Author Topic: Roof rack system for carrying Plywood  (Read 7577 times)
Offline krudawg
« on: May 04, 2022, 08:20 PM »
I've got a new Toyota Highlander with roof rack.  I'm not too sure about putting a couple sheets of plywood on it.  I've been looking a Yakima for something I can add to make carrying wood, Plywood and other lumber. safer/easier  Anybody using a Yakima rack for carrying wood who would like to point me in the right direction.
Ted
MFT/3, DF 500, Hammer K3 Winner, TS55,  Sjoberg Elite 1500 Workbench, Fuji MiniMite4 Platinum, OF1400, CT MIdi, CT26, RO90, ETC-150, OF1010 EQ-F
Former Marine, Vietnam Vet
Offline 4nthony
    • Slack for Recon Tools
Re: Roof rack system for carrying Plywood
« Reply #1 on: May 05, 2022, 12:20 AM »
Both Yakima and Thule sell cross bars that are wider than 48". If you can find the correct feet or clamp for your Highlander, then it'll work. The clamps will be different depending on if you have factory installed side rails or a bare roof. Also be aware of the weight limits for the specific clamps.
I used to have a Tacoma with a Leer shell that had rack tracks preinstalled on the roof. I had 60" Thule cross bars and I was comfortable strapping 3-4 sheets of plywood to the racks. I think the weight limit was somewhere in the 150 pound range.
I no longer have the Tacoma and now drive a wagon with factory racks. They work but I don't trust a full-width sheet up there. I think they're only about 36-40" wide. Now when I buy plywood, I have the yard cut the plywood down to around 24 - 30 inches wide so the boards fit within the clamps.
Recon Tool Notifications
Anthony
Offline Mr_Mod
« Reply #2 on: May 05, 2022, 06:29 AM »
Try Rhino rack, their platform system is darn good
https://www.rhinorack.com/en-us/
Offline pixelated
« Reply #3 on: May 05, 2022, 10:53 AM »
Dan Pattison has a good video on simple roof rack mod for carrying plywood.
I made one for our previous wagon, and I can confirm that it works well, and it's much easier than strapping 3 or four sides of the plywood to make sure it says in place. It also makes it easier to load.
When I'm going to carry sheet goods, I usually buy a few 2x4's as well to go on top so that the straps add better vertical pressure on the plywood.
Offline cpw
« Reply #4 on: May 05, 2022, 05:28 PM »
When I had a Mazda3 with a Thule rack or a Pilot with the regular manufacturer rack, at least 3/4" sheets were rigid enough that I could just put a couple on top of the cross bars, and then use one ratchet strap in front and one in back, looped around each side of the cross bar and it was pretty solid.
Offline Richard/RMW
« Reply #5 on: May 06, 2022, 08:41 AM »
I've carried plywood this way more than once, usually on stock SUV roof racks. Be aware that there is a massive amount of force (lift) if you are running along at highway speeds, trying to rip the material off. Use quality ratchet straps or 1/2" rope and know your truckers knot.
And never follow someone else hauling this way...
RMW
Offline SRSemenza
« Reply #6 on: May 06, 2022, 11:26 AM »
RMW
  You mean I can't just hold it on with my hand out the window and a buddy doing the same on the passenger side?   [huh]
       I actually saw this happen at a HD years ago. They got as far as making the turn from the parking lot row onto the main parking lot drive. I think they managed to hit maybe 10mph. At least they lost it in the parking lot.  [blink]
   Almost got two sheets of drywall on my windshield one time. Truck with cap in front of me at a traffic light. Must have just left a worksite. I noticed the sheets seemed to be moving around a bit while stopped at the light. I don't think it was tied down at all. They probably forgot but ........................... Truck hits the gas when the light turned green, I didn't. Drywall cartwheeled into the air and smashed on the pavement right in front of my car.
Offline Packard
« Reply #7 on: May 06, 2022, 11:38 AM »
Swimming pool noodles sliced open lengthwise will protect the plywood from damage.  Simply snap it onto the crossbars and then load the lumber.
You want to find the hollow ones.  Walmart and Homedepot sell them for about $4.00 to $6.00 each.  With a sharp kitchen carving knife it slices like butter.  I tried with a utility knife, but the blade was not long enough.
Offline Sparktrician
« Reply #8 on: May 06, 2022, 03:40 PM »
Go slow. 30MPH (tops) slow. Strap as if your child was sitting on it. Stop gradually.
One sheet is about 100 pounds. Most roofs can handle 100-200 pounds. So about 2 sheets is max. That is not much.
All things considered, it is MUCH, MUCH better to just get or rent a trailer. Or cut to size at the yard so it fits in the trunk.
If I'm hauling sheet goods, regardless of weight, they go inside my '15 Expedition EL with the back door solidly closed, and ratchet-strapped to the underpinnings of the second row seats that have been folded down.  Lumber up to 10' can go inside in low quantities.  Longer materials (trim, lumber up to 16', plumbing, conduit) all go on the Yakima JetStream bars on top of the Expedition.  That said, all will be shrink-wrapped at the front end with a short length of duct tape securing the shrink wrap to avoid wind separation and destruction of the materials, especially trim.  I watched some bozo totally destroy a load of shoe molding because he didn't tie the front ends together to resist the wind.  I also watched another clown spread a load of sheetrock on the highway because he apparently didn't strap it down inside a shorter-length Expedition, and didn't tie down the back door.
- Willy -
Offline Bob D.
  • Inactive Member
    • My Cordless Workshop
« Reply #9 on: May 06, 2022, 04:23 PM »
Both HD and Lowes have pretty good deals on renting their trucks for a couple hours.
Just because you rent the truck from one of them doesn't mean you have to haul anything from their store home.
HD is $19 for the first 75 minutes as an example.
Lowes is $19 for 90 minutes and another $5 for every 15 minutes over 90.
Is it worth $20 not to lose a load or damage your car?
U-Haul too of course is an option.
Offline Packard
« Reply #10 on: May 06, 2022, 04:29 PM »
Two things watch for when transporting sheet goods on the roof top are:
1.  Air lift.  Air gets under the front of the plywood and the lifting pressure can be immense.
2.  Hard stop inertia.  A hard stop will toss the sheet goods forward will gusto.  A sheet of plywood 3/4” x 4’ x 8’ weighs about 60 pounds; pressure treated, about 90 pounds.  A hard stop and the sheet can fly off and decapitate someone.
Offline Bob D.
  • Inactive Member
« Reply #11 on: May 06, 2022, 05:45 PM »
" A hard stop and the sheet can fly off and decapitate someone."
They can fly out of a p/u truck bed too, as has happened more than once.
So tie-downs are needed there too if your bed is not covered.
Offline krudawg
« Reply #12 on: May 08, 2022, 12:31 PM »
Good Point.  Does anybody make a roof rack with an air deflector on the front - that would eliminate  "air lift hazard"
Ted
Offline 4nthony
« Reply #13 on: May 08, 2022, 12:36 PM »
AFAIK, most fairings designed for roof racks are meant to quiet air noise.
Anthony
Offline Packard
« Reply #14 on: May 09, 2022, 08:17 AM »
I think you can make a clamp-on piece of hardboard to eliminate the gap under the plywood and thus eliminate the uplift hazard.  I never tried to do so, but it seems doable.
Offline Mini Me
« Reply #15 on: May 09, 2022, 09:34 AM »
Use some strong G clamps instead of straps and the ply won't be going anywhere. Strapping as shown in the video is next to useless as the straps need to be run over the top of the ply, back under the ply then over the top again and then tensioned. It is called belly roping in my neck of the woods, others my have other names for it.
Offline pixelated
« Reply #16 on: May 09, 2022, 09:42 AM »
Most of my roof-rack plywood hauling was done on fairing equipped racks. The fairing reduces the wind noise quite a lot whether you're hauling something or not, so, I find it a worthwhile addition.
That said, my current cars use the newer "aero" cross bar racks, and don't use the fairings.
I've not had a problem with uplift, glass sunroofs are great to help monitor the load while in transit  [smile]
Offline Packard
« Reply #17 on: May 09, 2022, 09:55 AM »
I have never trusted roof rack mountings after seeing a roof top rack actually get torn from  the roof of a car.
I use straps and I have always run the straps over the load and into the passenger compartment by running through with the doors closed.
My Chrysler Pacifica comes with a convertible roof rack that be moved into place when required.  I have had no reason to use it and I don't know how to make the switch.
I just found this video and it looks pretty simple.  I don't know its capacity though.
Offline SRSemenza
« Reply #18 on: May 09, 2022, 10:05 AM »
Stow in place cross bars. That's a cool feature.
Offline Packard
« Reply #19 on: May 09, 2022, 10:22 AM »
I just looked at the owners' manual.  The maximum weight on the crossbars of the Chrysler Pacifica's stow in place crossbars is 150 pounds distributed evenly over the rack.
« Reply #20 on: May 09, 2022, 01:06 PM »
Subaru has had a similar system for over a decade, but it, too, is weight-limited.
- Willy -
Offline squall_line
« Reply #21 on: May 09, 2022, 03:34 PM »
Note the sensible oxford and khakis used when making the installation.  [big grin]
And my favorite trope of all automotive instructions: "removal is reverse of installation".
Offline Packard
« Reply #22 on: May 09, 2022, 03:50 PM »
I am a member of the Chrysler Pacifica Website.  And other than the fact that the speedometer will spontaneously shift from mph to kph, mine has been flawless.  (Switching back is easy.)
Others have not been as lucky.  But I will say that many of the features (like the stow n' go rear seats) are well-thought-out.  The ride and handling are exceptional for a mini-van and quite comparable to a well-sorted out sedan.  It is also quiet at cruising speeds, offers good acceleration, and has seats that are comfortable for long trips.
I have yet to need new brake linings even though I just clocked 102,000 miles.  (I don't understand it either.)
But others have had engine problems and transmission problems.  Enough have complained that is clearly is not an isolated incident.
When people ask me about it I say, "It's the best car I have had in recent years, but I cannot recommend it because of all the reported issues."
Offline VonaseBegum
« Reply #23 on: February 23, 2023, 07:34 AM »
Hi there! Well, Yakima is a reputable brand in the outdoor gear and car rack industry. I've never used it, but the reviews seem great! Before using any roof rack or accessory to transport lumber, I suggest you to make sure that the weight of the load is within the weight limit. Besides, make sure that the load is securely tied down and properly balanced. Overloading your roof rack or improperly securing your load can pose a serious safety hazard. So it's important to take the necessary precautions and follow the manufacturer's instructions carefully. If you feel you can't handle it, contact reliable specialists, such as those from Indianapolis roof contractor. Hope I helped!
« Last Edit: February 26, 2023, 12:08 PM by VonaseBegum »
Offline krudawg
« Reply #24 on: February 24, 2023, 11:30 PM »
Don't forget to calculate the effects of INDUCED DRAG as your speed increeases and the possible adverse effects of Parasitic drag  [eek]
Ted
Offline Mark37
« Reply #25 on: March 08, 2023, 12:35 AM »
Years ago, I experienced having a sheet of MDF fly forward off my roof rack when I had to stop a little short. It sailed right over the hood and narrowly missed some people in the cross walk.  Not good.  That image is etched in my brain.
2 problems:  my driving, and the load not being securely tied.
The rack was the type of thing that clamped on the rain gutters (remember rain gutters?)  The MDF was probably tied on with rope or the freebie plastic twine the lumber yard had.  This was a long time ago, before I knew about ratchet straps.
In subsequent years I have successfully used a cross-wise version of the Dan Pattison rack in the youtube above on my minivan.  It attached to the lengthwise rails, which I think is stronger than attaching to the crossbars.  The 2x4s were about 5 feet long, plenty to loop ratchet straps over sheet goods.  4 straps altogether, 2 lateral and 2 lengthwise.
It was pretty secure, for the short, low speed drive from the lumber yard to my house.
Currently I get my plywood partially cut at the lumber yard and haul it inside.  For lumber, I can get 10 footers inside if I take out the middle and rear seats, a big job, but worth it.  I'm jealous of those with minivans whose seats stow in the floor.
Offline darita
« Reply #26 on: March 13, 2023, 07:58 PM »
I got Rhino Racks for my Pilot.  They have nice, long crossbars that work well for sheet goods.  In addition to strapping down, I also made sure to strap to prevent the sheets from sliding forward and backward.  I always took surface streets home, being careful not to go too fast.  Also, never more than 2 sheets of 3/4".  I would also just slide them in the back compartment.
Or try what this guy did when I sold him my steel cabinet...
Offline ChuckS
« Reply #27 on: March 13, 2023, 10:23 PM »
I suppose this is a joke right? How could he change lanes with his side mirrors blocked?
If someone drives like this in my city, I'm sure he wouldn't go quite far before someone reports on him, and he gets stopped by a traffic cop.
Offline Packard
« Reply #28 on: March 14, 2023, 11:02 AM »
I own a Chrysler Pacifica with the stow in place roof rack.  Never used it.
When I fold down the Stow n Go seats I can slide a full sheet of 4’ x 8’ plywood in the interior and close the door.
I then drive home and back onto the driveway.  I setup my saw horse cutting setup behind the car.  I place a roller stand behind the van just a little higher than the saw horses.  I then slide out the sheet over the roller stand and roll it onto the cutting station.
I make my cuts and carry the smaller pieces into the shop.
The Stow n Go is the only reason I got the van and the only reason I kept it after getting a Chrysler 300 sedan.
Offline squall_line
« Reply #29 on: March 14, 2023, 11:11 AM »
If we ever have a second kid, my wife has finally reluctantly come around to being okay replacing our Rav 4 with a minivan (she doesn't want to be a Minivan Mom).  I've been itching for one for this very reason.
I miss my parents' old Ford Aerostar Extended, body-on-frame minivan.  No stowable seats, though; those things were cumbersome to remove, to say the least.
Offline Packard
« Reply #30 on: March 14, 2023, 03:08 PM »
The Pacifica is surprisingly luxurious, quiet and has good ride characteristics.
I had purchased a 2019 Honda CRV with all the bells and whistles.  I kept it for 6,000 miles and about 3 - 4 months before trading it in on the Pacifica.  The Pacifica is a vastly nicer car (and far more expensive).
I can only recommend the Honda CRV or the Civic (which shares the same engine) if you live in the south. In cold weather the engine will only reach operating temperature at highway speeds.  If you let it idle, the temperature will drop to “cold” in the winter.  So your defroster will not defrost.  It will not clear the snow from accumulating because in the snow you are not driving at highway speeds.  Honda knew about the problem.  At one point the Canadian equivalent of the DOT threatened to have a mandatory recall.
A couple of weeks after I took delivery of my car they had a “quite recall”, that is they had dealers retrofit new fuel injectors to all the cars that were on their lot but were unsold.  It was a partial fix.
I found out about it but Honda would not replace the injectors on my car because “Honda does not believe there is a defect”.
I have permanently divorced myself from Honda and all Honda products.
Quite aside from that, the SUV (Sport Utility Vehicle) was not sporty, lacked utility, and was barely suitable as a vehicle.  I could not carry even a 60” long plank of wood in the cargo area with the seats folded down.
The Pacifica is far nicer to ride in, quieter and smoother riding.  It has more utility, but no more sportiness.
I traded in the nearly new Honda and an older Sonata plus $800.00 that I put on my Amex and I drove off with the van.  Never regretted it.
Anyone who favors SUVs over a Pacifica or the new Kia, simply has not driven both.  Image aside, the vans are far nicer vehicles.  The Honda van is supposed to be nice too, but you know how I feel about Hondas.
Both the Pacifica and the Toyota are available with 4-wheel drive.  But only the Pacifica has the Stow n Go.  But the super delux version with captains chairs does not have stow and go, and the hybrid also does not.
If you are looking to buy a Pacifica (or the newest version of the Dodge) make sure that you know that it features the stow and go.  Some models do not.
