1, Lots of scratch pads on my rotex.
2. I think you are talking about the one in the second picture. Those are just two Operator stations for that machine. It is a linear feed through profile sander. Sanding heads adjust up/down in/out and tilt. Can squeeze almost 12" wide out of it. Built in 1999, cost 100k new.
1. Thanks for that...in 3M speak...that'd be Scotchbrite. ![Smile [smile]](https://www.festoolownersgroup.com/Smileys/default/smile.gif)
2. That's interesting...kind of makes the LS 130 look like a taco machine.
I gather that the equipment you're gathering is still focused on producing your original idea of reproducing difficult to achieve architectural focal points/design details.
Honestly, I don't know what I'm doing anymore.
everything is there to set up a production shop along with specialty millwork an architectural millwork, my smaller stuff is basically set up (cut off saws, tablesaws, jointers, planer, bandsaws, pattern mills, sanders (disc, edge, stroke, widebelt, etc.) Tenoners, mortisers, etc.) Also have a decent machine shop set up, adding a slotter and maybe a 33k pound Cincinnati Gilbert HBM. I have ended up in a real small niche doing better than new rebuilds though, plus a ton of forklift repairs, industrial maintenance/repair, I'm busy, I'm expensive, I can't keep up.
So yeah, only thing I'm missing is the time to finish wiring and the DC.
Sent from my SM-N960U using Tapatalk
