Author Topic: Nova Viking DVR 16” bench drill press  (Read 16983 times)
Offline grayedout
Re: Nova Viking DVR 16” bench drill press
« Reply #60 on: April 02, 2020, 05:35 PM »
I just come across this post and have a couple of video on this drill press on has a chuck replacmemt
The Drill
The Chuck
https://youtu.be/fUiz4ny-G0I?t=242
Ruwi Clamping plate
« Last Edit: April 02, 2020, 05:41 PM by grayedout »
Offline Claimdude
« Reply #61 on: May 10, 2020, 09:45 AM »
Hi Viking owners,
I have a Viking on order and am building an 80/20 stand with drawers. I would like to have this ready to set the drill press on when it arrives without having to move it later. To that end I would to drill 4 holes in the top to attach the base but need a measured drawing of the base (which I haven't been able to locate) or at the least the measurements (width, length and distance from front end of slot to the front edge of the base) along with a center to center measurement from slot to slot. Does anyone here know where I can find that info or be wiling to take the measurements off the base of their Viking? I would greatly appreciate any help you all can provide!
Jack Lemley
Offline Erich
« Reply #62 on: May 10, 2020, 11:22 AM »
@Claimdude
I measured my Viking for you.
The base is 10.5" by 18.375".
The holes average 0.52" diameter.
All four holes are set back 1.385" to the centerline from each edge.
The slots are 5.375" on center and 2.75" back from the front edge.
« Last Edit: May 10, 2020, 11:34 AM by Erich »
Offline Claimdude
« Reply #63 on: May 10, 2020, 12:39 PM »
Thanks Erich!
@Claimdude
Online 08G8V8
« Reply #64 on: June 30, 2020, 09:36 AM »
Hi Viking owners,
Jack Lemley
Did you get your stand made?  I’ve got mine on a temporary stand and was also looking at making a stand from 8020 material. I bought extra material when making my workbench but haven’t got anywhere with the drillpress stand yet. Post up some pictures if you can. Thanks
Offline Claimdude
« Reply #65 on: June 30, 2020, 09:53 PM »
Yes, I have my stand complete and Viking attached. I will upload some pics later this week. I also got the Albrecht Keyless Chuck off Zoro with 20% discount (roughly $340 shipped). Real happy ith everything so far.
Jack
Hi Viking owners,
Jack Lemley
Offline Claimdude
« Reply #66 on: July 01, 2020, 09:26 AM »
Here are the pics of my new Viking and 80/20 stand
Jack
Hi Viking owners,
Jack Lemley
Online 08G8V8
« Reply #67 on: July 01, 2020, 09:31 AM »
Looks good and what I am looking at doing. Need to work on a layout and just get it done!  Thanks
Online 08G8V8
« Reply #68 on: July 01, 2020, 10:07 AM »
Jack
Hi Viking owners,
Jack Lemley
What dimensions did you make it, WxDXH?
Height without wheels and plywood top.
« Last Edit: July 01, 2020, 04:19 PM by 08G8V8 »
Offline Claimdude
« Reply #69 on: July 01, 2020, 08:33 PM »
W20in x D22in x H25in these are the material lengths. The material is 1.5" x 1.5"
Jack
Jack
Hi Viking owners,
Jack Lemley
Online 08G8V8
« Reply #70 on: July 01, 2020, 09:06 PM »
Jack
Jack
Hi Viking owners,
Jack Lemley
Perfect, thanks so much. I was looking at around a 24” cube since I have (4) sticks of 72” 1515 extrusion.
Offline Claimdude
« Reply #71 on: July 01, 2020, 10:12 PM »
I didn't really make it clear in my reply but the dimensions are the 820 stick sizes so the depth and width need to add 3" (1 1/2" for each piece of stock) for for outside dimensions. The height is actual 25"
Jack
Jack
Hi Viking owners,
Jack Lemley
Online 08G8V8
« Reply #72 on: July 01, 2020, 10:46 PM »
Jack
Jack
Hi Viking owners,
Jack Lemley
Got it. Yeah, I scaled it off the screen and figured it had to be around 23” wide horizontal stick in the front, so 26” wide overall.
I started laying it out at 24” cube, but it leaves me excess unusable material, so I will grow all directions to maximize my material.
Offline stevensivak
« Reply #73 on: December 25, 2020, 06:14 PM »
Curious to know if it would be possible to take a voyager and have the
shaft cut down so that it could be used as a bench top unit....
Would anything prevent that from being possible?
« Reply #74 on: December 26, 2020, 02:00 PM »
Don’t see why you couldn’t, the post is just a rotocast iron pipe ground round. At least that’s what it looked like to me. The downside is you’re left with a very large base for a bench top machine.
Offline stevensivak
« Reply #75 on: December 27, 2020, 08:50 AM »
good point about base size...
but then I assume that the notched rails on the side of the shaft would need
to be cut down also....  but they are tapered at the ends to fit into a collar...
that seems to be the hurdle....
Offline lshah72414
« Reply #76 on: January 20, 2021, 03:18 PM »
Waiting on a nova viking drill press, and bought an albrecht chuck off ebay used. It need an arbor so it will fit on the press(MT2 taper). Just wondering if there is a certain brand of arbor I should be looking at. On  ebay there is a veteran owned company that sells arbors with .0004" runout. Very reasonable in price.Wondering if that will suffice.
Thanks for your help.
Offline deepcreek
    • TimberFire Studio
« Reply #77 on: March 06, 2021, 11:33 PM »
We finally have our drill press properly accessorized.
Nova Viking with Albrecht chuck, W.L. Fuller imperial brad points, Fisch wave cutter forstners, and Fisch metric brad points.
Yes, we are tool nerds.
Joe Adams
TimberFire Studio
Houston, Texas
Offline festal
« Reply #78 on: April 12, 2021, 07:20 AM »
was just checking out who has viking in stock and noticed new floor standing version available https://www.grizzly.com/products/teknatool-nova-viking-16-floor-model-drill-press/t32590
