Author Topic: Rockler Sliding Door Slide Pins  (Read 328 times)
« on: February 23, 2020, 09:24 AM »
Just ran across this the other day and thought the idea had some merit. Has anyone used this before?
https://www.rockler.com/sliding-door-hardware?sid=V9177&utm_source=criteo&utm_medium=display&utm_campaign=lower_funnel
They also recommend that the door runs on some Nylo-Tape to reduce friction. I'd probably inlet it into the bottom of the sliding door.
https://www.rockler.com/nylo-tape-friction-free-drawer-slide-tape
« Last Edit: February 23, 2020, 09:27 AM by Cheese »
Offline Sparktrician
Re: Rockler Sliding Door Slide Pins
« Reply #1 on: February 23, 2020, 10:13 AM »
Why not just cut a block of UHMW and let it into the bottom piece, allowing the extended tab to ride on the UHMW material?  Tape is just so, well, inelegant...   [big grin]
- Willy -
Offline Sanderxpander
« Reply #2 on: February 23, 2020, 03:56 PM »
Mine are opposite? In the sense that there's a pin in the floor and a groove in the bottom of the door. To me it's better than having a groove in the floor (or cabinet floor).
