Author Topic: Possible to straighten out bowed aluminum extrusion?  (Read 2276 times)
Offline festal
« on: June 10, 2022, 06:21 PM »
So it seems that the fence that came with my kity 637 jointer/planer has a bow in it. Is it possible to straighten it out?
Bow starts at the green mark
Offline Bob D.
    • My Cordless Workshop
Re: Possible to straighten out bowed aluminum extrusion?
« Reply #1 on: June 10, 2022, 06:27 PM »
How long is that piece about 24 inches maybe a tad longer.
Offline festal
« Reply #2 on: June 10, 2022, 07:01 PM »
Spot on. Little over 23.5” by 6”
Offline Crazyraceguy
« Reply #3 on: June 10, 2022, 07:05 PM »
It is possible, but there is some level of risk involved. If you over bend it, trying to straighten it out, it is likely destroyed. It will not bend back without damage/breaking.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
MFT clamps set
Offline Lincoln
« Reply #4 on: June 10, 2022, 07:43 PM »
Try attaching a sub-fence/face to it - ply or MDF. Might be enough to straighten it, if not you can use packers between the fence/sub fence.
 My cast jointer fence had a slight bow to it, so drilled some clearance holes through it and attached a piece of 25mm Birch ply. Few pieces of blue tape here and there for packing and it's now dead straight/flat.
Offline rvieceli
« Reply #5 on: June 10, 2022, 07:51 PM »
I'm going to suggest either just ignore it and remember to reference of the bottom 2/3 of the fence OR attach another face to the current fence and shim it flat. I used a piece of UHMW plastic for my table saw and the folks I bought my band saw from used a piece of hard maple.
On the subject of shims, grab a couple of those cheap import feeler gauge sets from your favorite vendor. They are usually around $5 or less and use them with CA glue or tape.
https://www.harborfreight.com/feeler-gauge-32-pc-63665.html
Ron
Offline Bob D.
« Reply #6 on: June 10, 2022, 07:57 PM »
Are the two t-slots what is used to secure it to the machine.
Is the bow consistent for the whole length.
Can you show in some photos where this mounts on the machine.
Offline festal
« Reply #7 on: June 10, 2022, 08:26 PM »
Yep now spans entire length. There are 4 t-slot bolts on the back. Picture only shows 2
« Last Edit: June 10, 2022, 08:29 PM by festal »
Offline festal
« Reply #8 on: June 10, 2022, 08:31 PM »
Ron
That might be a way to go. I did order uhmw tape from Amazon and was going to tape it on top and wood would glide over it. 5mil tape so hopefully that would be enough
Offline Bob D.
« Reply #9 on: June 10, 2022, 10:44 PM »
Is there a gap at this point between the t-slots?
With the fence off are the faces of those mounting brackets that meet up with the fence flat.
Offline festal
« Reply #10 on: June 11, 2022, 07:36 AM »
There is a gap where you have an arrow.  0.80mm feeler gauge fits in there.  I'll check the faces of the mounting brackets a bit later today. need to remove the fence
Offline JimH2
« Reply #11 on: June 14, 2022, 10:30 AM »
Not to hijack, but how does that safety arm work?
Offline festal
« Reply #12 on: June 14, 2022, 02:01 PM »
Blade guard?  it does.  Its European style vs porkchop style
Offline JD2720
« Reply #13 on: June 14, 2022, 04:31 PM »
I straightened the aluminum fence on my 16" jointer by screwing a piece of hard maple to it. I then ran the face of the fence over the jointer to straighten it. It has worked great for the past 11+ years.
Offline FestitaMakool
« Reply #14 on: June 14, 2022, 05:21 PM »
If you have a heat gun..
Have you tried to clamp it down (with all steel clamps…) face down on a flat surface, heating it slowly in the area where the bend is - while slowly tightening the clamps until it’s laying flat and give it the most heat then? Then leave it until cooled.
Offline mino
« Reply #15 on: June 14, 2022, 06:38 PM »
That whole assembly looks wonky. Starting with the fence connection and ending with the fence not looking very sturdy to begin even if was straight.
As a (cheap) bet I would go with the "attach some hardwood to it which you make flat".
A proper solution would be to scrap the whole fence and design (have) a new one (made) which would have its face machined including the way the fence attaches to make it more sturdy, playing also with the pivot point while at it so it has zero give.
You can use a standard extrusion like 30x120 mm or whatever is locally avaliable. Just with one face machined to be trully flat.
The last -most obvious- option is to have the bent fence machined WITHOUT trying to flaten it by force. When aluminum alloyws bend, there are permanet changes in the structure. Trying to bent it back will weaken it and even if it does not break the already-wonky fence would become even weaker.
Offline Peter Kelly
« Reply #16 on: June 14, 2022, 07:45 PM »
I love that blade guard, need to fab up something similar for my jointer.
Offline festal
« Reply #17 on: June 14, 2022, 09:28 PM »
It is wonky.  Having it machined is an option but not cheap around me.  Not worth it.  I actually ended up selling it and went back to my 6" ridgid for now.  Will look for something else once it becomes available.
« Reply #18 on: June 14, 2022, 11:17 PM »
What mino said...aluminum doesn't like to be bent and then re-bent, it just isn't very happy.  [smile]  It's just not a very ductile metal compared to steel or copper. It work hardens easily which is similar to SST and once bent and then re-bent it likes to fracture. You can certainly try to rebend the fence as you have nothing to lose but just be aware of the likely possible outcome.
The suggestions of attaching a wood face to the fence and then machining that surface makes the most sense to me, short of designing and constructing your own fence from other extruded aluminum products.
Offline festal
« Reply #19 on: June 15, 2022, 06:53 AM »
I'll let the buyer deal with it lol.  back to searching for something else
