Author Topic: Ordered a Hammer A3 31  (Read 6192 times)
Offline xxrb2010
Re: Ordered a Hammer A3 31
« Reply #30 on: November 09, 2019, 09:55 AM »
@rmhinden
Bob, thanks for the info on the Magports and the 5 inch Fernco coupling to adapt them to the A3 jointer/planer.  Attached picture should look familiar.
The Magports are a greatly improved way to disconnect and reconnect the dust hose on my J/P.
Which coupler are you using? When I looked at Fenco web site and their drawing for the 1056-55 it shows an ID of 5.5 that looks way too big for a 5 inch magport or 120 mm hammer port.
Offline xxrb2010
« Reply #31 on: November 09, 2019, 09:57 AM »
Max,
Glad it was helpful.
Bob
Same question as just posted on the post above:
Offline rmhinden
« Reply #32 on: November 09, 2019, 11:11 AM »
Right, the 5" Fenco coupler is too big with out modification.   What I did was to cut a section out of it and glued it back together with CA glue to have it fit the 5" Magport.   You can see the seam in a few of the pictures I posted.
This is still too big for the 120mm (4.72") Hammer outlet.  I put several layers of Silicone Rubber Self Fusing Tape on the 120mm outlet to make the diameter larger.  Only took a few layers.   The 1 1/2" size that I linked to was the right width.
Hope this helps.
Bob
