Ok good we're getting somewhere.
1) No ifs ands or butts, plywood is a bitch on endmills; especially baltic. Keep extra bits on hand as you will consume them. Also why I like the cheaper ones. You have multiple layers of veneer laminated in opposing directions so you are always cutting against and with grain at all times.
2) NEVER! I typically use 5 and slow how fast I push the machine whether human or on auto/auto-lock. If you watch any of the Shaper Sessions you will see those guys roll with 4-5.
3) Good. Still a good idea to follow the Origin Mantra (what I call it)... Many shallower passes with .02-.03 offset to final depth. Then do full depth passes removing offset to final fit or dimension to clean up edges (and any burns).
4) Default is 10ips. This only applies when you hit auto button in corners or if you are in auto-lock (I use a lot now). If you, the human, are the feed speed, be mindful to not try to fly faster than the cut can keep up. Good recipe for burning/dulling there too.
5) This is a clear indicator speed is too fast and/or bit is dull. Get a couple new bits, drop speed and try again.
6) I don't clean em often but it really helps. A shallow dish, squirt some CMT 2050 in, get bit coated and let is sit for a little while, then scrub with a little stainless or brass brush. It helps get pitch, sap, and adhesive off of the bits and they run cooler and last longer.
7) Good choice, I have the same cranked up to full speed. If in shop I will connect to a drop to my dust collector. Some of the users have modded the shroud trying to improve dust extraction. I think it works ok, just make sure to vacuum out excess chips in between passes. I use the 4mm hex wrench followed by vac to clear the deep channels. Leaving junk in the grooves will also prematurely wear bits.
Even if you are not a traditional machinist, there is solid logic to follow here. When a metal machinist is milling a big block of aluminum or steel, they have a nozzle that floods the part and tool with coolant. It helps lubricate the cut and keeps it cool. Your dust extractor works similarly. If you allow it clear path to cut, it will provide cool airflow to the tool that will improve cuts, reduce burning, and give some longevity to your bits. Goes without saying, if you plunk down big money on fancy bits, you really need to pay attention to their care. That is, unless you are rich.
![Big Grin [big grin]](https://www.festoolownersgroup.com/Smileys/default/biggrin.gif)
