Author Topic: Upgraded my DW745  (Read 11071 times)
Online Rick Herrick
Re: Upgraded my DW745
« Reply #60 on: November 19, 2020, 12:32 PM »
I forgot to add my thanks to @DynaGlide . I just finished mine up this past weekend.  Its a pretty cool upgrade, appreciate the original post.
Offline sdscolumbia
« Reply #61 on: November 19, 2020, 04:06 PM »
Quick question -- do you have to remove the auxiliary fence to "flip" the saw's support for wider cuts?
Offline nicholam77
« Reply #62 on: November 29, 2020, 08:18 PM »
My Super Track and JessEm guides showed up!
I went with a 36" Super Track extrusion, so on my DWE7490 I now have ~16.5" of support before the blade with 3/4" material:
It makes a big difference, thanks @DynaGlide for this awesome idea and thread!
On the back side I used hex socket cap screws and some nylon washers for a small footprint -- was able to retain the DeWalt push stick holder:
I would think so? I just realized this tonight. Kind of a bummer. With the JessEm guides in place, to get a push stick through you really can't cut skinnier than 2", and due to the table surface not wider than ~12" on my model. So with the auxiliary fence and guides in place it definitely limits the type of cuts that work... unless someone else has some input on how to get around this?
« Last Edit: November 29, 2020, 08:21 PM by nicholam77 »
Offline ChuckM
« Reply #63 on: November 29, 2020, 10:41 PM »
Snip.
The last narrow strips I cut were 1/2" wide or so. To do so, you need a long push stick that can go below the roller and preferably a feather board, too. See the set-up in the image.
By the way, I mentioned this before: you can use the front roller/fence as a stop block for making cuts with the miter gauge.
« Last Edit: November 30, 2020, 05:02 PM by ChuckM »
