I have not experienced any issues with resawing in the 6 years I have had the N4400. Below is an example using a 1/2" Woodslicer blade. Incidentally, I do not like these blades as they wear quickly - I much prefer a 1" bi-metal Woodmaster 1 1/2 tpi for resawing. Note the widely set teeth - too many teeth and the gullets will clog ..
The other aid is a resaw fence, which I made ..
I do not have - and never have had - the ceramic guides. The standard ones work just fine. The sparks in your photo appear to be coming from guides that are rubbing on the blade. They may be too far forward and touching the teeth.
The basic fence I received was a degree off. I filed down the runners until it was perfectly square.
The blades are placed on the wheels/tyres in such a way that they spin smoothly. I tighten them progressively. I make no issue of where they sit on the wheel. Tension must be correct for your size blade.
Check to see if the rubber drive band is tensioned tightly. If it is loose you will lose power. Too little power and the blade will wander.
Incidentally, I added a rule to my bandsaw. It is made from stainless steel. The screw holes are slotted to enable fine adjustments ..
