That's exactly my way of thinking too. Capability of tackling the unknown is always a concern, because I don't choose what I build.
I latched onto the insert tooling early-on. It is especially important with flush-trim and pattern bits.
Although I have access to a sharpening service, at no cost to me, you lose the flush when the bit gets smaller. With insert tooling, it takes a few minutes to turn or replace an insert. You are right back cutting again.
I have both the 30mm and 50mm cut length versions of the Amana (flush & pattern) with 1/2" shanks.
I keep both of the 30mm ones on Milwaukee 5615-21, the 50mm ones don't get used nearly as often. They reside in the router bit Systainer, with the rest of the
investment ![Scared [scared]](https://www.festoolownersgroup.com/Smileys/default/scared.gif)
I have one of those compression "ultimate flush trim" bits too, but I save it for solid wood only.
I have never tried an insert-spiral router bit. How well do they cut? As smooth as a "real" spiral?
The big Besseys are extremely handy. I got a fantastic deal on them because of the large purchase of Festool equipment. They can't discount that, but they could on other stuff in the same purchase.
That's how I ended up with the Vario version of some of the longer ones. I may have never bought them otherwise, but I really like them. I've got (4) 98s, (2) 78, (2) 60, (4) 50.
I don't personally own any pipe clamps, but the shop has a bunch. Every once in a while we get out the 10' ones.
