So I got it.
Loved it all the way through assembly--really beefy cart, nicest wheels I've seen in a while, clever accessory bag...
Got to the gun and the doubts arose. It's junk. Milwaukee is so full of it for claiming it's a $700 dollar value. I've seen better guns in Harbor Freight. It's all chromed brass and PAINTED aluminum. The tips they provide are of dubious quality. The tip guard is too small and tight to the nozzle. The hvlp hose is just super cheap plastic with plastic connectors.
The thing only has controls for the pump, with no control for the turbine.
To prime the pump and get material to the gun, you have spent nearly a half gallon, so good luck with shooting the good stuff (and the cleanup).
So, to the spraying (in hvlp)--lame. Just can't atomize and the pattern is inconsistent. Playing with the only control (pump) yielded unsatisfactory results in both directions. Then it sputters.The pump kicking in and out varies the quality of the spray a great deal as you spray.
The only way to get a decent and consistent pattern is to run the pump way higher than recommended, but then the material is coming out WAY more than you can handle, at least for waterbourne clear...
So, back to the Home Depot it goes.
Probably would do well spraying 5 gallons of exterior latex at a time.
I'm curious if anyone here got theirs going any better.
Also, wondering if there is such a thing as a tip smaller than .010, as it seems that might make a world of difference.
