Author Topic: Nova Viking DVR 16” bench drill press  (Read 17471 times)
Online 08G8V8
Re: Nova Viking DVR 16” bench drill press
« Reply #30 on: December 06, 2019, 12:32 PM »
I bought another arbor for the Albrecht as well, so I can swap back quickly. I will see how the stock chuck runout measures.
It will be interesting to see what runout the stock chuck has.  [big grin]
Make sure you have a couple of arbor wedges on hand so you can easily remove the arbor.
https://www.zoro.com/jacobs-wedge-set-13268/i/G0565573/feature-product?gclid=EAIaIQobChMI-73nlqyh5gIVjtdkCh1bMwafEAQYBCABEgKIgfD_BwE
I bought another arbor so I wouldn’t need to remove the arbor from the chuck. I guess it would be a good idea to have some wedges in the toolbox anyway. Thanks.
Online 08G8V8
« Reply #31 on: December 06, 2019, 12:46 PM »
Can you post up a picture of yours when you get it setup in your cart?
@08G8V8
Here's a photo of my current set up.  The top and bottom are double thick.  My Labrador gnawed on the trim when he was a puppy and I never got around to fixing/finishing it.
I'll probably make an 80/20 cart similar to the one I'm working on for my Kapex sans the drawers.
(Attachment Link)
(Attachment Link)
Very nice!  I am building a 8020 MFT style workbench and just ordered my material earlier this week. I ordered everything cut to length but no added machining such as tapping. I ordered some extra 1515 profile and hardware to have on hand, and think a drillpress stand is what I’ll use it for.
Online 08G8V8
Re: Nova Viking DVR 16” bench drill presso
« Reply #32 on: December 06, 2019, 01:43 PM »
Cheese, do I need the #3 set of wedges?  The chuck, stock and Albrecht are J33 taper, so does that mean it needs the #3 3JT?
« Reply #33 on: December 06, 2019, 10:17 PM »
Well these arbor wedges are very specific in their capabilities. I have Morse 3, Morse 2 and Jacobs 6 arbors. The numbers stamped on the arbor wedges are 3...2....and 6. I'd suspect the wedges for your application should be stamped 33...just my guess. If I had better info than that, I'd let you know.  [smile]
Online 08G8V8
« Reply #34 on: December 07, 2019, 11:18 AM »
I found a video on YouTube about these and the guy measured the inside width and I took a screen shot of them.
Just like the problem he had, the inside dimension was either too small or too big for the stock arbor I have. I saw other videos on how to remove the arbor in this case, but I just ordered a new arbor for the new chuck and I’ll leave the stock arbor and chuck married together.
Offline deepcreek
    • TimberFire Studio
« Reply #35 on: December 07, 2019, 11:29 AM »
IMPORTANT - I just read in the manual (page 8) that you MUST use a surge protector rated to at least 15amp 115v and a joules rating of at least 3900J to protect the DVR motor.
Also on page 9 it says for a GFI to be compatible with the DVR motor it must have a leak current threshold rating of 30mA.  Normal household GFI devices are typically rated at 5mA which may trigger when using the drill press.
The best deal I have found that meets the 15amp 115v and 3,900 Joules rating is from Tripp Lite and costs about $50 at Amazon.
https://www.tripplite.com/protect-it-8-outlet-industrial-safety-surge-protector-25-ft-cord-3900-joules-cord-wrap-hang-holes~TLM825SA
It's much larger than I need for my setup and comes with a ridiculously long 25 foot cord.  (Although, I suppose the cord makes sense for a construction jobsite.)
Has anyone found a better alternative?
The Isobar's like I use for my home electronics are only rated to 12 Amps and 3,840 Joules.
Thanks!
Joe
Joe Adams
TimberFire Studio
Houston, Texas
Online 08G8V8
« Reply #36 on: December 07, 2019, 11:53 AM »
I ordered this from Amazon.  It is 15amp and 4320 joule.
https://www.amazon.com/gp/aw/d/B07GPF72BZ?ref=ppx_pt2_mob_b_prod_image
« Reply #37 on: December 07, 2019, 12:10 PM »
I didn’t pay any attention to the joule specification, just used an ordinary surge protection outlet strip. Guess I’ve been lucky.
I don’t even know what a higher or lower joule rating means. Can anyone explain?
Online rvieceli
« Reply #39 on: December 07, 2019, 12:23 PM »
#6 wedge is the one for a #6 Jacobs Taper and a JT33
But as mentioned they don’t always work right with the quill end taper.
Ron
Online 08G8V8
« Reply #40 on: December 07, 2019, 12:44 PM »
A joule is a measure of energy.  The joule rating of a surge protector is how many joules it can absorb.  Anything above the 3900 joule requirement from Nova will meet their specs.
« Reply #41 on: December 07, 2019, 03:01 PM »
So the Nova DVRs can tolerate more “surge” or less?
Offline deepcreek
    • TimberFire Studio
« Reply #42 on: December 07, 2019, 06:07 PM »
Since they're specifying a surge protector rated to 3,900 joules, I suspect they're pretty sensitive or being exceedingly cautious.
@Michael Kellough & @08G8V8
Thanks for the recommendations on the surge protectors from Amazon basics.  I didn't even see them when I looked there.
Joe Adams
TimberFire Studio
Houston, Texas
« Reply #43 on: December 07, 2019, 07:11 PM »
This “absorb” didn’t sink in till now. Thanks.
Offline festal
« Reply #44 on: December 12, 2019, 05:06 PM »
Those that got the Viking what are your thoughts?  I can't decide between Viking and Voyager.
« Reply #45 on: December 12, 2019, 06:15 PM »
The Viking is not simply a Voyager at a lower cost and a short leg.
The Voyager has valuable features that the Viking lacks. Compare carefully, but if you can afford both the floor space and cost, get the Voyager.
Offline threesixright
« Reply #46 on: December 13, 2019, 09:17 AM »
Any idea where we can find a function matrix, so we can compare  [tongue]?
Will be available in Europe?
Online 08G8V8
« Reply #47 on: December 13, 2019, 09:37 AM »
Besides the difference in motor power, stroke and table size, the Viking doesn’t have the (4) speed presets and it also doesn’t have the menu system to select bit type and material type to get the recommended speed. You need to figure out the speed and turn the dial manually.
The manual depth gage is different between the 2 as well, but the electronic depth gage is so easy to use and so precise, I would imagine that would be the method used to set depth.
It does have the electronic depth control, reverse functionality, self start and it has a crosshair laser built in.
The user manual shows the Europe part number as 83703 and the UK part number as 87304. I guess you would need to inquire with a vendor that sells the Voyager to see if they will be selling the Viking.
« Reply #48 on: December 13, 2019, 06:17 PM »
@08G8V8
Thanks for the explanation!  [thumbs up]
Online 08G8V8
« Reply #49 on: January 11, 2020, 05:12 PM »
For those of you who have bought the Nova, what is the height of the bench you have it mounted to?
The Viking spindle to base measurement is 22.66” per their website, and the Voyager same dimension is 40.94”, so a difference of 18.28”.
I am going to build a cabinet using 8020 material, as I bought extra material when I ordered material for my MFT-style workbench.  But in order to be able to use the drillpress, I wanted to get a cheap temporary stand from Harbor Freight, but both local stores did not have it in stock, so I ordered a similar stand from Amazon for a little bit more $$.
This stand is about 31” high, and I put a laminated stack of 3/4 plywood making a final height of about 32.5”.  This worked for temporary usage to drill all my 8020 material, but it puts the spindle about 14” higher than where a Voyager spindle would be.
I know the height would be user preference, but just wanted to see what other owners have used and what you feel is preferable.
« Reply #50 on: January 16, 2020, 01:36 AM »
While at Costco yesterday I saw a pack of surge protectors. Couldn’t remember the joule spec for the Voyager so looked up the manual online. The official Voyager manual simply says “ A Surge Protection Device must be used, rated to at least 15 amps“ and notes that “ Ground Fault Interrupters (GFI's) are generally not compatible with Variable speed motors. If you wish to use a GFI or RCD, select a unit that is confirmed for use with a Variable speed motor using capacitor charge.”
You’d think they would update the Voyager manual since they now have such specific requirements for the Viking.
Offline Bob D.
« Reply #51 on: January 16, 2020, 04:41 AM »
The same warning appears in the manual for the Rikon 14" bandsaw DVR motor upgrade which is made by Striatech, the same people who make the DVR motors for Nova lathes and drill presses.
« Last Edit: January 24, 2020, 08:40 PM by Bob D. »
Offline jarbroen
« Reply #52 on: January 24, 2020, 03:01 PM »
Any feedback on using the Viking?   I see comments about chucks, but am wondering about ease of use, height, etc.
I'm strongly considering adding one of these to my workshop.  Mostly for woodworking and possibly light metal work some day.
Online 08G8V8
« Reply #53 on: January 26, 2020, 05:02 PM »
I do like mine, but as I asked a few posts ago, I am curious to what height folks have theirs mounted as it is tall for a “bench top” press.
I do wish it had a little more ability to configure like the Voyager, but I understand the price point and limited options. I do wish you could configure the options on what happens when depth setting is met. It will always reverses direction of the bit when the depth is hit, and don’t always want that. Also, wish it had a mechanical depth stop like the Voyager, for this reason.
It would be nice if it remembered the RPM it was set to after it is turned off. Not sure if the Voyager does, but it returns to 950rpm after it is turned off and back on. Maybe it doesn’t, which is why the Voyager has the 3 preset speed buttons that the Viking doesn’t.
Offline Jiggy Joiner
« Reply #54 on: January 26, 2020, 06:42 PM »
@08G8V8  I think the height is a personal thing, especially with the traditional machines that have belt drive, as easy access to the belts had to be considered.
I could take measurements from my Voyager, like the height of the chuck from the floor, or centre of control panel/screen from the floor if it helps?
Mine is slightly higher than standard though, as I made a mobile base for it.
Online 08G8V8
« Reply #55 on: January 26, 2020, 06:56 PM »
I looked at the specs online for the Voyager and Viking, and also saw both at a Woodcraft store recently, and I think it I remember it being like an 18” difference between them.  I have mine mounted on a stand with plywood on top of that, putting it on a stand about 33” high, so dropping it 18” won’t work.
Think I’ve got it worked out to build a stand about 25” high, dropping it to a more comfortable level, and work with the amount of 8020 material I have on hand.
Offline jarbroen
« Reply #56 on: January 30, 2020, 01:53 PM »
I really appreciate the feedback.
The laser would be nice, but the lack of other features as compared to the Voyager might drive me away from the Viking.
Saving $600 sounds great, just have to decided if I would really miss any of those options that aren't included.
Offline derekcohen
    • In The Woodshop
« Reply #57 on: February 01, 2020, 08:12 PM »
Quote
It is surprising that the Voyager does not come with a laser or light. I would not purchase the Viking just to get these.
I added a Wixey laser to my Voyager ...
.. and a rechargeable bicycle light for extra illumination ...
Even so, I could live without these.
Visit www.inthewoodshop.com for tutorials on joinery, hand tools, and my trials and tribulations with furniture builds.
Offline jarbroen
« Reply #58 on: February 06, 2020, 01:51 PM »
If I do end up purchasing a drill press in the near future I'm pretty certain it will be the Voyager.
The Viking is really appealing, but I think the missing features would make it less appealing for a long term tool.
Online 08G8V8
« Reply #59 on: February 06, 2020, 01:57 PM »
I was mistaken, you can change the functionality of what happens when the depth stop limit is reached. I missed it in the manual.
I emailed tech support about this and the rpm issue, and they told me how to change the reverse functionality. They also said they will look into allowing a user defined startup rpm, instead of the 900 it is currently.
Not that this will sway your opinion but just following up with updated info.
