I saw this in my inbox days ago and am surprised it hasn't popped on the FOG yet. Available through SauterShop, it appears to be a pretty straightforward method for boring a 20mm x 96mm grid pattern in a top, without the issues introduced with compound error in systems that rely on indexing a smaller template on previously bored holes.
At 1200mm x 800mm this is larger than a standard MFT/3 top, and I see no reason a person can't easily center or index the template for a MFT.
Note that the holes are 30.2mm diameter, which should perfectly accommodate a 30mm bushing. Also note that the assembly does away with using the 20mm holes for alignment (I never did fully understand the desire to use holes which are destined to get fouled or wallowed-out as a precision setup system), instead relying on a different set of holes for track alignment, which has the added benefit of allowing a variety of angles to be quickly and accurately used.
This top style has been sold by Sautershop for years, it's just the template which is new.
I've ordered plenty of tools, parts and accessories from SauterShop and found them to be a great resource, easy to work with and straightforward international shipping.
https://www.sautershop.com/multifunctional-tables/diy-multifunctional-tables/vario-master-mft-steel-template/
