Author Topic: MFT Hole Jigs  (Read 31777 times)
Offline Jiggy Joiner
Re: MFT Hole Jigs
« Reply #150 on: August 10, 2019, 10:26 AM »
@Cheese Thanks, I had to change the avatar, as it was causing unrest in the grand kid camp (favouritism)  [doh]
Your test showed more movement than I imagined, I know there will be some but, that's an eye opener. I suppose it could also work the other way round. Like some that have had the misfortune of the slop or play in their Parff sticks, yet test cuts showed them to be square?
I wonder if, and how much play there might be with a CNC?
Offline Papas Woodshop
Re: MFT Hole Jigs
« Reply #151 on: August 10, 2019, 05:13 PM »
Is MDF the best material for making a table like the festool MFT table? Oner picture on the thread looks like melamine covered MDF.
Mike
Papa's Workshop
Re: MFT Hole Jigs
« Reply #152 on: August 11, 2019, 09:48 AM »
Don’t know which bushing is required by the Woodpecker jig but the Festool 20mm bit does work in the Festool OF 1100, and 1000, and 900 too.
Woodpeckers uses 2 different proprietary bushings along with a 1/2" Ø router bit to produce either 20 mm or 3/4" Ø holes. So while the Festool 20 mm bit will fit a 1010 router, the Woodpeckers hole boring jig system is centered around using a 1400 router, or equivalent that will accept 1/2" Ø bits.
Re: MFT Hole Jigs
« Reply #153 on: August 11, 2019, 11:13 AM »
Does the Festool 20mm bit work with the Woodpecker bushing? Maybe that’s what you ended up using and I didn’t read carefully enough.
Re: MFT Hole Jigs
« Reply #154 on: August 11, 2019, 11:33 AM »
It works wonderfully...it's just that you need to make a bushing for the Woodpeckers bushing.  [eek]
Personally, I'm surprised that they decided to release it as a regular part of their product line. In my mind it's still in the development stage and should be offered only to experimenters. It's not a very elegant solution to produce either 20 mm Ø or 1/2" Ø holes.  [crying]   [crying]
Offline Bob D.
Re: MFT Hole Jigs
« Reply #155 on: August 11, 2019, 02:22 PM »
Cheese you're making a straight plunge but that doesn't take the movement of the bushing guide plate snapped into the base of the 1400. That potential movement is still there,, and even though you are now not applying lateral force to it there is still the possibility that it can (or WILL) move when withdrawn and placed in the next hole in the template.
It seems to me that another brand plunge router (PC690/890, Milwaukee, DeWalt, you name it) that has a fixed base and uses PC style bushings would be a better choice along with your adapter bushing to eliminate any lateral movement.
I have a OF1400, and at least 6  other routers. But after seeing what you have shown us all with your tests I will never rely on the OF1400 for accurate guide bushing work.
« Last Edit: August 11, 2019, 02:24 PM by Bob D. »
Re: MFT Hole Jigs
« Reply #156 on: August 11, 2019, 03:23 PM »
I agree 100% Bob... [thumbs up]  That's the reason I rely on the 1010 for all of my guide bushing work. Sometimes when you go down one of these rabbit holes it's a good practice to just take a breath and think for a minute. Note to self, I really should have fabricated a guide bushing adaptor for the 1010 instead.  [doh]
However on a larger scale, had I known what I know now, I'd have purchased the LR 32 system instead as I already have a holey rail. I would take the $190 for the jig, $60 for the Whiteside 1/2" bit, and $70 for the Festool 20 mm bit and apply that to the cost of the LR 32 instead. I'd then have a piece of kit that was more than just a one-pony show.
I exchanged several emails and photos with Ed from Woodpeckers and he confirmed my results. It was in one of these exchanges that he stated that Woodpeckers was recommending the jig for hold down purposes only...not to be used for precision alignment or cutting.  [eek]
Offline rylim
Re: MFT Hole Jigs
« Reply #157 on: November 05, 2020, 11:30 PM »
I'm planning to get the hole boring jig from Woodpecker and which one do you guys recommend? Metric or standard?
Sale: Festool 498899 Assorted Domino Beech Tenons Set with Cutter Bits (5-Bits)- New - $265
Offline Grev
    • Follow me on Instagram
Re: MFT Hole Jigs
« Reply #158 on: November 06, 2020, 07:03 AM »
It's really your preference, however, I think there are more options for 20mm bench dogs and the Woodpecker MFT square (which I highly recommend) is designed around the 96mm hole pattern and 20mm holes.
Offline acer66
Re: MFT Hole Jigs
« Reply #159 on: November 13, 2020, 08:49 AM »
I am going to try this but with the Bosch router adapter plate.
Offline cubevandude
Re: MFT Hole Jigs
« Reply #160 on: November 16, 2020, 01:46 PM »
If you have festool this video is for you.  I have Makita and went with the Parf Guide Mk1.
Online Peter Parfitt
  • Magazine/Blog Author
Re: MFT Hole Jigs
« Reply #161 on: November 16, 2020, 02:08 PM »
Hi Everyone
I have seen many references to the Parf Guide System -SPOILER ALERT as I have an interest but...
How many of the producers of the other methods have published an uncut video of a 5 cut test using their system?
This is important as it is accuracy that counts.
Offline box185
Re: MFT Hole Jigs
« Reply #162 on: November 16, 2020, 02:25 PM »
I think this approach is worth a look if you already have the LR 32 system.
DIY MFT using the LR32 kit
Online afish
Re: MFT Hole Jigs
« Reply #163 on: November 16, 2020, 04:01 PM »
Peter is correct.  I originally wanted the Dominofix but no one had or would do a 5 cut test. So Peter got my money and I purchased a MkII from axminster (they are great to deal with by the way) I will say its not the fastest process to do a full 4x8 top and if you are doing MDF top the vacuum adaptor is a requirement NOT an option.  I still like the looks of the dominofx and think it would be faster but havent found any proof of accuracy.
