For what it's worth and YMMV:
The Klein NCVT's "beeping" will increase the more voltage is present. So if you are checking mains and it just "beeps" slow, it's very likely it's picking up some "inductive voltage". However, with the NCVTs there is no way to be 100% sure about that. There can still be voltage, and you can still get zapped. That's why I solely use them as indicators and for fault finding purposes (string-a-lights anyone?
(I can simulate this behavior all day on my toolboxes with LED floor lighting. If it's switched on, my NCVTs will claim there is voltage all over the box ... It's the same with 2 parallel lines. One live, one off - it will still slowly beep on the one that is off because it picks up from the one that is still live and running parallel.
Those NCTVs should never be your only tool to determine if a circuit is live/hot or not.
I also don't like multimeters to determine if a circuit/line is hot or not, because most (if not all?) of them lack a feature to add load to the circuit you are testing, which then eliminates any and all induced voltage - so you can be sure it was just that. If the voltage is not eliminated, it will let you know by vibrating. Fluke twin-pole testers for example do just that.
I would always recommend the twin-pole testers over any other tester/meter because they are a highly reliable way to determine if a circuit is live or not and also offer basic continuity testing. The digital ones will also allow you to read the actual voltage. The "load"-function also allows you to check/trip GFCIs - but, at least with the Fluke models, they will not trip GFCIs accidentally/ all the time when just checking voltage. Some old-school/past twin-pole testers did just that.
https://www.fluke.com/en/product/electrical-testing/basic-testers/fluke-t90-t110-t130-t150Personally, I have a couple of the T150s in different toolboxes/setups. But even the T90 will be better and much more reliable than any NCVT.
Klein offers a variety of twin/two pole/lead testers as well, those are also better than any NCVT.
If it just has to be a NCVT, get one from Fluke - they make the most reliable, among generally rather unreliable testers.
That said, owning 2 Klein NCVTs as well, they work if you know the limits. Plus they have neat secondary features that come in handy from time to time.
But then again, with mains, better to be safe than sorry!
Kind regards,
Oliver
