Author Topic: Table Saw Purchase  (Read 5393 times)
Offline Route24Design
    • My Personal Blog
Table Saw Purchase
« on: January 11, 2019, 10:01 AM »
I picked up woodworking because of DIY home projects.  Projects consist of built in cabinets in bedroomI currently work with Festool TS 55, Domino 500, RTS and Pro 5 Sander, LR32 system, and some DIY parallel guides I made out of 80/20 material.  My MFT bench is a Kreg Universal Bench (64x28) with a top I made myself using the LR32 system and a 80/20 fence with flag stops.  Doing some cabinets for around the house, I noticed that my cuts are slightly off.  My first culprit are my man made parallel guides.  Thinking of splurging on a set of Seneca or Woodpecker.  My second culprit is my man made MFT top and rail attachments.
That being said, I'm thinking of either investing in 1 or 2 Festool MFT tables and Seneca or woodpecker parallel guides.  Or heading into the world of a Sawstop and getting a PCS 1.75 36" or Contractor 36".  I never had a table saw or used one for cabinet making so it will be a learning experience which is fine as I'm a DYI woodworker and hobbyist.  Question is, how much of the workflow from solely using a track saw to using a track saw and table saw will change?  Is the PCS too much saw for a combo track and table saw workflow?  I would hate to invest in another major tool and not utilize my track saw anymore.  My work space is in the basement of my home.  I have about a 20' x 14' area that I work in.  Have laundry and gym area sharing the basement workspace.
Looking for feedback from experience woodworkers that have this setup or have gone this route and switched to one or the other.
Thanks in advance
Festool TS 55 REQ-F-PLUS
Festool OF 1400 EQ-F-PLUS
Festool CT MIDI HEPA
Festool CT Sys HEPA
Festool Domino DF 500 Q-PLUS
Festool PRO 5 LTD (ETS 125 REQ)
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Festool FS 1400/2 (x2)
Festool FS 1400/2-LR 32 Guide Rail
Festool LR32 Router Hole Drilling Set
Offline RKA
Re: Table Saw Purchase
« Reply #1 on: January 11, 2019, 10:41 AM »
You'll get answers all over the map and it will come down to your preferences in how you want to organize that shop space and what tradeoffs you're willing to make.
A quality table saw has many uses beyond the sheet good cutting capability you're currently struggling with.  If you intend to make this a hobby, you'll find it valuable, and no, a PCS isn't too much saw to supplement a track saw.  But, the footprint required for a table saw including space for infeed and outfeed support and a dust collector can be substantial.  You have a good amount of space to work with, however most of that space can't be shared.  You'll also need at least a multi function bench that can be used for assembly, clamping, perhaps a little hand tool work, and of course work with handheld power tools.  And then you need storage space for tools and accessories.  I would work on your shop layout and see if a table saw fits into the picture.
The track saw is still a good supplement to the table saw when dealing with full sized sheets of plywood.  At least for initial break down and even for final sizing on panels too large to crosscut on your table saw.  I think you'll be hard pressed to find people that gave up their track saw after acquiring a table saw, so I wouldn't worry about that.  But you'll also find people that only use a table saw and don't want the extra expense of a track saw.  Track saws are relatively new, gaining popularity in the last 10 years, while table saws have been the mainstay in hobbiest wood shops for decades.
Accessories for the track saw will depend on which way you go with the table saw.  Parallel guides might not be needed if you're using the table saw for rips.  But an MFT or DIY MFT style bench could still be helpful for the crosscuts with appropriate accessories to keep the work piece perpendicular to the rail and saw.  If you want to use the track saw for everything, obviously the accessories are out there to support it.  And those things it can't do can be backfilled with other tools like a router which will fill in the gap between the table saw and track saw.  In my view it's less efficient in terms of workflow, but sometimes the space savings gained is worth it.  That's a common theme and trade off in woodworking.
-Raj
Offline Sanderxpander
« Reply #2 on: January 11, 2019, 01:19 PM »
I don't have a perfect solution for perfect repeatability either, I don't have a table saw or parallel guides. But I do get perfect squares and near perfect repeatability on things like shelves using careful marking and the TSO Guide Rail square. I heartily recommend this accessory.
    • My Personal Blog
« Reply #3 on: January 11, 2019, 01:22 PM »
I have the TSO guide rail.  I usually take 5mm off the edge, then add the guideraile and go around the board making my cuts to dimensions needed.  Either my technique is wrong, which it very well can be, or something is off on my track rails.  Either way I'm having a hard time deciding to invest more in the track saw only route or get a table saw and learn that tool and utilize the fence on that.
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline jonnyrocket
« Reply #4 on: January 11, 2019, 03:24 PM »
As mentioned, you will get responses across the board on this question, so I'll add mine to those you have gotten already.
Perfect or near perfect squares can be obtained with what basics you have. Before adding another tool to the mix, I would focus on determining what part of your current flow is introducing the error.
If you add the table saw before you fix your current flow, you may not get any better results than you are now. If needed, document your procedure in pictures and post it here. I'm sure that the collective genius here on the FOG can help narrow down where your issues may be lurking.
    • My Personal Blog
« Reply #5 on: January 11, 2019, 03:38 PM »
Very true.  I just came back from buying new splinter guards.  Changing the splinter guard on all my rails.  Also looking to see what parallel guides to get.  I think my DIY ones are introducing some error as well.
Although I don't have pictures now, my procedure that I follow is:
1- Cut 5mm off the factory edge
2- Using the newly fresh edge, measure off my finish dimension and do my rip cut.
3- with the ripped parallel edges, add the GRS or use my MFT Kreg bench and cut 5 mm off the crosscut edge.  Referencing the 1st rip cut edge off the bench fence (80/20 extrusion), I set my flag stop to dimension and cross cut
« Last Edit: January 11, 2019, 03:41 PM by WoodworkTech »
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline RKA
« Reply #6 on: January 11, 2019, 04:41 PM »
How is #2 being accomplished?  (the parallel cut)
Get that part right, then you can work out any errors on the cross cuts.  The TSO is very accurate, but it's easy to skew it when you're trying to align the rail to a mark.
-Raj
    • My Personal Blog
« Reply #7 on: January 11, 2019, 04:43 PM »
I used my DIY parallel guides off the 1st 5mm cut.  I would measure the dimension, set parallel guides using woodpecker rule and stop, clamp rail down and cut
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline neilc
« Reply #8 on: January 11, 2019, 05:00 PM »
I use two single edge razor blades like you use for scraping a window.  Measure from a square edge, place a razor blade corner pressed in at that index mark on both ends of the piece.  Slide the guide rail up against those two blade marked points.  Optionally clamp down the rail.  Remove the razor blades and make the cut.
It's the most accurate and least expensive way I have found if you don't want to mess with the various options for parallel guides.
    • My Personal Blog
« Reply #9 on: January 11, 2019, 05:01 PM »
Good tip.  I’ll give that a try.
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline ctvader
« Reply #10 on: January 11, 2019, 05:39 PM »
I was in a similar position to you not that long ago.  I had/have a dw 744 job site saw that, IMO, is scary to use for the work I do.  Knowing my fingers are extremely important to me, I upgraded the saw to a SS contractor saw with the mobile base.  I work out of a two car garage, which we use to park our cars.  With some reorg, I was able to fit the table saw into a corner of the garage and wheel it when I use it.  Works just fine.
I own a TS55 along with the TSO guide and it's an amazing combination - it's what I use for large panels with great precision.  As mentioned above, you need to decide what you do and what you make.  If i'm building a cabinet or bookcase, you can't beat the TS55 with the TSO guide.  If you're making small, repeatable cuts (cutting boards, etc), the table saw will be faster and more efficient (Note - I didn't say better).  I hope this helps.
    • My Personal Blog
« Reply #11 on: January 11, 2019, 06:08 PM »
Thanks.  I mostly do cabinets right now.  Looking to do picture frames and other things.  Smallest cuts right now are edge banding cuts to cover plywood edges
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline RobBob
« Reply #12 on: January 11, 2019, 07:40 PM »
I also have a two car garage based shop and with great results use a Festool track saw plus TSO guide rail complemented by a jobsite saw.  I don't feel limited at all and the accuracy is on the money.
P.S.  I have the Seneca parallel guides, but my advice is to buy the jobsite saw first, then decide if you also need the parallel guides.
« Last Edit: January 11, 2019, 07:58 PM by RobBob »
Offline jobsworth
  • Festool Baby.....
« Reply #13 on: January 11, 2019, 07:58 PM »
IMO the only reason you would need a TS for cabinet work and the only reason I own a table saw is for thin rip cuts.
With that being said, If you are making face frame cabinets then you ca make a jig to cut the face frames.
Offline TealaG
« Reply #14 on: January 11, 2019, 09:07 PM »
I own a table saw but for the longest time, I used my track saw because I felt safer (and frankly, I still do).   But I have great difficulty with wood narrower than the track, despite using a narrow parallel guide - the wood always pulls away from the guides  :(    Besides the narrow cuts, there are  some cuts that aren't conducive to using a track saw (think cutting a tenon or a dado).
So I finally got my table saw set up, learned to use it and got an incra fence system.  I am making several small parts cabinets and hardboard dividers - lots of pieces of the same dimensions.   I must admit that using a table saw was much faster and more accurate than my track saw (partially because the pieces are narrower than the track).  However, I was surprised by the fact that I was still using my track saw to break down the large pieces of plywood because I don't want to manage a large piece of wood with the table saw spinning.
I know that there are folks who live without a circular or track saw and just a table saw.   But to me, you need either a circular or track saw, even if you have a table saw because I'm not brave like John Heisz - man handling (literally) a 4x8 sheet of plywood, alone!
I'm glad I learned to use my table saw because I can do some things I couldn't do with my track saw.   But I do realize that my track saw isn't going away either.   :)
    • My Personal Blog
« Reply #15 on: January 11, 2019, 09:09 PM »
Thank you.  Interesting to hear that even with parallel guides that are setup for narrow cuts, the wood will still move.  What table saw do you use?
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline TealaG
« Reply #16 on: January 11, 2019, 10:19 PM »
Hi...I have a Bosch 4100 but I added the Incra Table saw fence and attached the router table to the left side.   Honestly, I only did this over Christmas and have only used it since then.  The parallel guides are great for cuts greater than the width of the track and I can get fairly accurate and repeatable cuts that way.  I sometimes just mark the wood on the cutline then use the TSO guide to square the track and I find that to be accurate enough (is it "precision"? No...because despite a thin pencil etc, I am inaccurate, but the cut is fairly square).
For cuts wider than the track where the uncut piece of wood is 2.5' wide, I can get equal accuracy with both the table saw and track saw, but it's faster on the table saw.   Less than track width, faster and more accurate on the table saw.  Larger than 2.5' wide and I'm cutting that sucker down with a track saw.    Note that my car cannot accept wood greater than 36" wide x 50" so I always get the wood cut at the store, which again reduces the size of wood I manage in the base case.   Nothing I build has a single piece of wood larger than 36x50.
Offline Alanbach
« Reply #17 on: January 12, 2019, 12:30 AM »
First a disclaimer. I suppose that I am a bit biased because I used a table saw for 20 or 30 years before track saws ever hit the US market. So I have a lot of habits that are well ingrained into me. Having said that I upgraded my Unisaw to a Sawstop 3HP PCS about a year ago and also picked up a TS55 shortly after that. I use the TS55 to break down big sheets with ease and safety. However, when it comes to repeatability I use the table saw. If I am building a bunch of cabinets that need 23 1/4” sides I am going slice the sheet down the middle with the track saw and then use the track saw to break down those halves so that they are fat to final dimensions. After that I am going to let the table saw do what it is great at, repeatability. Set the fence to 23 1/4”, Check it twice with your tape and then make a test nick in the first piece. Once you have done that well away you go, and in minutes you have a bunch of pieces that are exactly the same width. Sure the table saw requires that the saw and fence are set up properly and there certainly are techniques that need to be mastered but all in all, IMO, it is a machine made for repeatability and it is good at it. I am sure that there are many here that will argue that accurate repeatability can be achieved with a track saw. I don’t doubt that, however, I read posts almost every week of people struggling to get accurate repeatability out of their track saw. Obviously it is a journey.
The way I look at if you want to make things with tolerances of 1/32nd or 1/64th you need reliable repeatability. I just think that if that is what you need you will find the table saw path a bit smoother. Having said that if that is the road you want to travel and that is the kind of accuracy you want to achieve then make sure you buy a high quality saw but most importantly a saw that is paired with a premium fence. IMO most jobsite saws do not have top notch fences systems. I love my PCS but I would not own their lesser fence, I would only own the T Glide fence. I hope this helps.
Offline Vondawg
« Reply #18 on: January 12, 2019, 07:29 AM »
@Alanbach - Real world perfectly stated !....right tool for the right job
    • My Personal Blog
« Reply #19 on: January 12, 2019, 08:01 AM »
Thanks for that response.  You mentioned you use a 3HP saw.  Do you fell the 1.75HP with T-glide fence is good enough for cabinet making and picture frame projects, etc?  I’m considering the sawstop PCS or Contractor saw 1.75 with T-Glide
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline Steve1
« Reply #20 on: January 12, 2019, 08:55 AM »
I am just a hobby woodworker (possibly similar to you).    I got my table saw (Ridgid R4512) maybe 6 years ago, and find it very useful.  I made a bunch of cabinets recently and found it very useful.  If you want two sides of a cabinet same size, there is nothing better than setting the fence and running first one board, then the other through it.   Having a fence that is repeatably parallel to the saw blade is critical.     Table saw does take of a whole lota floorspace, that's for sure.   But retract the blade and it serves as a nice bench.
Offline Alanbach
« Reply #21 on: January 12, 2019, 09:50 AM »
@WoodworkTech - So in my opinion the question around 1.75 vs. 3HP comes down to the work you do. The 1.75 will serve you well for 3/4” plywood and 3/4” hardwoods. The issues comes into play when you start to break down 1 1/2” - 2” hardwoods or thicker. So if you think that you will work 99.9% of the time with thicknesses under and inch you can go with the 1.75hp. Just know that if want to cut down some table legs (for example) out of some 10/4 maple your saw is going to struggle. You might still be able to do it (by slowing down your feed rate and installing a thin kerf rip blade) but you will definitely know that you are pushing your saw hard. The big reason that people pick the smaller motor is so they won’t have to rewire their shop for 220v. The 3hp will require a 220 circuit.
Offline JimH2
« Reply #22 on: January 12, 2019, 10:06 AM »
A table saw is the foundation of any shop. Don't second guess yourself...get the 3HP PCS and you will never second guess your purchase. As @Alanbach posted I had a Unisaw for about 15 years before I bought the PCS. I was one of the very early PCS customers as I was offered to try it for free in exchange for feedback. I chose to keep the saw and paid a discounted rate to keep. Mine and others feedback lead to changes to the final production model and when the production model shipped I was shipped a kit with the parts necessary to make my saw like those being sold. They also sent a new blade with the kit. Some on FOG slander the founder of SawStop, but pay not attention to the noise. The saw is top notch and provides a level of safety that would never exist had SawStop not been formed. I never missed my Unisaw after I sold it.
You are on the right track about a track saw. They are great for some things, better for others and very convenient, but they cannot touch a table saw in terms of accuracy and repeatability unless you have extra time to futz with the rail to get it perfect. To be clear I have a track saw and use it very often, especially for breaking down sheet goods and making cabinets on-site. I also have a portable table saw I carry with me if repeatability and precision are needed. If you are eyeing up a portable table saw the Saw Stop is great, but if you are not willing to spend that much consider the DeWalt or Milwaukee with geared fences. I have the DeWalt and the fence is the differentiator between it and other portable table saws. The Milwaukee looks to be identical with the same fence.
Offline Alanbach
« Reply #23 on: January 12, 2019, 10:18 AM »
@WoodworkTech - one more thing! If you decide to move forward with a SS PCS and if you can afford it, you should definitely buy the better mobile base (industrial). It is fantastic and should make managing the saw in your smaller shop much easier. It is a big heavy saw but on that base I can move mine around easily with a couple of fingers. I know that between the 36” t glide, the industrial base and possibly the 3hp motor that we are taking about quite a bit more money but at that point you will have a saw that your grandchildren might still be using long after you are gone😊.
Offline mark60
« Reply #24 on: January 12, 2019, 10:23 AM »
If my track saw broke today I'd order a new one today and the same with my Sawstop. I'm just a hobbyist but bought a 3HP PCS two years ago and it's a pleasure to use. I might have been able to sneak by with the smaller motor but knew the bigger motor would never be too big and the enclosed cabinet keeps things much cleaner. Keep in mind that the mobile base makes it tuck out of the way when not needed.
Offline Peter Halle
« Reply #25 on: January 12, 2019, 11:09 AM »
Often here ther is the debate or question of can you do without a tablesaw if you have a track saw.
The real answer in my mind is that with all work there will be times when bringing a tool to the work is better and then when bringing work to the tool.
Are they grey areas? Sure.  But I would offer that if you have the space a tablesaw is a tool to have in your arsenal so to speak.
Offline DeformedTree
« Reply #26 on: January 12, 2019, 12:16 PM »
I think this gets into the question of if we officially got CMS TS inserts in North America how this discussion would change.  I have a table saw, a small one, it's not very good.  I intend to get a CMS for router,  thus getting TS module(s) makes sense.
Having a track saw now, it's absolutely wonderful verses trying to move full sheets of plywood thru a saw by yourself, or even trying to use a straight edge and circular saw.   That said, clearly when things get skinny, a table saw is needed.   Like you say, if you have space, and say space for a big table saw and out feed tables, then great, but for those without permanent setups or a lot of space.  I think the likes of a CMS setup start to look very good.  For the couple skinny cuts, have the option with a bit of setup, away you go.  I think I will probably get a TS 75 and module,  give me the tool for thick stuff on rail and table saw as needed.  General track stuff use the TS 55.   This isn't exactly the cheapest path, but it does mean I don't have a table saw just taking up space most the time.
    • My Personal Blog
« Reply #27 on: January 12, 2019, 12:53 PM »
A lot of good insight from responses.  Appreciate it.  Anyone have experience  with the Contractor vs PCS sawstop and noise level differences?  Contractor much louder since motor is exposed?  Also, the sawstop slider a good option for future upgrade or having the table saw and MFT style bench eliminate the need for slider?
Festool CT Sys HEPA
Festool ETS EC 125
Festool Rotex 125
Festool RTS
Offline Alanbach
« Reply #28 on: January 12, 2019, 01:12 PM »
I can’t speak to the noise level difference but I can tell you that the dust collection on a PCS is much better than a Contractors. The slider is an intriguing option but it sure expands the footprint of the saw making it a no go for me. Since I already have a TS55 for breaking down large sheet goods I would probably invest in a Kapex or other good SCMS before I got the Sawstop slider. But yes, it is a great option!
Offline Paul G
« Reply #29 on: January 12, 2019, 01:18 PM »
Since the laundry and gym are in the same space I would be far more concerned with dust control instead of noise. Ear protection is easy, cleaning up dust from everything is less so.
+1
