Our decisions are typically based on the available data so I always appreciate feedback whether it agrees with or goes against what I've said.
FWIW - I REALLY enjoy 8020. As you may know, my outfeed table is built with 8020, and I was considering to build my Kapex miter station out of 8020. As far as my MFT fence, the stock fence wasn't good enough, but I decided to use an Incra fence rather than 8020 mainly because I've bad vision in my Left eye and an astigmatism.
I can line up an end stop to a measure and it will look different with both eyes open and will also look different between each individual eye opened even if I move the open eye directly over the mark! Because of this, and maybe even if I had better vision, I really like being able to calibrate a rule/end stop system once, and be able to quickly drop the end stop to the measure, move it, move it back, and confidently reproduce the exact same measure, as quickly as possible. Not only is it quick and accurate but because of my eyes and desire to get an exact measure it saves me a good deal of time ... and it's not just for predefined end stop points but any point on the scale.
Another bonus is my fence is 99% off the table which gives me a generous cross cutting capacity when compared to setting up 8020 after the back row of holes ... I suppose I could fabricate brackets for 8020 to use the side rails so this isn't a concern. The downside of mounting to the rail profile is that it takes a minute to reinstall as opposed to bench dogs. I hardly need to switch back and forth as I don't get much time in the shop but certainly can appreciate that convenience for the times you do use it.
All that said, I just made a video to illustrate the maximum deflection with me purposefully bending the fence back with a lot more pressure than it should see in reality to show the maximum possible deflection. From what I see it seems my fence is very solid and reliable under normal usage but you can judge for yourself. But even if the fence is solid, the guide rail requires more effort than I'd like, and is not always consistent thus why I really like the TSO guide rail with parallel guide rail. You still think it wouldn't be consistent in this usage?
I've some people over but will update the video shortly ...
