Author Topic: Quality cordless hand drill press  (Read 7794 times)
Offline treesner
  • DESIGN / CRAFT / ROAM
    • Trailboundco
« on: April 23, 2018, 05:30 PM »
Does anyone make a Festool quality drill press guide to work with a hand drill? I tried one and it’s junk, looks like the build quality on other ones is similar
Offline GoingMyWay
Re: Quality cordless hand drill press
« Reply #1 on: April 23, 2018, 05:37 PM »
Inquiring Minds Want to Know
Online TinyShop
« Reply #2 on: April 23, 2018, 05:40 PM »
@treesner - I suggest that you review the following thread from beginning to end. In addition to the earliest posts, there has been some recent activity, all of which should interest you:
http://festoolownersgroup.com/festool-tools-accessories/festool-drill-stand/
Also, this and more can usually be found via a search of the site using the parameters listed under the "Search" tab.
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n], Festool RAS 115 (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline rizzoa13
« Reply #3 on: April 23, 2018, 05:54 PM »
I have the mafell drill stand. The price is hard to swallow but it’s the best on the market by far.
Offline Peter_C
« Reply #4 on: April 24, 2018, 12:04 AM »
Why not just find a used drill press from Craigslist? Even a cost effective one from Harbor Freight will work better than those cheesy jigs. Plus a drill press can accept a vise, and clamps, like the Automaxx clamps.
Offline Corwin
« Reply #5 on: April 24, 2018, 03:26 AM »
A drill press will not work in every situation. These "cheesy jigs" can be your best option sometimes.
Offline Euclid
« Reply #6 on: April 24, 2018, 05:55 AM »
Because a drill press is an entirely different kind of tool for an entirely different set of circumstances.
The most obvious tasks for which a drill press is of no use, are drilling into the centre of a large panel, into an already partly-constructed piece, or into a vertical surface.
« Last Edit: April 24, 2018, 06:03 AM by Euclid »
Offline rizzoa13
« Reply #7 on: April 24, 2018, 06:58 AM »
What I use my drilling jig for mostly is handrails to accept metal spindles. Can’t really drill on an angle with a drill press on a 16’ length of handrail.
« Reply #8 on: April 24, 2018, 08:09 AM »
Some time back bought a Duss drill stand to use with a Metabo dual mode hammer drill. (Bought it used from a local fog member)
Took it to a work site where I’d be drilling finished holes in white oak with a 2-1/2” Forster bit. Was nervous about using the Duss/Metabo for the first time on something important so I was relieved to discover the complex had a shop and “one of those cheap drill presses from Harbor Freight”. (Don’t really know where it was from)
The cheap DP could barely turn the big bit even in low gear when in contact with the wood.
The Duss/Metabo on the other hand was awesome. Even with the drill clamp swung to the side so the Duss could sit on the work the very rigid construction of the stand and powerful drill made the job stress-free.
Offline zapdafish
« Reply #9 on: April 24, 2018, 10:01 AM »
I sorta ran into the same need so at first I used a drill press and turned a block of wood into a guide but over time the hole gets real sloppy so I found bushings to make my guide out of. worked great
fastenal
Offline promark747
« Reply #10 on: April 24, 2018, 10:07 AM »
fastenal
I have also used these in a pinch (they sell different sizes):
https://www.amazon.com/Gator-Tools-STD1000DGNP-V-Drill-Guide/dp/B0061FY004
« Reply #11 on: April 24, 2018, 11:51 AM »
If we're talking about a closed bottom drill stand (think mini drill press) the best value drill stand is a Wabeco. They're made in Germany and the options and prices can't be touched by anyone else. Steel posts with cast iron bases and mounting ears.
This is only $68.   [jawdrop]
This is only $160.
While this with a 2-axis table, positionable in .1mm increments, is only $302.
I don't own one but if I needed one, Wabeco is the first place I'd research.
https://www.wabeco-remscheid.de/media/content/Download/Bohrstaender/FraesBohrstaender%20screen%20englisch.pdf
Just ran across this spring Promotion
https://www.wabeco-remscheid.de/media/content/Download/Ausstellungsmaschinen/Frühlingsaktion-2018-EN.pdf
« Last Edit: April 24, 2018, 12:12 PM by Cheese »
Offline GoingMyWay
« Reply #12 on: April 24, 2018, 12:24 PM »
The Wabeco looks neat.  Does it work well?  I guess it's designed to work with a corded drill that has a trigger that can be locked on.
Offline Svar
« Reply #13 on: April 24, 2018, 01:49 PM »
I prefer Proxxon BFB 2000. Proper dovetail slide mechanism and ability to drill at an angle.
« Reply #14 on: April 24, 2018, 03:03 PM »
I agree, the Proxxon unit is real nice, however it runs about $300.
I was coming strictly from the value perspective aspect as the small Wabeco, with only a down plunge function costs $70.
There are a lot of down plunge only units out there from Metabo, Bosch, Record and BDS. However, they all run in the $190-$450 range.
And then there’s the Duss in the $600-$750 range.
Offline Svar
« Reply #15 on: April 24, 2018, 03:23 PM »
My problem with Wabeco is that they don't ship to US (directly from the company). Re-sellers bring the price up considerably.
« Reply #16 on: April 24, 2018, 03:38 PM »
You’re right, they only ship within the EU. However Amazon.de does resell their products for pretty close to the same price.
The last item I ordered from Amazon.de was a Festool PowerSys that I received in just 4 days.  [cool]
Offline Svar
« Reply #17 on: April 24, 2018, 04:08 PM »
No luck. Kein Verkäufer liefert diesen Artikel aktuell in die Vereinigten Staaten!
Online TinyShop
« Reply #18 on: April 24, 2018, 07:29 PM »
Found a German online retailer with more "normal" pricing that's set up to ship Wabeco stands to the U.S.:
The most basic version - https://www.toolteam24.com/en-GB/bohrstaender-h-500mm-ausladung-127mm-hub60-wabeco-4005725224003.html
A version with the rotatable round table: https://www.toolteam24.com/en-GB/bohr-fraeswerk-h-500mm-hub-horiz-175-hub-vertikal-250-wabeco-4005725244049.html
The material vise: https://www.toolteam24.com/en-GB/maschinenschraubstock-b-100mm-spann-w-65mm-wabeco-m-drehteller-4005725405402.html
The smallest two-axis table: https://www.toolteam24.com/en-GB/kreuzsupport-z-bohr-fraeswerk-art-nr-832620-4005725244100.html
« Last Edit: April 24, 2018, 07:37 PM by TinyShop »
« Reply #19 on: April 24, 2018, 10:24 PM »
Sweet...thanks for that. The variety of versions that Wabeco offers is mind numbing. I’m still thinking seriously about their 2-axis table.
The trash we’re offered in the states is horrendous. A 2-axis table with .005-.010” backlash for $230 is insulting. However if enough fools purchase the item, they’ll continue to hawk it.  [mad]
So who’s the fool...
Offline treesner
    • Trailboundco
« Reply #20 on: April 25, 2018, 02:34 AM »
I’ve got a drill press just want that drill press experience portable
I suppose I could just use my plunge router
Offline treesner
    • Trailboundco
« Reply #21 on: April 25, 2018, 02:40 AM »
Can you drill at an angle with these?
Offline treesner
    • Trailboundco
« Reply #22 on: April 25, 2018, 02:47 AM »
Get on the waitlist for the UJK Drill Guide: https://tsoproducts.com/workholding-accessories/ujk-technology-drill-guide/.
Said they would email me late summer when more are available
Offline Gregor
« Reply #23 on: April 25, 2018, 04:20 AM »
Quote
There are some countries we do not supply among others AU and USA.
For these countries, we are happy to forward your request to our representative or we will
give you the address of our representation.
Maybe just sent them a mail?
« Reply #24 on: April 26, 2018, 09:33 AM »
Maybe just send them a mail?
Thanks for the suggestion @Gregor , that's exactly what I did. I thought they may have a US distributor, however they don't. They just channeled my request through an internal group and Wabeco will ship it from Germany directly to me.
Interestingly enough, the normal price for the 2-axis K600 table is €224.00, while the current sale price is €140.00. I was quoted a price of €117.00.  That's pretty close to 50% off the regular price.  [eek]
The only kicker is freight, that costs €80.00.
Offline Gregor
« Reply #25 on: April 26, 2018, 10:09 AM »
The price on their website includes 19% VAT.
Quote
Yea, sending stuff over the pond by plane is quite expensive...
Offline JeffAZ
« Reply #26 on: July 10, 2020, 08:29 AM »
Two years later... I wanted to order the relatively small version of drill stand that Wabeco offers (B1230).  I asked for pricing and added the work table, steel machine vice, and clamping device.  Probably a total of around 22 lbs.  Pricing for the items is awesome.  Shipping costs aren't.  160 Euros ($180).  Double from two years ago.  It's disappointing and I'll probably pass.  Real fast response from the company though.  Great guys.
« Last Edit: July 10, 2020, 08:32 AM by JeffAZ »
Offline Gregor
« Reply #27 on: July 10, 2020, 08:42 PM »
You likely have ordered more than @Cheese (btw: happy with your K600?) which will result in a heavier box, Airfreight cost is AFAIK more a function of weight than of volume.
Maybe ask them if they could send the box through a slower (hence: cheaper) method?
Offline JeffAZ
« Reply #28 on: July 11, 2020, 12:35 AM »
I'll ask on a slower, cheaper speed of delivery.  Based on a post from @Cheese I took a look at toolteam24 and they can ship the press (by itself) for 50 Euros via DHL.  I might do that.  Maybe Wabeco should look into DHL.  But then my thinking is they must have already.  What company wouldn't have compared the two biggest worldwide shipping companies and settled on the best pricing?  I think there's a huge market in the US and elsewhere for such a press (all we have now is China  stuff) but you can't make it work with a $180 shipping charge.  They need a distributor here.
Offline Michel
    • Lyrk Tømrer & Snedker Aps
Danish carpenter and cabinetmaker, just me and my padawan :)
http://www.lyrk.dk
Offline Claimdude
« Reply #30 on: July 11, 2020, 06:21 AM »
You can get the UJK drill guide at Axminster for $145 and they ship to the US (available now). Also, Rockler recently came out with a drill guide very similar to the UJK, a little larger capacity. I bought the Rockler while waiting on the UJK and it has great fit and finish, very robust and a good value at $149.
Jack
« Reply #31 on: July 11, 2020, 09:21 AM »
I've had really good luck having DHL ship to the states. The shipping is reasonably priced and it's also fast. A high recommend.  [smile]
