Author Topic: New from Starmix: Adaptor plate to mount T-Loc/Clas. Systainer or L-Boxx to Vac  (Read 5497 times)
Offline six-point socket II
  • formerly @the_black_tie_diyer
Hi!
Starmix published/released this on German forum: werkzeug-news.de. ( https://www.werkzeug-news.de/forum/viewtopic.php?f=9&t=42671 )
Adaptor plate to mount T-Loc & Classic Systainer or L-Boxx (or another new, not yet released toolbox system) to Starmix compact and i-Pulse dust extractors.
Other toolboxes can be mounted by using straps.
Power cord and hose can be stored/mounted on adaptor plate.
Adaptor plate can be mounted to all Starmix compact and i-Pulse dust extractors without using tools. Compatible with all future Starmix dust extractors.
Adaptor plate will feature 4 marked spots for drilling, which can be used to attach adaptor plate to other manufacturers dust extractors - if layout is compatible.
Picture copyright by Starmix.
Kind regards,
Oliver
Kind regards,
Oliver
Offline Tooms
Think for the CA-VA the mount is to the wrong side for this plade
My design there turn the short side of the systainer to the front of the starmix
http://festoolownersgroup.com/member-projects/starmix-meets-festool-ca-va/
Offline Tom Gensmer
Very cool!
It appears that Starmix is following Nilfisk in offering a mounting plate that accommodates both Systainers AND the Sortimo/L-Boxx cases, very clever on their part.
I wonder if these will be available in North America?
CT-MIDI, C-18, RO-150, RO-90, OF-1010, OF-1400, MFK-700, MFK-700EQ/B, EHL-65, DTS-400, LS-130, MFT/3 (x4), MFT/Kapex (x3), KA 65 Conturo, endless Systainers
Offline TinyShop
What strange and fortuitous timing! I had actually carved out some time tomorrow to adapt a Karcher sys-plate to fit my i-Pulse - now I can sell that imported plate and instead look forward to the real deal! Finally!!!
« Last Edit: January 19, 2019, 11:29 PM by TinyShop »
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline Job and Knock
Thank you for that, Oliver. I was just mulling over whether to get a Metabo Metadepot (the Systainer adaptor for the older ASR2025) and butcher that to go onto my ASR35M - now I know that Starmix 9and presumably Metabo in due course?) are releasing a ready-made solution I'll hold my horses a bit
Simplicity is the embodiment of purity and unity
- Shaker maxim
TS 55 - TS75 - Kapex KS120 - OF1010 - OF2200 - Rotex RO150e - Domino DF500Q -  Domino DF700XL
Offline demographic
I wonder if them can make one for my Festool CTM, likely be better plastic than the standard hose garage that Festool provide...
Offline TinyShop
https://www.starmix.de/en/products/wetdry-vacuum-cleaners/craft/vacuum-cleaners-ipulse/ipulse-l-1635-top
and
just google "Starmix Smartfix" :)
A word of caution - the Smartfix rails (which are available separately as an accessory) are not compatible with pre-2018 iPulse vacs. During the initial roll out of the Smartfix concept, the marketing language in use at the time didn't make this clear. I went back forth with a a German retailer and with Starmix and almost became a victim of this confusion. Now, with the forthcoming roll out of the OEM sys-plate, this confusion should be reduced.
Offline worldburger
and
So would the ASR 35 mentioned above be compatible? It does seem the rails would only work on the new (and seemingly NAINA) iPulse since it needs the updated top that has the molding to hold the rails.
That being said, is there presently a Systainer dock solution for the older style ASR 35?
Offline TinyShop
and
I think there might be some confusion. The image included in the OP's post shows the forthcoming sys-dock that will give all of us pre-2018 i-Pulse vac owners (and this includes the currently available Metabo-, Hitachi-, CS Unitec-branded versions - which, although they may be marketed as the "latest-greatest" are more than a season behind the most current model) the opportunity to fit systainers, etc., to the top by way of a tool-less adapter that rests on the lid and locks to the handle.
This is not to be confused with the Starmix "Smartfix" rails (which are available as a spare part in Europe) that now come standard on certain versions/packages of the NAINA i-Pulse vacs. Basically, we get the leftovers here in N.A. so it will be be a while before existing stock is sold and somebody (be it Metabo or someone else) decides to import a shipment of the Smartfix-compatible machines. In the past, this was annoying since there was no OEM sys-dock option available anywhere in the world for the late model i-Pulse vacs. That is apparently about to change. Even so, I suspect that anyone wanting to outfit their non-Smartfix-compatible vac with the forthcoming sys-dock will be forced to find a retailer in Europe willing to ship this part to N.A. IOW I highly doubt they'll be available here anytime soon.
Edit - I should have also mentioned that the Smartfix-compatible lid (and Smartfix rails) are available in Europe as spare parts - I was aware of the rails but not the lid, the latter of which I only came recently while googling the topic:
[Source: https://starmix-specialist.nl/starmix-bovenkap-relingset-ipulse-444673-445106.html]
Part number is 444673 (for the lid) and 445106 (for the Startmix rails) and the total cost runs about 80 euro (sans GST) plus shipping. There are not any electronics buried in the lid so it should be a fairly straight forward matter to swap lids. Note - Depending on your particular version, the color scheme may not match.
Here's another possible source.
« Last Edit: January 30, 2019, 04:16 PM by TinyShop »
Offline worldburger
and
This is not to be confused with the Starmix "Starfix" rails (which are available as a spare part in Europe) that now come standard on certain versions/packages of the NAINA i-Pulse vacs. Basically, we get the leftovers here in N.A. so it will be be a while before existing stock is sold and somebody (be it Metabo or someone else) decides to import a shipment of the Starfix-compatible machines. In the past, this was annoying since there was no OEM sys-dock option available anywhere in the world for the late model i-Pulse vacs. That is apparently about to change. Even so, I suspect that anyone wanting to outfit their non-Starfix-compatible vac with the forthcoming sys-dock will be forced to find a retailer in Europe willing to ship this part to N.A. IOW I highly doubt they'll be available here anytime soon.
Edit - I should have also mentioned that the Starfix-compatible lid is available in Europe as a spare part - I came across this fact while googling the topic:
Part number is 444673 (for the lid) and 445106 (for the Starfix rails) and the total cost runs about 80 euro (sans GST) plus shipping. There are not any electronics buried in the lid so it should be a fairly straight forward matter to swap lids. Note - Depending on your particular version, the color scheme may not match.
GREAT looking out! Thank you!
Dang. I'd imagine that top would fit on the old ASR 35's, don't you think?
Ok, who lives in Europa and wants to mail one to USA?? ;)
Offline TinyShop
@worldburger - yes, as I understand it, the replacement top will fit all i-Pulse vacs, yours included. In fact, that's exactly how they are being marketed, "Retrofit your vac to the new Starfix sandard."
Offline Tom Gensmer
and
A few years ago I adapted a Festool Systainer cart to serve as a docking station for my Metabo ASR 35. It worked "ok", but to do so involved having to remove the top section, which turned out to be a rather involved process, I think I removed and reinstalled over a dozen screws and I think I had to remove and reattach the power cord. Either way, it's absolutely doable to replace the top section, but it's involved. If I were to update my Mafell S-35 to dock Systainers, personally I'd be more inclined to go with the docking plate rather than replacing the entire upper housing.
I've actually come to enjoy using my S-35 "naked", it helps to keep the vac nice and small, and if I want to set something on it the top is flat so tools won't slide off.
Offline TinyShop
Just heard back from Starmix. At this point the planned rollout of the sys-dock isn't until October 2019 (!). That stinks. So, it looks like I'll be trying to get my hands on a replacement lid. Fingers crossed.
Kind regards,
Oliver
Offline TinyShop
Hi!
More pictures available: https://www.dropbox.com/sh/v4nvfwz3j347b8l/AACjtdhLiVDEVzUiEtkH3TOva?dl=0
Kind regards,
Oliver
Thanks @six-point socket II!
I can't help but wonder why the release for this part is nine months out? After all, the longer Starmix waits the less of these machines will still be at work and the less of these sys-docks they will sell. Wouldn't it make more sense to get this into the marketplace ASAP (and saturate same)? Weird logic.
Of course, it does appear to be a somewhat complicated mold but the fact Starmix waited all these years to design it is another head-scratcher, especially since they had experience with a custom sys dock in the recent past (a.k.a. the aforementioned "MetaDepot" and the Mafell-branded version as well). Maybe Metabo and Mafell indicated that the product didn't sell very well and so Starmix was hesitant to go out on a limb with an i-Pulse version? If that's the case, they didn't see the writing on the wall in regards to Festool's and Tanos' growing popularity.
« Last Edit: January 25, 2019, 01:27 PM by TinyShop »
Offline TinyShop
and
Ah, yes, Brice. Your involvement in the (long!) Starmix thread over on the Mafell Users Forum (and your other related posts on the same topic) have been the source of much inspiration for me over the last couple of years. Thank you for your willingness to adapt and modify your tools to get the most out them and also for taking the time to post about your efforts! Where would Mafell (or, for that matter, Festool) be without all of the selfless sharing that goes on between us forum members?!) :)
« Last Edit: February 27, 2019, 11:09 PM by TinyShop »
They should have done. Makita licensed the Systainer design about 4 years back and have gone mental over here with a Makpac (aka licensed copy of the Classic Systainer) insert for what looks like about 80% of their range these days, Metabo have their own compatible Metalock box (having previously supplied tools in Tanos-supplied Systainers both classic and T-Loc), Mafell, Lamello and Mirka all supply kit in Systainer T-Locs, and even Hitachi supply some stuff in versions of the Systainers. Very common in Germany and the EU and very popular - so not just a Festool thing
- Shaker maxim
Offline worldburger
How are you going to try and get a replacement lid? I'd be interested in buying one as well.  Perhaps we could investigate ordering multiples and saving on the trans-Atlantic shipping...
Offline TinyShop
I've had some dealings with Starmix in the past and have a contact that I'm in the midst of corresponding with. (It's his turn to respond.) I'd planned to add updates to this thread when I had them and will still do so. On that note, I also contacted two retailers requesting quotes but haven't heard back from either. Which reminds me that I need to send each of them round-two. I will definitely include your willingness to join-in on shipping. Selling two of everything rather than just one should be more persuasive. Stand by.... :)
Offline worldburger
FYI, I imagine there's a few others who would be on board with this. I am fairly certain I know at minimum 2 more.
Offline TinyShop
Excellent news. I just let on as much in the second round of emails to the previously-alluded-to spare parts suppliers. I'm also in the process of locating U.K. spare parts suppliers and making the same request of them (much easier with the language barrier). I'll post what I hear back.
Update: I've emailed about a dozen Starmix suppliers/retailers in the U.K. as well as sent followup emails to a Dutch retailer and a German retailer. I've also sent another message to my Starmix contact in Germany. My hope for the delay in his response is that he's trying to figure out a way to help me (us) out but only time will tell on that front. At this point, I should order a container's worth and set up shop to supply all the Metabo, Mafell, Hitachi, CS Unitec, etc. i-Pulse owners on this side of the pond! I wonder how many of us their are? That's potentially a lot of wasted plastic. Again, wouldn't it be so much easier if the sys-dock would just be made available worldwide now? Arrghhh.
More as I get it.
« Last Edit: January 30, 2019, 04:12 PM by TinyShop »
Offline TinyShop
OK, I heard back overnight from my contact at Starmix as well as several of the many retailers I contacted.
In regards to Starmix, there is no chance of any of us getting ahold of even a prototype of the forthcoming OEM sys-dock. I offered us up as a test group but they didn't bite. The two part numbers (for the lid and the rails) were confirmed as being correct though I'm not sure why this confirmation was offered as I didn't ask for it. There was also no response to my question about whether Starmix could supply us directly with the spare parts (as opposed to us having to track down a willing retailer). I will follow up on that (again). My contact also warned me that installing these spare parts would be "at my risk" and that doing so would void the warranty.
All but one of the retailers who responded were sorry to say that they couldn't get these parts. The one that did respond, though, forwarded a quote that produced an automatic sitting response. Get this, including economy shipping, for each of the lid and rails combinations, they want £190 (or US$248.71 at today's exchange rate). That's £95 for the parts and £95 for the shipping. After that, the math breaks down a bit. If we want to ship two full sets together at the same time the total price increases to £420 (US$550.03 or US$275/each). This isn't even close to what the parts sell for elsewhere.
I don't know about anyone else but for me this offer is a total non-starter.
That being said, I've personally found that shipping costs from the U.K. is often so out of whack with other locales (like Germany, the Netherlands and France, for instance) that I still have some hope that I can locate a more reasonable offer. It may even make sense to group the rails together as one shipment and then ship the lids separately - the latter's size is a big part of the problem. That said, if they nest together (not sure if they do) I can't understand why the cost would be so obscene (even knowing what I know about U.K. shipping costs). So, stand by on that front too.
Other than that, I'm of course open to any ideas for other workarounds. As it currently stands, I might be installing that Karcher sys-dock after all. :(
Offline TinyShop
Quick update:  The U.K. seller that's been responsive regrouped and has amended their offer. While it's certainly an improvement, it's not nearly enough in my estimation. The first offer assumed TNT as the shipping agent. Going instead with UPS (and the new parts price he arrived at after he'd had time to reflect on what his competitors in the Netherlands and Germany are charging), he returned with a total for two complete sets with shipping of £315 (or $412.23 a.k.a. $206.12 per person).  That's  for one complete set of parts (a lid and two rails) and the remainder being the second set of parts (£112.50) and shipping (£90). Both the parts price and the shipping price still seem high (though the latter is at  least approaching what I'm familiar with, though still have double), especially when compared to the offers on display publicly elsewhere.
Offline TinyShop
Just wanted to post an update. After multiple attempts to reach out to the Dutch and German retailers which show these spare parts as available on their respective websites, I finally heard back from both. In both cases, neither was able to help owing to neither of them being willing/able to ship to the United States. I also heard back from all of the other retailers (one French, one Spanish, a couple of German and British eBay sellers) and in every case, each of them stated that they did not have access to the parts. And, now, my contact at Starmix has stopped replying to my multiple attempts which ask him if he'd be willing and/or able to sell us the parts directly. At this point, I'm at a loss as to what to do next. I'm thinking that it will take a FOG member located in Germany or the Netherlands who is willing to act as an intermediary.
In the meantime, with my patience exhausted, I came up with an interim solution solution using a Karcher sys-dock. You can read all about those efforts elsewhere on the forum.
« Last Edit: February 28, 2019, 09:34 AM by TinyShop »
If you need someone in Germany ... I'm right here. Just let me know.
Kind regards,
Oliver
Kind regards,
Oliver
Offline TinyShop
Kind regards,
Oliver
My apologes @six-point socket II - I missed your generous offer until just now. I've actually been perfectly happy with my own solution which has held up remarkably well (I prefer the "in-line" versus transverse orientation afforded by my solution too). When mine fails (if is ever fails) I'll pick up the real thing. So, at present, I don't have the need for your assistance. But thanks anyways!
However, getting back to the reason I'm revisiting this thread...
The Starmix "UNIFIX" has been available for a few months now:
Anyone in N.A. who wants one just has to spend a little time sniffing around online until they are able to find a Euro retailer (amongst the growing number of online retailers stocking this part) who is willing to ship across the pond. Where there's a will there's a way. Or, you could just hit up Oliver. ;)
[Note - as of this writing, this adapter plate is not available via eBay.de, ebay.co.uk, amazon.de, amazon,fr., amazon.es or amazon.co.uk.]
« Last Edit: January 05, 2020, 03:29 PM by TinyShop »
