I am in a position to put some money back into my shop, and normally how this work is that I’ll identify my most pressing need and address it. I have quite a few things on my long term outlook but I can’t decide what to address right now because everything seems to be right about the same urgency level from where I look.
I have a 11’6” (3.5m) square shop that has pretty much anything I would need to complete a given project. It’s tight, but it works. But I can’t add something like a CNC, which I would greatly benefit from. The size factor plays into somewhat in my thinking. Here I’m asking what you would address next if you were in my position. My finances are fine, this is money set aside specifically for this purpose, so I’d appreciate it if we can stay on topic.
I have on my long term wish list the following: a Kapex, TS75, Domino 700, Rotex of some sort, a spray solution, and a welder. For purposes of this thread I am omitting the welder because I have the one I want picked out and am getting it in August. I recently got a couple TSO products to help with my sheet goods, and will also likely pick up a Seneca parallel kit. What do I build? To this point smaller furniture for my house and set pieces for a local theatre company. Upcoming projects are a computer desk, tall bookcases, and maybe kitchen cabs.
Kapex – I feel like this may be inevitable, but it’s so much money to address some minor issues. My miter saw (Hitachi C12RSH) works fine, but is brutal on the dust collection, and I sometimes don’t trust the accuracy at 90 degrees. I also don’t use the miter capability much and the compound cuts at all because it isn’t great to do and getting back to 90. I really would be gaining convenience here for the trade of a big chunk of change and a little bit less capability. The Kapex is only about 15 pounds lighter than the Hitachi, which I thought would be more. I could take it outside when I needed to cut boards longer than shop can handle. Some situations that could be handled by the jigsaw, though.
TS 75 – This would be very helpful in jointing boards. I can also do this with my TSC 55, just with a bit less capability and power. I do have a 6” jointer I can do this on, my issue with the jointer is that I am limited to about 6.5” width and this doesn’t solve that. Expands my abilities in a very specific case.
Domino 700 – Will be added one day, just perhaps not now. No projects on my radar that the 500 can’t handle and be better suited. Won’t be selling the 500, so the ability to do both with the 700 isn’t a big selling point. Also the most expensive thing on my list and needs tenons on top of that. Probably the thing I most won’t do right now, and will wait until a need arises.
Rotex – I thought for sure I would grab a RO150 to pair with my ETS 150 (and DTS and Pro 5) at the first opportunity. Again, though, I don’t have a huge need for stripping paint in my upcoming projects. I absolutely do want that ability, and have two dressers sitting in my house right now that I would elevate up the list, but I do so enjoy my ETS. Alternate is the Bosch GET-75N, but I lose the advantage of having the paper already. I am also considering the RO90 for the ability to sand narrow stock (which I sanded with my 150 on this last project) plus the delta head, which I don’t particularly enjoy with my DTS. Downside is that I have to buy not one but two new sets of papers.
Sprayer – I am debating building vs buying new kitchen cabs, and if I build I will have a need to paint them white. I have a 8 gallon compressor, so I don’t think a HVLP gun from HF or somewhere would fit the bill (but would be ecstatic if it could). Otherwise, my finish method of choice is hand applying Arm-R-Seal. I was looking at either a 3 or 4 stage Fuji if I went this route, but I would be 100% spraying outside in the elements.
What would you add to your arsenal?
