Author Topic: MFT/3 Fence and Square ... TSO GRS-16 PE?  (Read 7524 times)
Offline Bugsysiegals
Re: MFT/3 Fence and Square ... TSO GRS-16 PE?
« Reply #90 on: January 26, 2021, 03:01 PM »
BTW, how did you end up cutting the Incra fence and getting a decent finish?
Offline 08G8V8
« Reply #91 on: January 26, 2021, 03:23 PM »
I used a hack saw and a grinder with a cutoff wheel to get it close, then just used a grinding disc to get the vertical webbing close to flush, and then used a file to get it flush or very close to flush.
A band saw would make much quicker work if it, but don’t have one.
« Reply #92 on: January 26, 2021, 03:49 PM »
Thanks ... same here ... no band saw as I always find some other tools I think I will use more often.
