Author Topic: Powermatic 60HH Jointer Vibration  (Read 298 times)
« on: July 21, 2020, 11:19 AM »
Good afternoon everyone.  I am only asking this question on this forum because i trust the knowledge of the seasoned woodworkers on here.  I have a Powermatic 60HH jointer that I feel has more than normal vibration while running and definetly when powered down.  If i completely remove the belt the motor runs silky smooth.  Has anyone experienced this on their Powermatics?
Offline JD2720
Re: Powermatic 60HH Jointer Vibration
« Reply #1 on: July 21, 2020, 12:09 PM »
The first place to start would be to make sure the pulleys are tight. Next would be to replace the v belt with link a link belt.
Link Belt
Offline StanB
« Reply #2 on: July 21, 2020, 12:31 PM »
the belt likely has some set in it from sitting a while, or its not tensioned properly. I would also suggest the link belt above. huge difference.
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro | VAC SYS SYSTEM SET | MX 1200 E MIXER | DF700 XL
« Reply #3 on: July 21, 2020, 12:55 PM »
Thank you everyone.  I will check the pullies today
Offline rvieceli
« Reply #4 on: July 21, 2020, 01:40 PM »
@Keithptd@bellsouth.net
In addition, try these as well.
with the belt off, spin the head and check that it moves smoothly and doesn't have any play. Maybe wiggle the shaft a bit. On a newer machine you wouldn't think there would be bearing problems already but stuff happens.
Inspect the cutting head to make sure that all the cutters are still there ans fastened securely. See if if a chuck of wood has jammed itself in the head causing it to out of balance.
Make sure the machine itself is not wobbly and doesn't rock. Many floors aren't really level even if they look flat and level. If you have it on a mobile base, make sure that one or more of the casters hasn't flattened out causing an imbalance.
Ron
« Reply #5 on: July 21, 2020, 02:16 PM »
Thank you.  Will test these as well.  Great advice fellas.
Offline JonathanJung
  • www.timberlightdesigns.com
    • Timberlight Designs
« Reply #6 on: July 23, 2020, 11:07 AM »
My old Grizzly rattled/vibrated. Replaced the belts with Continental at $7ea and now it's quiet.
