I’ve owned a 16-32 sander for many years with no issues. The advantage of the 16-32 is the open end. Once the bottom belt is adjusted, it stays in place. Adjusting it is fussy.
I can’t take bit bites with my sander. The one you are looking at is a lot heftier and can probably remove a lot of wood on every pass.
I tend to use 80 grit all the time. I have all the other grits, just don’t use them.
You might want to check on sand paper availability for that model.
