Author Topic: Nova Voyager - Aftermarket table  (Read 4853 times)
Offline Caboose1966
« on: October 25, 2018, 09:47 AM »
Hello, folks!
I just recently purchased a Nova Voyager drill press and I see that there are a handful of owners of the same on this forum.  I have read a couple of real informative, extensive threads on here so thought I would pose this question...
I am looking at adding a bigger table to this drill press, which seems to be a pretty common modification for woodworkers.  I am strongly considering the Woodpeckers' offering, but wondering if any of you have any input on that.  I know building your own is a popular option, and I might do that... just have the same issue as many with time constraints.
The other issue I'm wondering about is interference between a larger table and the table height crank.  For those of you that have added a bigger table, what have you done to mitigate that?  I am considering replacing the crank handle with a 5" handwheel... just haven't found exactly the right option yet, and it will depend a bit on the table I add.
Thanks for any input/advice you may have.
Dean
Re: Nova Voyager - Aftermarket table
« Reply #1 on: October 25, 2018, 10:30 AM »
I went with a hand wheel. I also have 30 or 40 pound cross slide table on the includesteel table and it’s not a problem to elevate. Not at the shop now but I think the hand wheel is below the table so a larger table would still work. Don’t hold me to that though...
Offline Caboose1966
« Reply #2 on: October 25, 2018, 06:17 PM »
Thanks, Michael.
Do you recall the manufacturer/model of the handwheel you went with?  I think I can go up to 5" - figured the biggest one that would fit would be best for leverage.  Also.  Looks like it's about a 1/2" bore which, surprisingly, was not easy to find on smaller than 6" diameter wheel.  Also, having an issue finding one with a set-screw or drilled for one.  How did you attach to the shaft?
Thanks,
Dean
« Reply #3 on: October 25, 2018, 10:43 PM »
I have a Woodpeckers drill press table attached to an older Delta metal drill that has a production, cutting fluid assisted table. The Woodpeckers table is attached with 2 SHCS that will allow easy removal if you need to swap it out. My typical work incorporates probably a 50/50 spread of metal vs wood projects. The Woodpeckers drill press table remains on the drill press for 95% of the tasks I perform. It’s very nice and I would highly recommend it. I’d also recommend purchasing both fences.
Prior to that, I installed a Rockler drill press table on the Delta and it was a real POS. It’s up for sale...anyone want to take a chance?  [smile]
Offline neilc
« Reply #4 on: October 25, 2018, 11:16 PM »
I used woodpecker fence and adjustable T-track.  For the table, I purchased 3/4" phenolic and doubled it up and added inserts on the  bottom to drop into the slots of the OEM table.  For height handle adjustment, I cut out the corner of a phenolic plywood top to accommodate the handle revolution.
Go to post 28 in this thread for photos.  Plans are also there for the cabinet I made as well.  http://festoolownersgroup.com/other-tool-reviews/nova-voyager-drill-press/
Happy to share more if you have questions.
Neil
Offline Mario Turcot
« Reply #5 on: October 26, 2018, 08:08 AM »
First, thank you for the hand wheel suggestion. This is something I never thought about.
My advice: Before making any decision make sure your NEW table will not affect the tilt feature. Not that you will use it often but it hurt when you limit a feature on such a nice power tool. I am currently playing with a design to run on my CNC and just before I start to cut a prototype I realized that the tilt option will be limited. So here again back to the design phase  [eek]
Neil show off his setup a month ago  [tongue] and that inspire me to start with his design.
Mario
Re: Nova Voyager - Aftermarket Hand Wheel
« Reply #6 on: October 26, 2018, 08:40 AM »
See this thread
http://festoolownersgroup.com/other-tools-accessories/nova-drill-press-52667/
Reply # 9
PS. When searching for older posts in the Fog it’s better to go out to Google and search. Just include Festool Owner’s Group in the query.
« Reply #7 on: October 26, 2018, 08:43 AM »
Mario
« Reply #8 on: October 26, 2018, 08:44 AM »
Just added the wheel.
Offline Caboose1966
« Reply #9 on: October 26, 2018, 12:31 PM »
Thanks, everybody, for the feedback and suggestions.  Sounds like the Woodpeckers is a good way to go.
Michael,
Thanks for the link to the other thread and the info on the chuck and handwheel.  I actually just ordered that same Llambrich chuck on Monday and received it yesterday.  Haven't mounted in yet, but will this weekend.  I will do some measuring and head-scratching this weekend to see if I can make that handwheel you suggested work with the layout on the Nova.  If not, perusing the McMaster site shows a lot of different handwheel options so I think I will be able to find one that fits the bill.
Thanks again for all of the great info.  Now it's time to start makin' holes in stuff   [wink]
Dean
Offline SRSemenza
« Reply #10 on: October 26, 2018, 06:12 PM »
 @Caboose1966
     I used a socket  with extension and flex head ratchet (extra stuff I had) in place of the crank on this Delta. It works very well. Plenty of leverage, easy to reach with out contortions,  and works around any other objects that might be in the way.
Offline Caboose1966
« Reply #11 on: October 26, 2018, 11:48 PM »
Another good idea.  Thanks, Seth.
Dean
Offline Caboose1966
« Reply #12 on: October 26, 2018, 11:53 PM »
Hey, Cheese... a couple of questions for you.
I’m usually pretty good at figuring out acronyms, but what are “SHCS”?
Also, you mention getting both fences... I’m looking at the Woodpeckers WPDPPACK2 that has the fence face at the rear. What fences did you buy? I’m seeing the DP3 fence, but what’s the other one?
Thanks,
Dean
Offline rvieceli
« Reply #13 on: October 27, 2018, 06:57 AM »
@Caboose1966
Dean SHCS is a Socket Head Cap Screw
https://www.boltdepot.com/Socket_screws.aspx
SHCS look particularly nice when you counterbore the piece to sink the head to below the surface.
https://www.mscdirect.com/browse/tn/Holemaking/Counterbores-Porting-Tools/Solid-Pilot-Counterbores-Sets/Solid-Pilot-Counterbores?navid=12106214
I think @Cheese is referring to the T track fence that comes with the table and the DP3 high fence.
Ron
Offline Bob D.
« Reply #14 on: October 27, 2018, 07:04 AM »
I have plans to get the NOVA drill press soon. I have been thinking about replacing the table and wishing it had something like the Delta 18-900L which tilts L/R and F/B and has a flat edge for easier clamping plus the square sacrificial center is a nice touch too. IIRC the Voyagers' is round so not as easy to duplicate as it's probably some odd diameter that I don't have a hole saw to match and I can batch out a stack of square blanks from scrap in no time.
Reid Supply (now  http://www.essentracomponents.com ) or McMaster-Carr are two sources with good selections of handwheels and cranks of all sizes/types. Not the least expensive options but I think the best selection.
Both are pretty easy to navigate and find what you need. My personal preference is McMaster, I think their online catalog, ordering, and search system is the easiest to use.
I believe there is a free fence available from NOVA until Dec 31, 2018. Might be worth go ing to their website and finding out the details.
« Last Edit: October 27, 2018, 07:16 AM by Bob D. »
« Reply #15 on: October 27, 2018, 09:44 AM »
Thanks,
Dean
Hey Dean, Ron's correct on both the acronym and on the fence questions.  [big grin]
Here's a shot of how I mounted mine. It's an easy 2 screws on and off, and no poking around under the table, yet stable as all get out when you crank down the fasteners. The SHCS threads into T-bolts that slide in slots in the Delta table.
The second shot is to give you an idea on how durable the surface of the Woodpeckers table is. That's a 35# Heinrich vise that's been slid around the table hundreds of times for workpiece alignment purposes. I just wipe the Woodpeckers table with some Goof-Off on a paper towel and it cleans right up.
What I've really used a lot in woodworking are the Woodpecker rail flip stops. They make repetitive tasks easy and FAST. I'd recommend the aluminum/stainless version over the molded plastic version.
https://www.woodpeck.com/ssflipstop.html
[ Specified attachment is not available ]
« Last Edit: October 27, 2018, 09:48 AM by Cheese »
Offline SRSemenza
« Reply #16 on: October 27, 2018, 10:13 AM »
   The Delta I have originally had  a crank. I replaced that with a hand wheel, it was steel , 5 or 6". That worked pretty well. But was still difficult when reaching around or under. Even though I need to ratchet instead of just spin the wheel, the ratchet set up is much easier and more convenient. It will depend on other objects next to and behind the press. If you can easily step in next to the press the wheel will be pretty good. But even when I had the press in a location with good access the hand wheel did not work as well as the ratchet.  It is simply a matter of the add on table being both relatively heavy and in the way.
Offline Caboose1966
« Reply #17 on: October 27, 2018, 11:51 AM »
Thanks for all the excellent info. We’ve got a Tacoma Screw branch fairly close by so I should be able to peruse their selection of SHCS (thanks for the education on the acronym, by the way  [smile]) to see what will work for me. Thanks, Cheese.
Taking a couple of vacation days next week so will have a little time to get this mod done...just have to do a little shopping between now and then.
I hope the hand wheel works out well. I definitely need to do some mock-ups before I decide on the size, to make sure I have the clearance I’m hoping to have. I want to go with as large a diameter hand wheel as possible, but I’m pretty sure I’m going to be limited to 5”. McMaster Carr definitely had a great selection and I think I found the right combo of wheel diameter, bore and set screw options to fit the bill. Definitely easy to navigate, like was mentioned - thanks, Michael and Bob.
I notice that the DP table is available with the standard hold-down clamps or with knuckle clamps. Has anyone had experience with both and/or can comment if the knuckle clamps are a better option? It’s only a $15.00 price difference, so worth it if they are better/more convenient.
Having a hard time finding the aluminum/ stainless flip stops for the drill press table... will have to do some digging to see if they are still available. Definitely trying to avoid plastic wherever possible. I’ve been spoiled a bit by some of my JessEm stuff... they seem to have a similar plastic allergy to mine  [wink].
Thanks again for all the great info. I really appreciate it!  I’ll digest a bit more of all y’alls informative posts and probably think of more questions.
Dean
« Reply #18 on: October 27, 2018, 12:45 PM »
https://www.woodpeck.com/ssflipstop.html   [smile]
Offline Caboose1966
« Reply #19 on: October 27, 2018, 12:45 PM »
Told ya’ I’d have more questions...
Cheese, what kind of setup do you have there with what I assume is a vacuum nozzle?  Does it pick up the shavings pretty well?
Bob. Yep, I’ve already sent in my rebate form for the free fence from Nova. Although, if I get the woodpeckers setup installed, I may not use it much.  Maybe I will reserve that fence for metalworking when I remove the woodpeckers setup...that will be reserved for woodworking.
Just did a little more measuring and ordered the 6” zinc hand wheel from McMaster.
Thanks,
Dean
Offline Caboose1966
« Reply #20 on: October 27, 2018, 12:50 PM »
Thanks for the link (again), Cheese. Don’t know how I missed it in your earlier post...and on the woodpeckers website  [embarassed].
Will be putting together my shopping list this morning. Amazon is a little higher priced but I know I’d get the stuff in time to do the work while I’m on vacation. Woodpeckers site shows backorderd but Toolnut has in stock and good price. Wonder how fast their free shipping is...?
Thanks again,
Dean
« Reply #21 on: October 27, 2018, 12:57 PM »
Hey the link is tough to find on the woodpeckers website. That's the reason I included it for you.
You'd think it would be under Flip Stops, however it's not.  [sad]
« Reply #22 on: October 27, 2018, 06:26 PM »
Hey Dean, it’s a vac nozzle that works well. Woodcraft sells it for about $25. The hose is really cool, you can shorten it, lengthen it or bend it to hold any shape you want, and then return it to its original size.  It also comes with a scoop end rather than the nozzle end for wider dust collection. My last project was aluminum so that’s the reason the nozzle end is still on.
I made a bracket from BB and fastened it to the Delta with 2 MagSwitch magnets. The sizing of the hole for the hose was the most difficult part of the project.  [smile]  A small enough hole to hold the hose securely yet large enough so that the hose can be adjusted/moved with one hand.
 Again, no clamps, no straps, no extraneous parts...just friction holds it in place.
« Reply #23 on: October 29, 2018, 07:21 AM »
Hey cheese or anyone with the Woodpecker table, can you give me the measurement C to C between the two tracks, and the tracks thickness?
I just ordered the tracks and low profile fence and some SStops  [big grin] I will be making my own top since the woodpecker top alone bumped the shipping from $46 to $111  [eek]
The table will be based on neilc top with probably some magswitch magnets to hold it (ty Cheese). I'm also planning to incorporate a circular offset insert.
Mario
Offline rvieceli
« Reply #24 on: October 29, 2018, 08:34 AM »
@Mario Turcot I’d suggest bolting the table down. Unless you’re going to spend the big bucks the magnets can’t hold against the torque involved.
Ron
« Reply #25 on: October 29, 2018, 09:26 AM »
Ron
Ron, I was thinking to screw a runner like, under the table that would make a snug fit. Sliding the table in position and securing it sideways from magnets through the runners. The magnets would ultimately hold the table to stick on the DP table and the side runners to avoid spinning. Do you think it would be enough to keep it secure?
Another option would be a L channel with pressure screw from under. All i am looking for is a quick way to remove the top for when I drill into metal+lubricant using a vise.
Sorry to hijack your thread Dean  [sad]
Mario
« Reply #26 on: October 29, 2018, 10:08 AM »
Hey Mario, the CL to CL (center line) distance between the tracks is 13.75". The track width appears to be 1.75" because the slot width is 1.77/1.78". The track thickness however, is another story. It is .50", I think ??  It's tough to get an accurate measurement of the track thickness without removing it from the table.
I'd suggest you wait until you have the track in your hands because you want it to be slightly recessed relative to the top surface. Woodpeckers recesses their tracks by .030" (1/32") to prevent anodization wear from sliding things across the table.
I'd also echo Ron's thoughts on bolting your home made top down to the Voyager table. It's not only side thrust & twist you have to worry about, it's also a heavy off set load on the table could flip it off. I can place a 35# vise loaded with another 25# of material ANYWHERE on the top and not be afraid of it landing on the floor...or my toes. [big grin]
« Reply #27 on: October 29, 2018, 10:25 AM »
Gotcha on the toes  [eek] and thanks for the measurements.
I will probably sandwich two pieces of BB 12mm together. Hopefully the tracks will recess enough to prevent wear out with 12mm. That way i don't have to make any dado to sit the tracks on. will have the bottom layer in one piece and the top layer in three pieces. Want it modular enough so I can replace any top part w/o having to redo the whole top.
Back to the design table  [wink]
Mario
Offline Grev
« Reply #28 on: October 29, 2018, 10:43 AM »
I also have the WP DP table on my Delta 18-900 and love it.  Just wanted to let you know the Festool track clamps work good with the track and also accepts 1/4"-20 hex bolts/nuts for custom jigs.
Offline Caboose1966
« Reply #29 on: October 29, 2018, 10:55 AM »
More great info and pictures.  Thanks, everyone.
Mario, no worries about "hijacking".  Personally, I like it when everyone chimes in with their related questions/ideas.  Makes it more one-stop shopping that way  [laughing].
TrackTubes... thanks for the info on the Festool track clamps.  Good to know.
I've got to get on ordering the table today.  After that's in place and the way I want it, the vacuum setup looks like a great addition.  I've got a few dust-collection related tasks things I have to get figured out.  Everything is just set up to hook up to my shop vac on an as-needed basis right now.  Ultimately, when I get a permanent dust-collection system set up, I'll have to re-work some of the connections, but trying to think ahead as much as possible to minimize that re-work down the line.
Thanks again for all the helpful info.
Dean
« Reply #30 on: October 29, 2018, 01:48 PM »
Doh! Tracktubesguy, you just make me realized that the DP3 can be reversed  [big grin]
After crushing all the numbers I came with a first draft. Let me know what you think and if you see any flaw.
This is the lower layer only, showing where the WP tracks will sit. The dark grey parts are column and actual drill press table. The light grey are bumpers under the table to ease installation and make sure it's always at the same position. The column collar (that's how I named it) have a shape to allow the table to tilt easily. The black parts are where the WP tracks will be. I still have to find out the center of the chuck based on the column (What is called the depth I guess).
« Last Edit: October 29, 2018, 02:00 PM by Mario Turcot »
Mario
Offline rvieceli
« Reply #31 on: October 29, 2018, 03:01 PM »
@Mario Turcot
There's not a particularly compelling reason the have the add on table extend any farther that the column in the rear. You won't really gain anything and it complicates the construction a bit.
In addition you might as well extend the t track all the way to the front edge. Makes it easier to insert things.
If it were me, I'd take bar stock that would fit through the slot in the factory table, drill and tap it for maybe 1/4-20 or the metric equivalent. Cut it to a length that when rotated at 90 degrees to the slot would hold securely. I would then drill and countersink the holes in the add on top to keep the screw heads below the surface. You would align the tapped bars so they dropped through the factory table slots to below the factory table and then rotate them 90 to the slot and tighten the screws.
You'd need to decide if you needed just two of those or maybe one in the front also.
Ron
Offline SRSemenza
« Reply #32 on: October 29, 2018, 03:57 PM »
Depending on what sort of fence mounts are being used having the table extend back past the column can gain a couple inches of usable space.  My t- track fence  mounts are behind the fence. The table extends back. The mount can be in the track space beyond the column gaining space in the drilling area in front of the fence.
« Reply #33 on: October 29, 2018, 04:20 PM »
Just thinking, we all have at least 1 old cordless drill that refuses to die and it's battery still charges to full capacity, yet when we reach for a drill we always grab the newer models. [sad]
Why not replace that ratchet handle with the old cordless drill and then just pull the trigger?  [big grin]
I'm going to try that on my Delta...got an old Milwaukee cordless just hanging out in the shop.
Offline Dick Mahany
« Reply #34 on: October 29, 2018, 05:17 PM »
I made a home brew drill press table from 1" MDF and Formica laminate.  I dedicated an inexpensive ratchet for the column lock and extended the crank handle.  While it works great for my needs, there are a few things sub optimal.  One is that to tilt the table, I have to loosen a set screw on the coupling nut for the crank handle extension.  The other is that I wish I had made the crank handle quickly removable as it always seems to snag on other tools when I wheel my drill press into storage position.
Edit:  Note the position of the square sacrificial insert.  It is purposely offset to drill in one quadrant of the insert.  This gives me 4x positions on two sides before I need to replace the insert.
« Last Edit: October 29, 2018, 07:47 PM by Dick Mahany »
Offline SRSemenza
« Reply #35 on: October 29, 2018, 06:09 PM »
  Cool extension!  If you take out the front set screw you can go with a socket and extensions in place of the threaded rod. And  maybe a universal would take care of the tilt problem?
Offline Caboose1966
« Reply #36 on: October 29, 2018, 06:17 PM »
See why I don't mind "hijacking".... I LOVE all these ideas and pictures!  I have the Woodpeckers fence and the fence on it's way, but now I want to make my own custom fence, too.  I also have a 6" handwheel coming for the table elevation crank, but I'm liking these extensions and ratchets and all the other cool ideas.  Necessity is the mother of invention, right.
Hijack away!!   ;)
Dean
Offline Dick Mahany
« Reply #37 on: October 29, 2018, 07:56 PM »
Great suggestion...........I see a trip to Harbor Freight for some cheap 3/8" extensions in my future  [big grin]
Offline SRSemenza
« Reply #38 on: October 29, 2018, 10:15 PM »
Not sure how well it will crank with the universal while tilted and I think you will need to allow extra length in the extension so that it can slide in the support  when tilting.
« Reply #39 on: October 30, 2018, 07:27 AM »
@rvieceli Ron, thank you for your comments on my first draft.
Ron
Ron, I agree with you that it might not help it and that make the design more complicated. I do like some challenge  [big grin].
I am a too visual person to picture where you talk about drill & countersink the holes [sad]. My goal right now is to get to a design that will give me the larger working surface possible w/o getting out of wack. For example, if I end up extending the table in the back, there will be a notch for the handle or the handle will be mounted under the table like Dick one with a double universal joints. I like the hand wheel suggestion, looks very nice I.M.O.
Extending the tracks? Well that first draft is based on the length of the WP tracks 15 3/4". I was planning to add a key hole (T-Bolt size) in the front of each slot to help sliding in clamps.
Having a front track? Another very good suggestion. I might add one on the next version. Of course that track would go all the way  [wink]
I am still at the design phase and love all the idead & pictures you guys bring in. Thank you  [smile]
Mario
Offline derekcohen
    • In The Woodshop
« Reply #40 on: December 01, 2019, 11:50 AM »
I purchased a Voyager yesterday tempted by Black Friday. There was a decent discount, along with a free Nova fence for the table. I have not seen any mention of the fence on the forum, and so am not sure whether there are any views of it ...
I've only just finished putting it all together, and not even plugged it in, so not much to offer about the drill. The fence has potential, but will need tweaking - I do not like the lever-clamp at the rear. It feels notchy.
Interestingly, all the pictures of the bare table - both the manufacturers and in forums - show the table reversed. Even the woodwork store from whom I purchased the Voyager had their demo with the table reversed .... it was not possible to use the fence the way these are set up.
« Reply #41 on: December 01, 2019, 12:12 PM »
 [thumbs up] Congrats on your new toy.
The press drill is simply awesome. Quiet and very easy to use. The first thing you might want to learn is to set the zero depth on any and every piece of wood you want to bore.
My sister made me a hood to protect from dust. The motor vent is on the top
1) Power up the Voyager, depth will be at zero by default.
2) Install drill bit and put your stock under it
3) Pull down the quill until the bit hit the stock and press the Zero Confirm button
As you can see the table is mounted reversed. I find out easier to clamp stock since I don't have that fence. Another thing you might want to change is the chuck. I put a keyless chuck and never regret is  [big grin]
I don't plan to get the fence despite it is a well constructed fence. I'm in the planning of making a larger wood table with a low/high profile fence similar to
« Last Edit: December 01, 2019, 12:26 PM by Mario Turcot »
Mario
Offline derekcohen
    • In The Woodshop
« Reply #42 on: December 01, 2019, 12:40 PM »
Thanks Mario.
I already have a keyless chuck - I used in on my previous drill press, and it slotted straight into the Voyager.
Offline Bob D.
« Reply #43 on: December 01, 2019, 01:15 PM »
"My sister made me a hood to protect from dust."
That's really nice Mario, your sister did a great job, even adding a window.
Would look great with Nova screen printed on the front.
« Reply #44 on: December 01, 2019, 04:15 PM »
Indeed she's awesome. She also made one for the iMac and the bandsaw
Proof   [wink]
Mario
Offline thudchkr
« Reply #45 on: December 01, 2019, 06:03 PM »
I purchased the fence when I bought my Voyager.  I found it difficult to use because the table slots, where the fence mounted to the table, varied in depth.  The variance meant I couldn’t just loosen the lever through the approximately 180 degrees of travel the locking levers have as they’re mounted behind the fence. You’d have to reposition the spring loaded levers to a new position and re-loosen them, (or the opposite for tightening), before you could slide the fence to its desired position. I was considering contacting Nova about the issue and considered taking to a machine shop to have the slot milled to a consistent thickness.
Ultimately, I just quit using it when I built my own table with the Woodpecker drill press fence hardware.
Now the fence just sits on a shelf. Anybody out there with a Voyager drill press want a great deal on the Voyager fence?  If so, PM me and maybe we can make a deal.
Clint
