Author Topic: Ruler clamps for Festool guide rail  (Read 3225 times)
Offline JaapAap
« on: March 26, 2017, 12:27 PM »
Hello,
I'm from Europe and wandet to by the woodpeckers precision woodworking Story Stick Pro. Unfortunately this is not yet available in Europe for a normal price. So I decided to make it myself with 3d Printing. Here you can find the result.
https://www.shapeways.com/product/L3FQ3V5U2/festool-ruler-clamps-for-guide-rail?optionId=62299838
I like to know what you think of my solution.
Joli
Offline DrD
  • I might not be fast BUT I sure am slow
Re: Ruler clamps for Festool guide rail
« Reply #1 on: March 26, 2017, 12:52 PM »
@JaapAap
First welcome to the FOG.
I viewed you stops and they really look nice.  Are you offering them as an alternative to the Festool p/n 495 542, Adjustable Stops used on the MFT fence?  Do they come with the knob shown on the web site?
KS12 EB Kapex with Delta Folding Table & FastCap Best Fence; TS75 EQ with Parallel Guide Rail Set (FS-PA 495717 & FS-PA-VL 495718) and FS 800/2, 1080/2, 1400/2 LR32, 1400/2, 1900/2 Guide Rails, and Betterly SLC23 Straight Line Connector; DF500 Q with Assortment Systainer; OF1010 EQ with Fine Adjuster for Guide Stop, WA-OF Angle Arm, UP-OF Edging Plate and SF-OF Chip Deflector (486242); OF1400 EQ with OF1400 Dust Hood x 2, OF 1400  Edge Guide x 2, OF 1400  Guide Stop; LR32 Set; PSB399 EQ; EHL65 E; RAS115.04 E; RS2 E; ETS150/3 EQ; RO150 FEQ; Hand Sanding Block Set; CT26 with assortment of AS and Non-AS Hoses; MFT/3 Table x2; SysLite; Assortment of Quick & Screw Clamps, Consumables, Dogs.
Offline JaapAap
« Reply #2 on: March 26, 2017, 03:10 PM »
@DrD
They are meant to use as a precise repeatable measurement tool( just like the story stick pro http://www.woodpeck.com/sspro96.html). So you can set the clamps on the right distance and sign your line. In the middle of the clamp, I add a 1 mm gap in where you can sign. This helps you to work faster while keeping your work precise. At the other end, you can find a small 0.5 mm tip that can help you to set the right measurement. The tip is lifted with one mm so you can put your ruler underneath (see picture). The clams are coming without the knob. Unfortunately, the clamps will be too expensive when I design a 3d printed knob on it :)
Offline ben_r_
« Reply #3 on: March 26, 2017, 08:26 PM »
Oh I see. So these are to use a guide rail as a story stick? Neat idea. Think Id rather they were CNCd out of aluminum, but this is nice and less expensive.
Offline JaapAap
« Reply #4 on: March 28, 2017, 02:48 PM »
Yes exactly. That is indeed a better explanation :). Unfortunately no CNC in my barn yet. But I made them available in steel as well. Still a bit expensive. When there is more interest, I could try to use less material so they can become cheaper. anyone interested?
https://www.shapeways.com/product/edit/L3FQ3V5U2
« Last Edit: March 28, 2017, 02:51 PM by JaapAap »
Offline JaapAap
« Reply #5 on: May 09, 2017, 10:27 AM »
Hi All,
I tested the ruler clamps for my self-build kitchen. I made some small improvements so you can now work with a very high precision. I have to say that I'm impressed that such a simple add on can help me to save a lot of time and mistakes. I make now a package of 2 so it is more affordable to try out. Also, I add some different colours that can help you when you try to differentiate to set over left or right aligned measurements.
I have seen there where some purchases already. I would like to hear your feedback too improve.
Offline NL-mikkla
  • www.m144h.com
« Reply #6 on: May 09, 2017, 10:48 AM »
They look very good, unclear to me how much there are in the box when purchased?
Offline JaapAap
« Reply #7 on: May 09, 2017, 10:52 AM »
Hi
Currently, there are two items in the box. I will write it down in the shop.
Thanks for the feedback.
