« Reply #30 on: May 16, 2017, 01:17 PM »
Hmm, are you sure there is no adapter?
I think the compatibility down range is there to the "old" OIS blades. I can check this afternoon.
I cannot find an adapter for backward compatibility. Please do check.
I see Metabo have a new(?) Multitool that has led lights and what looks like (not sure) the new fein bosch starlock type of blade fixing and old style blade fixing. I only saw the video earlier so I msy be incorrect with my observations.
I am using that Metabo 18V multicutter which is an OIS machine - it has an adapter for Supercut/Vecturo blades which is very simple and does the job well. Since I have mostly Supercut blades I am using them on the Metabo.
I was surprised to find that they shipped the machine with an adapter for Supercut blades - but it is very welcome indeed. The adapter does not fit other machines AFAIK though.
The Metabo machine is a very good multicutter. The on/off switch is VERY stiff but it might have to do with the vibration of the tool (keeping it from accidentally shutting off). The vibration level is not too bad.
Festool: CS 50EB precisio set, Domino DF500, DF XL 700, OFK500 edge router, OF1010 router EHL65 planer, CTL Mini/Midi Vac, CTL 26 vac MFT800+1080 tables
DSC-AG Grinder, RAS 115
Drills: T18, BHC18, CXS.
SysLite KAL II, SYS Rock.
Sys- and Sortainers galore.
