Author Topic: Makita LS1019L miter saw mini review  (Read 45589 times)
0 Members and 3 Guests are viewing this topic.
Offline Duane Franks
Re: Makita LS1019L miter saw mini review
« Reply #60 on: June 25, 2018, 03:12 PM »
Does anyone know if Makita has addressed the blade tracking issue? There is a local supplier who has these on sale for $449 ($100 off) and I am looking at this saw as a possible addition to my shop. Thanks, Duane
Offline RKA
« Reply #61 on: June 25, 2018, 03:18 PM »
Nothing that I've read about yet.  Seems like it's in the hands of the end user for now.  Where is this local source?  I've been keeping an eye out for a friend in the market for a SCMS and haven't seen a price that good yet.
-Raj
Offline jpmeunier
« Reply #62 on: June 25, 2018, 04:02 PM »
Has anyone seen a zero clearance insert available for this saw? If not, I guess I need to make a template.
Offline JYip
« Reply #63 on: June 25, 2018, 04:28 PM »
I bought this saw recently. The table was flat and the fence was square. However, like most others, the bars that the saw head travels along are not parallel. I discovered this when I had a cut mark on a board and was lining the mark up with the laser line. As I pulled the saw head back towards me, I noticed that the laser line would move laterally relative to my pencil mark. The final cut was not square. I decided to just return the saw instead of trying to align the bars.
Hope this helps.
Jeff
« Reply #64 on: June 29, 2018, 07:53 PM »
RKA, Sorry for the late response. The local supplier is Jerry's Home Improvement in Eugene, Oregon. I think the price is good until 8PM pacific time today, but may be worth a call to their tool department @ (541) 689-1911.
Offline RKA
« Reply #65 on: June 29, 2018, 09:55 PM »
Thanks!  Your on the other coast but hopefully someone else can benefit!
-Raj
Offline tewic
« Reply #66 on: April 15, 2019, 06:43 AM »
I just got a LS1019L as well. Seems like Makita still has the same issue with the slide being slightly off, even though the blade is square to the fences, on new unites.
I've tried loosening the screws on part #169 as suggested, but I'm unsure on how I actually adjust the rails. With the screws loose (even tried screwing them all the way off), #169 is still as fixed on the rails, as with the screws tightned. I haven't tried applying more force, as I'm unsure I'm actually doing the right thing.
When the screws are loose, is #169 supposed to be adjusted to an angle, or pulled forward/backwards. Or is it the rails that should be pulled or adjusted to an angle?
Offline RKA
« Reply #67 on: April 15, 2019, 07:35 AM »
@tewic It take a bit of force to realign the rails.  Once the screws are loosened, slip a 1x2 between the rails and use that to twist the rails so to speak.  Which way?  Try one direction with a small adjustment and see if it’s better or worse, then you’ll know.
-Raj
Offline tewic
« Reply #68 on: April 15, 2019, 08:08 AM »
Okay, so the rails need to be twisted/adjusted in relation each other, and not both in relation to #169 or their mount on the back of the stand.
I actually thought it was the blade that was not square to the rails, and thus when you square the blade to the fences, the rails are not square to the fences.
Offline tewic
« Reply #69 on: April 17, 2019, 04:00 AM »
I did as @RKA suggested and it actually worked. After half an hour of trail and error it was almost spot on. Thank you so much!
One thing I noticed. When twisting it one way, if I twisted it slightly too far and wanted to twist it just a tiny bit back again, it was prone to going back to it's out of factory position. I'm curious to see if after some time of use, if it will slowly slip back to the misaligned position, or if the bolts on #169 will keep it in place.
Offline Mike Goetzke
« Reply #70 on: July 13, 2019, 10:16 AM »
Thanks guys - worked on my cordless.
Online gearhound
« Reply #71 on: August 19, 2019, 09:33 PM »
Any updates on Makita fixing this issue yet? Really want to buy one, but not too fond of the thought of tweaking this part #169 when it wasn't meant to be adjustable in the 1st place.....
For those that have made the adjustment tweak, I'm curious how it's holding up over the months/years....does it require frequent adjustment. I'll be using it for furniture builds and don't want to be worrying all the time that it's not square.
Offline Jiggy Joiner
« Reply #72 on: August 20, 2019, 03:42 AM »
Once adjusted and locked up, they hold fine. We bought two of them at the same time a good while back.
Out of the box, one had good rail alignment but, the base angle detents were a little bit out. The other had spot on detents but, the rails needed tweaking.
Both saws have been fine since and I like them a lot, I am a Makita fan though but, have to say, my Kapex is a better saw, by a fair margin (at a price)
I honestly don’t know if Makita have sorted the issues now, a salesman told me they had, he also called me young man, despite me being old enough to be his grandfather  [blink]
I agree too, these saws should not need all these adjustments out of the box. When I‘ve mentioned this at the point of sale, they say it could be a transport issue.
Why not call Makita and ask them, I have called Makita UK on occasion and they’ve always been helpful.
They are nice saws for the money, when set up right, either from the factory, or by user adjustment.
Offline Francis_Beland
« Reply #73 on: September 19, 2019, 01:16 PM »
Anyone want to make a little video (or pictures) on how to realign the bars? I also have the problem and I tried doing it. However, I'm not sure what to do exactly and since I don't want to brake it, I will need to get graphic help to be sure I'm doing the right thing.
Thank you
Offline Maero
« Reply #74 on: February 08, 2020, 05:29 PM »
I just recently got my LS1219L.
Nice saw in every way... almost. The blade was not parallell to the rails, and the sliding cut was doing a curved motion.
I knew about the Wood Whisperer having an issue with this. And he had stated something about other people adjusting the rails. But he ended up returning the saw.
So I really tried to understand how this could be adjusted. I thought to myself that surely Makita can't make such a good saw with this basic fault. Also my saw is a somewhat updated version and manufactured late 2019.
But no. I could only conclude that this is a problem in the casting of the whole gantry. Adjusting the rails in any way could, in my mind, not change this fact.
I also read about others who had received the response from Makita that this can not be fixed without completely replace the saw unit.
I remembered that during my research for this saw I had seen some discussion about "two screws".. Which two screws!?!
Finally I found this thread again.
Voila! A minor tweak with twisting the rails a miniscule amount in relation to one another, drastically moved the blade position.
First I thought this had to change the bevel angle. And yes it probably does in theory. But #1 It's such a small amount, and #2 It's just as likely to also being adjusted in the correct direction.
A big thanks to this thread!
« Last Edit: February 08, 2020, 05:37 PM by Maero »
Offline John1102
« Reply #75 on: February 08, 2020, 08:40 PM »
Can anyone post a picture of which screws on the Makita saw are for the adjustment?  Thanks!
Offline Lbob131
« Reply #76 on: February 09, 2020, 09:17 AM »
It the two allen screws   at the end of  the slide  rails afaik.
« Reply #77 on: February 09, 2020, 10:07 AM »
Go here:
https://www.protoolreviews.com/tools/power/cordless/saws-cordless/makita-10-cordless-miter-saw/34117/
See the black knob in center of picture on the top slide rail? To the left is a casting holding the upper/lower bars. See the two black spots on this casting? Those are the allen screw locations.
Offline Maero
« Reply #78 on: February 09, 2020, 04:47 PM »
The thing is that these are not adjustment screws. To me it doesn't even make sense. But it works.
Find something to use as leverage between the two rails. You need to twist them (in relation to each other) in a controlled and gently manner in the outwards end where the two screws are.
Loosen the screws and while tweaking the rails - screw them back in to "lock" the rail alignment.
You can think of the lower rail being pushed in the direction you want the blade to move at the end nearest to you. Maybe in a factor 2:1
I also want to add that the curved cut that my saw made previously also went away.
« Last Edit: February 09, 2020, 04:52 PM by Maero »
