Author Topic: Pin router  (Read 862 times)
Offline Crazyraceguy
Pin router
« on: September 13, 2021, 06:27 PM »
Hand-made attachment for the router table anyway.
One of the guys in the assembly area came to me today asking if I had  way to put the grooves in the opposite side of these parts. Ah....no, but give me 10 minutes. This was a quick make-shift thing, but it works, at least for this purpose. It's not as capable as some of the factory made models, because the pin cannot be quickly tilted up to allow for inside pocketed cuts, but it literally took only minutes to build. It also was not necessary in this case.
I had one before the fire that took everything, but it has been this long (2 years as of last month) since I have needed it. I might spend a little time making it better later, but if it is that long between uses?
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
Offline Bob D.
Re: Pin router
« Reply #1 on: September 13, 2021, 08:49 PM »
Don't know if these are still available but it looks pretty easy to make one of these.
Offline Bertotti
Re: Pin router
« Reply #2 on: September 14, 2021, 01:11 PM »
Sometimes I just don't see things correctly. I was looking at your first picture and wondering how that small silver piece on the left was holding it all in place. Doh. I did eventually see the clamps. You just have to love a simple effective jig that takes minutes to make.
I want to populate SD with trees because I miss the forests of the river bottoms.
Offline Packard
Re: Pin router
« Reply #3 on: September 14, 2021, 03:52 PM »
About 10 years ago I read about a commercially available version.  I just looked for it and  it is the Veritas (made in Canada).
I could not find a single vendor for this, however.  I would think that rigidity would be a key factor.  That casting looks pretty rigid.  But when it comes to problem-solving, your's was johnny on the spot.
http://www.veritastools.com/Products/Page.aspx?p=212
Re: Pin router
« Reply #4 on: September 14, 2021, 06:22 PM »
That and one other I saw one time that was made with square steel tubing are the commercially made units that I have seen. From what I recall, they are fairly expensive, which is fine if you use it frequently enough. Rigidity was the reason that I used a piece that was 3.25" wide and tried to keep it as low/close to the material as I could. The parts I needed to cut were 12" wide, so that arm was sticking out there quite a bit. The cut was just over 1/4" wide and only about 3/16" deep. I used a brand new 1/4" down spiral bit, so the cut pressure wasn't much. It worked out well.
CSX
PS420 + Base kit
OF1010
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Offline Bob D.
Re: Pin router
« Reply #5 on: September 14, 2021, 09:23 PM »
The one shown in the video I posted is $40 and still available today apparently. I wouldn't call that expensive but I have no idea what the quality level of the thing is.
And it looks easy enough to roll you own version with a MIG welder, a bit of steel, and a push/pull type toggle clamp.
Offline Packard
Re: Pin router
« Reply #6 on: September 15, 2021, 12:49 PM »
I do wonder what the price of the Veritas unit is.  Is that a casting?  Or is it a big piece of plastic?  Can't tell from the photo.
But for once in a while job, the improvised jig is nice and I am impressed.
I probably would have cut the grooves with a dado head and some sort of indexing pin on the table saw.  If I indexed off the same end of the board then both sides would be identical.
On the second thought, I have a radial arm saw.  That would be easier to index.
I rarely use my router for dados.  I don't know why though.
Re: Pin router
« Reply #7 on: September 15, 2021, 06:05 PM »
What I did, for this quicky, was add that second block to the side. Then two screws hold the main arm in place. One is very near the back, beyond the side block. That way, I could remove the front screw and rotate the arm, being fairly sure that it would return to the same place. It doesn't solve the vertical movement, but I didn't need that in this case.
I'm pretty sure that the Varitas unit is a casting and if I remember right it was around $200? but that was years ago. With all of the Festool stuff I have, I certainly couldn't call that expensive with a straight face, but for such a seldom used tool?
If I can find the pics, it will have the date for when I made the first one. I would guess at least 4 years?
Good guess, it will be 4 years in December. These were slightly different. They were blind grooves, so the shelves were not removable, and they were only about half the depth. There were thousands of them though. 4500? something silly like that. This entire room was filled with these little slots, floor to ceiling. They were very tricky to assemble, since the vertical members were vey flimsy until the spaces were filled with the shelf pieces.
« Last Edit: September 15, 2021, 06:22 PM by Crazyraceguy »
CSX
PS420 + Base kit
OF1010
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
