While researching what I would replace my cheapo Grizzly 17" DP I previously owned in my quest to fill my shop with "Lifelong Tools", it came down to deciding between two models.
1. Powermatic 2800B
2. Delta 18-900L
I initially was leaning towards the PM, but then started seeing a number of reviews and posts on various forums that indicated that quite a number of people had a range of problems with the 2800B. This was concerning, because the problems were not all related to a single issue, but were varied. To be fair, a lot of people liked their mustard machine, and many recommend it.
On the other hand, the reviews on the Delta were overwhelmingly positive with very few complaints, and most of those were owners whose machines originally were delivered with runout issues....but for the most part few in number.
The PM has digital speed control which was an attractive feature, but on the other hand, the Delta's belt changing system was designed to be fast and easy, and the innovative tensioning system allows the Drill Press to be placed virtually against a wall without having to make space for a motor tracked tensioning system (think Kapex). The PM is a good looking machine, and clearly one of only a few at the top of the DP food chain. Decent sized table and good construction. Then again, the same can be said for the less expensive Delta.
Finally, the Delta was clearly designed for woodworking vs metalwork. Big table, Biesmeyer Fence (option), wide and stable floor base, wide range of speed settings, solid construction, and cheaper than the PM.
Amazon $949 with free liftgate shipping in less than a weekThe result is that I am extremely pleased with the Delta. Installation was painless and I did not have any runout issues at all. The Lasers are 100% accurate and the LED gooseneck light works perfectly for my purposes. The machine is very stable and feels solid. It unquestionably meets the criteria in my "Lifelong" tools quest. It is a joy to work with and I would recommend it strongly to others.
Delta 18-900L Product Page from Delta Machinery SiteCheers,
Frank
![Smile [smile]](https://www.festoolownersgroup.com/Smileys/default/smile.gif)
