Author Topic: Sanding Paper tray  (Read 2396 times)
Offline GreenGA
  • JR
Sanding Paper tray
« on: March 20, 2008, 02:42 PM »
If this has already been posted before, please ignore.
For some reason I clicked to the Rockler site this morning and stumbled across this.  It looks like a perfect first, or second, project for us newbies. (the case, not the storage discs).  I know I could use it for all the sanding paper Uncle Bob sold me...
http://www.rockler.com/product.cfm?page=17886&ref_id=5025&ref_t=Z&originid=69389396
Never use a 2x4, when a 2x6 will do just as well.
SYS-Lites, CMS/GE, TS55, KAPEX, MFT/3, CXS Kit, C15 Set, C12 Set, T18 Set, Ti15 Set, CT48 w/Boom Arm, Carvex PSBC, HL850, HL65L, RO90, RTS400, DTS400, LS130, DX93, RO150, ETS 150/3, RAS 115/4E, RS2E, Domino 500 & 700 Sets, MFK700 Set, OF1010 EQ, OF1400, OF2000E+, MFS700, FS3000/2, LR 32-SYS+97" rail, 2011 Centrotec Set, Metric and Imperial Zobo Forstner Bit Set, VS600 Dovetail System, Guide Rail Kit, Parallel Guides, Tradesman Cleaning Set, Shinex, lotsa 'tainers (Sys, Sorts, Minis, Midis, Maxis. Attics, Classic, New and Blue).
Coming Attractions: Workcenter, NAINA when available.
Online SRSemenza
Re: Sanding Paper tray
« Reply #1 on: March 21, 2008, 12:37 AM »
    I had something similar that I used with my previous sander.  A piece of plywood about 24" long with dowels sticking up (about an inch tall) in the appropriate pattern for three stacks of disks.  Though the sander was six holes I just put three dowels in.  The dowels were  dowelling dowels ( for joining) the tapered ends made it easy to slip the sander and disks on.  It worked OK.  It had two problems  the disks didn't want to stay flat and tended to pop off the dowels do to curling. I fixed this by putting another piece of plywood (drilled to match) on top when not in use.  The second problem was that often, just do to a little cling, more than one disk wouold get picked up. Neither was a big deal though. The rack idea looks cool.
Set
