1400, ETS150/3, KAPEX120, T18, Centrotec Installer Set, Domino 500, SysLite and RO90
Offline PaulMarcel
    • Voilà, my blog
Dude, she's hot  [big grin]
