Today the installer's drill and the hackzall finally arrived. I haven't had the time yet to put them through their paces, but here's my first impression of the drill.
The balance and weight are great. I really like how this drill feels in hand. The forward/reverse button issue some mentioned is no issue to me. My hand is just a bit too small to reach the button on top without changing my grip, but I don't think that will detract from it's usability.
Despite all the plastic this drill does feel sturdy.
I don't know why, but I've always hated belt clips on drills. So that was removed as soon as I took it out of the box. It is attached with one screw, so not problems there. You can screw it back on either side of the handle if you prefer to do so.
The magnet on the front is strong enough to not lose bits or fasteners. The LED is powerful enough and aimed in such a manner that I think it will be quite useful in actual use.
There are two things that surprised me though. The first is that the 90 degree angle chuck rotates in the opposite direction as the drill itself. So when you use that chuck, forward is reverse and vice versa. I did not try this chuck during the demo, so I hadn't noticed before. No biggie, I will get used to it.
The other thing is that the hex chuck it too deep for my Wera bits (see photo).
I tried several bits with it and noticed it does not really lock the bits. You can pull them out quite easily with your fingers, if they are long enough (the bits that is
![Wink [wink]](https://www.festoolownersgroup.com/Smileys/default/winksmiley.gif)
). But it is not like the bits will fall out either. Wera rapidators on the other hand can't be pulled out of the chuck without using excessive force.
Some commented on the trigger not being "linear". That may be true. However, I already found that with a little Fingerspitzengefühl you can manipulate the speed quite well. So, while not optimal, this shouldn't keep anyone from choosing this drill either in my opinion.
I haven't tried the torque or how long the battery will last yet, but all in all I think I will be quite happy with this drill.
[Edit: the bit next to the drill is identical to the bit in the chuck]
