Author Topic: Makita LS1019L miter saw mini review  (Read 51352 times)
Offline James Biddle
« on: September 30, 2017, 06:30 PM »
So, I've only had my Makita LS1019L for just over 2 months now after selling my Kapex and I thought I'd give some of my initial observations of the new tool compared to the Kapex.
1. Dust collection.  The dust collection is good, not Kapex good, but good.  It has a hose diverter where it suck from both around the blade and behind.  I'm not happy that the hookup for the DC points downward at an angle, making it more challenging to hook up on a closed bench, but that's a minor bit.  Advantage-Kapex
2. Use against a wall.  Both tools have dual fixed tubes the saw slides out from so both can be put close to a wall.  You really can't put either against a wall and swing the miter without hose issues, but both are really well done.  Advantage-both
3. Quality of cut.  Using a good cut technique has a major impact on any miter saw, and the Makita is no different.  I was able to get perfect cuts (I was only cutting base cap molding on the Makita) with good technique.  If I pushed the cut too fast I got fuzz and if I raised the blade too quickly, I sometimes got flung the offcut.  Advantage-both
4. Accuracy of the setup out of the box.  I realize this may vary greatly from tool to tool, but my Makita needed adjustment out of the box. The good news is that the bevel adjustment is VERY easy with the attached hex wrench and access to the adjustment points.  The miter was dead on.  However, the Kapex required no adjustment out of the box.  Advantage-Kapex
5. Squareness and flatness of the fence and base.  Here, I had issues with both.  My Kapex base was not flat along the fence and non-adjustable.  The fence was dead-on though.  On the Makita, the base and stationary fence were dead on, but the removable fence had only a minor adjustment and I was unable to adjust the removable fence at the outer end of the base where there is a post and hole casting.  The effect was that I could not get perfectly cuts where that surface was referenced.  Advantage-neither
6. Ergonomics.  Neither machine is a pain to use, but my preference was the horizontal handle on the Makita over the vertical on the Kapex.  The laser switch was the index finger above the hand one the Makita making it easier to switch on and off during the process.  It was also easier to lower the blade to align the cut line on the Makita. Advantage-Makita
7. Laser.  Makita laser is only on one side, so the Kapex will win here.  Also, the Kapex laser was dead on at delivery, and I still need to adjust the Makita about a 64th, but have not got that far yet.  Advantage-Kapex.
8. Motor.  It's unfair to rate the Kapex against the Makita. The Makita is new with little track record.  Id does not seem to bog down in any of the cuts I've made, nor should it cutting the base cap I've used.  Advantage-neither
9. Hold downs.  I liked the Kapex hold downs and did not like it came with only one.  I don't like the Makita at all and don't like it came with only one.  Neither tool allows for 2 hold downs to be used with full miter rotation. Kapex got the hold down right and just did not include enough.  Makita falls flat here.  Advantage-Kapex
10. Miter and bevel adjustment.  Mixed bag here.  Kapex is really easy to unlock and rotate the bevel and use the button to release the stops.  Makita has the unlock at the end of a tube and then you manually pivot the tool and use buttons to release the stop.  On the miter, I found it easier to adjust the Makita close to the detents than the Kapex.  Both are a pain and the new innovator will have some method to rotate the bevel like Festool does with the bevel.  Advantage-neither
11. Price. I paid $509 for the Makita and the Kapex sells for $1,475.  Advantage-Makita
Overall.  The Kapex is clearly a better saw to me, while working.  The Makita has incorporated many of the Kapex's fine features while keeping the price at a level WAY below the Kapex.  I purposefully did not address portability because although the Kapex is easily more portable, you can buy two of the Makita and leave one in the shop and one in the truck and have a backup saw in case of emergencies.
Offline Peter Halle
Re: Makita LS1019L miter saw mini review
« Reply #1 on: September 30, 2017, 06:38 PM »
I appreciate a well done comparison and you have achieved that it my mind.   [thumbs up]
Offline Brandon
« Reply #2 on: September 30, 2017, 08:18 PM »
Thanks for the review. I am debating the Makita or a Bosch to replace my Kapex. I’m going to roll with Kapex for a bit longer but still live in fear of another motor failure. Mine went in less than a year and a half but has been fine since, about 3 years. I’ve since replaced/ modified a few parts on it to keep it going. If not for the dust collection it’s really just an average saw at an above average price.
As for your Makita motor, I will personally guarantee it won’t burn up in less than a year and a half. Send me a PM if it does and I’ll buy you a new one. I’ve had the same Makita circular saw for 10+ years, no issues.
Offline Lbob131
« Reply #3 on: October 01, 2017, 08:15 AM »
Is this saw available in the UK?
I have the older  tried and trusted  LS1013. As does an acquaintance.
And he is looking for a suitable  replacement.
Offline John1102
« Reply #4 on: October 01, 2017, 01:46 PM »
I am interested in this saw however I have seen some reviews by individuals such as the wood whisperer that state the saw doesn't stay square co-planer as the blade is slid forward.  The link below is from his video on his Instagram account.  I am wanting to get this saw but not if it can't cut square I am curious what others will say on this subject or makita dealers who carry the saw.
https://www.instagram.com/p/BX1ZVFMhTzS/?taken-by=woodwhisperer
Offline fuzzy logic
« Reply #5 on: October 01, 2017, 01:48 PM »
UK - Sitebox Ltd
https://www.sitebox.ltd.uk/makita-ls1016-110v-240v-mitre-saw-260mm-blade-omak_ls1016
Haven't checked anywhere else.
Fwiw, be interested in what reviews say 12/18 months.
Richard (UK)
(Edit: see John1102 posted as well)
(Edit: Apologies! My link is to a different version. Thanks for being on the ball John1102)
« Last Edit: October 03, 2017, 05:09 AM by fuzzy logic »
Decent people do the right thing - always?
Offline John1102
« Reply #6 on: October 02, 2017, 08:31 AM »
The link used by fuzzy logic (UK) isn't the saw model being discussed in this thread, which is the newer Makita LS1019L model that has the forward fixed rails to compete against the Festool Kapex model.  Thanks.
« Reply #7 on: October 02, 2017, 10:19 AM »
I had the same problem out of the box, but I just adjusted the saw to 90 by moving the detent ring.  Now mine tracks straight, not like he is showing.  I don't have the Kapex anymore, but I think it adjusts the same way, doesn't it?
Offline RKA
« Reply #8 on: October 02, 2017, 12:12 PM »
The issue WW experienced was that the saw blade wasn't parallel to the slides.  So even if you adjusted the blade (like you described) so it was exactly 90 degrees to the fence, when you pulled the blade back, the blade slides out in a skewed fashion.  This is a manufacturing defect, not something that you can adjust for.
-Raj
« Reply #9 on: October 02, 2017, 03:56 PM »
From the video Marc posted, it looked like the blade started out about a 1/16th away from the square and ran in towards and hit the square at full extension.  The only thing the square is testing is whether the 90degree cut is calibrated correctly.  Looks no different than if I set my miter about a half degree or so off of 90.  It that's the case, he needs to recalibrate the 90 position, which is as I described.  Am I missing something?
Offline John1102
« Reply #10 on: October 02, 2017, 04:38 PM »
It's not a squareness issue. Since the square is placed offset of the blade about 1/16" an inch yet still square to the blade off of the fence as the saw blade is pulled out along the rails at the end of the cutting length it begins to come into contact with the square.  It appears to be a manufacturing defect with the rail carriage as was my understanding from the video.
Offline Getmaverick
« Reply #11 on: October 02, 2017, 06:16 PM »
Curious to see how Makita responds to this co planar issue.
Offline RKA
« Reply #12 on: October 02, 2017, 08:53 PM »
6:15 in the video
-Raj
Offline glass1
« Reply #13 on: October 02, 2017, 09:04 PM »
I have found the blade not perfectly parellel to the slides to be a common issue on almost all scms. It’s the first thing I look for. I clamp a wide blade board to the saw. It does not matter the miter angle. With thread pushed all the way back I do,a plunge cut and with the blade still running I lift the blade up and pull it all the way out without cutting. Than I plunge down and mate the cuts. If the do not perfectly line up than the blade is not parellel to the slides. Most saws have no adjustment to fix if the blade is not parellel to the slides. My ls1019l is perfectly parellel. Dust collection is very good. Power is excellent.  Slides are smooth. Detent override. Easy to use safety and one can hold the blade guard up with the thumb. Flat table. It’s a great saw.
Offline glass1
« Reply #14 on: October 02, 2017, 09:05 PM »
Head pushed all the way back not thread...
Offline nms
« Reply #15 on: October 05, 2017, 08:40 AM »
6:15 in the video
This is unfortunate. Why does it seem so difficult to find an accurate SCMS for a decent price?
This Makita seemed like a contender, but I'm not satisfied with the accuracy issues.
I feel like there would be more side to side deflection with the way the rails are oriented on this vs the typical side by side layout in Kapex and others.
« Last Edit: October 05, 2017, 08:43 AM by nms »
Offline glass1
« Reply #16 on: October 05, 2017, 01:23 PM »
My Makita ls1019l is solid side to side. The old Dewalt dw708 had stacked slide rails it was solid as well. I like the Makita better than the kapex  in every way  except for the large bevel scale on the kapex  and the Makita weighs 10 lbs more. I still think the. Eat way to check if the blade is parallel is by lining up a chop cut with a push cut as I mentioned before. It does not matter the angle.
Offline RKA
« Reply #17 on: October 05, 2017, 03:34 PM »
@nms
Just buy it locally from a retailer that turns over stock regularly.  If it has this issue, you'll be able to confirm it quickly and return it.
 WW got his just after they were introduced.  His report in the video was some time after all this happened.  Granted, we're talking about months and not years, but it's still possible Makita has already resolved the issue and if they haven't, I'm sure they will soon.
-Raj
Offline nms
« Reply #18 on: October 05, 2017, 09:11 PM »
Have you done many test cuts on wide pieces and checked closely for deflection? I'm worried about it with 2x6 or 1x12 boards particularly.
@nms
Yeah that does sound like the best way to go. It seems like the dust collection is better than most alternatives. I was checking these out, but the dust collection is not good and no one mentions them around here: http://festoolownersgroup.com/other-tools-accessories/milwaukee-2734-10'-sliding-compound-miter-saw/
Offline glass1
« Reply #19 on: October 05, 2017, 09:16 PM »
So far deflection is a non issue. Why does this saw concern you with deflection ? I find it rock solid. Now that , Milwaukee 10” is a hunk of junk cheap feeling thing which is odd because their 12”maybe a beast but it sure feels solid to me.
Offline lwoirhaye
« Reply #20 on: October 05, 2017, 09:55 PM »
I think it's what is called "heeling" in a table saw.
Offline Arthur444
« Reply #21 on: October 06, 2017, 06:50 AM »
I also bought the Makita LS1019L to replace my 13 month old Kapex that burnt out. I much prefer the ergonomics on the Makita. The horizontal handle and the blade lock can be squeezed at the same time feels better. I also really like that the guard is on the outside of the blade housing so you can hold it up with your thumb if need be. I hate the guard on the Kapex, it would catch on your piece and lift up while cutting if your not careful. The way you have to twist your wrist on the Kapex to push the top safety switch is carpal tunnel stupidity. The Makita has a 15 amp motor compared to 13 amp on the Kapex. I personally don't see much of a difference in dust collection. I use a Fein dust extractor that is dedicated to the saw and it seems to work well in my small shop. The two sided laser is useful and the line is a little finer then the Makita but again the guard on the Kapex has really small slots where the laser shows through and as soon as the guard gets dirty you can't see the laser. The Makita guard has slots about 1/4"x 2" so you can see the laser better and the on off switch is placed in a better position. If the two saws were priced competitively you could give advantage to either one depending on your preferences but with the Kapex costing 3 times as much no way is the extra cost justified. Really the Kapex isn't worth more 650$.  My Kapex basically had the entire motor and gear housing replaced, if anyone is in the southern Wisconsin area and wants what is essentially a new Kapex for 1100$ I'll be listing it on Craigslist today.
Offline Oldwood
  • Alberta, Canada
« Reply #22 on: October 13, 2017, 01:53 PM »
Great trick for checking to see if the saw blade is aligned to the travel. Thanks for that. I returned my first saw the second one was better but still not acceptable. I am involved in a discussion with Makita service to see if this is something they can resolve or if I need to look for another brand of saw.
Confucius
Offline duburban
« Reply #23 on: October 13, 2017, 11:28 PM »
Im getting the sense that some of these makita saws are working and some not. Do we think this is related to early vs late or current production batches or across the board.
This feedback is critical, just trying to summarize the consensus
helper: i used a festool "circular saw" to do something simple and it made it really hard
me: exactly, it makes simple cuts complicated and complicated cuts simple
Offline glass1
« Reply #24 on: October 14, 2017, 01:45 AM »
I do believe if one loosens the 2 Allen screws that hold the front bar to the rails the rails can be pushed left or right and held in position when retightening.
Offline Oldwood
  • Alberta, Canada
« Reply #25 on: October 14, 2017, 10:50 AM »
I had a talk with the service department in Vancouver and he sent out some inquiries within the company and it looks like they are aware of the problem and will be dealing with it. The service rep went through a few saws they had in stock and he said most had the issue to some degree and he did find one that was good.
They have a 10" precision ground plate they mount in place of the blade then put a square against the fence and the plate then draw the saw head forward.
I talked with the store I bought the saw from and they will let me check a few saws to see if I can find one within reasonable tolerances. I like the saw and am willing to do some work to find one that will work for me.
We will have to wait to see what they do about this but I think something will be done shortly.
Confucius
Offline glass1
« Reply #26 on: October 14, 2017, 01:53 PM »
Just loosens the 2 screws that attach the front bar to the rails than the bars can be adjusted til the blade is parellel and hold and retighten. May take some trial and error.
Offline Josh F
« Reply #27 on: October 18, 2017, 01:29 PM »
I created I account here just to say. I had the same problem with the saw. Just got it yesterday. I did what was mentioned above and now it cuts perfect. The rails are not co planar to each other and just a little tweak and they are perfect.
   On a side note I love festool, have a half dozen of their tools. I just couldn’t justify spending almost 1500 on a scms, when my buddies motor burnt out on his winthin the first 3 months.
Offline Oldwood
  • Alberta, Canada
« Reply #28 on: October 18, 2017, 07:38 PM »
Josh or Glass could you tell me on the attached diagram are you talking about part #169?
TIA
Confucius
Offline Josh F
« Reply #29 on: October 18, 2017, 09:58 PM »
Yes part 169, I loosened the two Allen screws. Then slid a piece of 3/4 cedar in between the rails. I pushed lightly on it and relighted the Allen screws. It took me 3 or 4 tries, before I figured out which way I was moving the rails, and how it effected the blade and cut. We’re talking tweaking the rail maybe a 1/16”, but it transfer a lot down to the blade.
Offline Oldwood
  • Alberta, Canada
« Reply #30 on: October 18, 2017, 11:03 PM »
Thanks Josh
Confucius
Offline Steven Owen
« Reply #31 on: October 19, 2017, 12:11 PM »
6:15 in the video
The Dewalt 780 is the only affordable Miter Saw left on the market that doesn’t have this issue.  It’s only a matter of time before Dewalt decides to discontinue the 780.  People would hate on the DW 780 and DW 782 because they clock in at 52 pounds.  The heavy duty simple and clean aluminum rods keep the saw straight and don’t allow it to drift out of alignment.
The DW 717 is not machined to the same quality level as the DW 780.  You see a lot of 780’s used in Cabinet and Pipe fitting shops because of their accuracy.
« Last Edit: October 19, 2017, 12:15 PM by Steven Owen »
Festool CT Midi, Festool ETS 125, DF 700 Domino Coming Soon
Offline timbozi
« Reply #32 on: October 21, 2017, 02:14 PM »
Does anyone know of way to check for the parallel issue in store? Without making a cut.
Offline RKA
« Reply #33 on: October 21, 2017, 06:04 PM »
A simple 12” square should do.  But if the blade isn’t 90 degrees to the fence it will be harder to tell.
Set the square with the long leg against the blade and short leg against the fence.  Pull the saw out away from the fence.  If a gap emerges or the blade starts to jam against the square, it’s not dialed in right.
Or you can use a bevel gauge.  If you can set it to match the angle between the fence and blade.  You might need an extra set of hands to hold the saw head Dow and hold back the guard while you tighten the bevel gauge.  Now it doesn’t matter if the miter is set dead at 90.  Then pull the saw away from the fence and observe a gap or binding against the bevel gauge and blade.
-Raj
Offline Oldwood
  • Alberta, Canada
« Reply #34 on: October 21, 2017, 07:04 PM »
I tried 3 saws they all had the same problem. We did not think it was worth opening more boxes as we felt they would probably be the same. I like the saw and Makita service said they were aware of the problem and will call me when they know if or when it might get resolved.
I decided to wait bit and see what happens. I am not without a saw so I will use my old Hitachi for a while longer.
As RKA has already said hold a square against the blade when it is at the back of it's travel then draw the saw forward while holding the square tight to the back fence. If the blade wants to climb your square hold it on the other side and it should pull way from the square and give a indication of how much it is out.
Hope you can find a good one I think it could be a good saw.
Gerry
Confucius
« Reply #35 on: October 21, 2017, 09:07 PM »
The test is simple (checking if bade is parallel to travel)
With the saw at one end of it's travel, place a hard square edge block of wood (heavier the better) gently against the fore and aft teeth on one side of the blade. The block should touch same shaped teeth if the teeth are alternate ground.
Then push/pull the saw to the other position. If the block of wood didn't move you have to do the test on the other side of the blade.
If the block still didn't move the saw tracks and blade are parallel.
Offline glass1
« Reply #36 on: October 21, 2017, 11:34 PM »
I own the dewalt dhs790 and have used many, I guarantee that my blade is not perfectly parellel yet it’s a great saw.  The dewalt suffers from this issue just as many others do. Some saws parellel issues are unfixable others are. The dewalt saws tubes can be an be twisted. The Makita LS1019L blade can easily be set parellel. Just loosen the 2 allen set screws in the bar connecting the rails at front. Actually I could explain it but most  on this site simply will not understand how, but it’s easy peasey. One will need a piece of wood todo so. Just pm if I anybody is really interested.
Offline chileodell
« Reply #37 on: October 30, 2017, 04:57 PM »
HI Glass and Josh F.  I purchased this saw and am trying to adjust the rails. Which way are you inserting the wood to align them? I have tried but am not having any luck.
« Last Edit: October 30, 2017, 05:46 PM by chileodell »
Offline glass1
« Reply #38 on: October 30, 2017, 06:51 PM »
The square or block method only checks for square or angle accuracy, sorry wood whisperer but I am surprised by your lack of understanding. It does not matter the angle that the miter saw is set to to check if the blade is parallel to the rails. Take a 12" wide board put on saw with the saw in fully retracted position make a plunge cut lift head up to fully extended position and plunge down and finish cut. The cuts should perfectly or nearly perfectly line up. some saws can never be adjusted some can. pm me for more detail its to hard to explain it a post.
Offline chileodell
« Reply #39 on: October 30, 2017, 08:18 PM »
So after taking a frustration break I was able to align the slide rails as described by Glass1. Now the saw is tracking perfectly straight. I am ecstatic because I loved everything about the saw and didn't want to have to return it.
Offline dustymc
« Reply #40 on: November 03, 2017, 06:26 PM »
@glass1 I made an account just to say THANK YOU! I got a new saw today, it was about a quarter-blade off on the plunge-slide-plunge test, took maybe 5 minutes of diddling with the arms to get it where it's supposed to be.
Offline glass1
« Reply #41 on: November 04, 2017, 08:07 AM »
No worries. Have fun cutting. It’s a great saw.
Offline Steven Owen
« Reply #42 on: November 04, 2017, 03:17 PM »
At least Makita has an adjustment for the rail.  I had to exchange the Dewalt 782 twice to get one that squared up correctly.
Offline Job and Knock
« Reply #43 on: November 05, 2017, 05:11 AM »
Hmmm... My old DW708 had a tendency to twist in cut noticeably on long one-sided dust cuts (where I was adjusting a mitre cut). I believe that's why DW changed the design to a side by side rail arrangement on the DW718. The big Makita (LS1214) was better than the DW708 in that respect (we ran them side by side for  couple of oak panelling jobs)
I have issues with how miniscule the bevel scale on the Makita is - and the effect that will have on ultimate accuracy and repeatability of cuts. One of the best features of the Kapex is those large, easily read scales. Makita need to learn that we aren't all 25 year old hotshots with razor sharp eyesight.
18 months on with a 110 volt Kapex doing mainly oak, ash and maple and it still hasn't fried, yet. Must be doing something right
« Last Edit: November 12, 2017, 06:11 AM by Job and Knock »
Simplicity is the embodiment of purity and unity
- Shaker maxim
TS 55 - TS75 - Kapex KS120 - OF1010 - OF2200 - Rotex RO150e - Domino DF500Q -  Domino DF700XL
Offline glass1
« Reply #44 on: November 05, 2017, 08:02 AM »
Really. I found the 1019 much more solid than the kapex. No doubt the 1014 and 1214 were solid saws that gave years of use and abuse.  The only 2 things on those saws that was lacking was no 60 degree miter and no bevel past 45.
The only 2 things I like about the kapex over the 1019 are the bevel scale and the weight. Everything else the makita takes it, flat table, better blade guard, standard blades, 60 miter both ways, more power, no carpal tunnel trigger, no leaky arbor, miter detent override, dust collection, and more than likely that pesky motor issue, and of course price.
Offline Cochese
    • The 144 Workshop
« Reply #45 on: November 07, 2017, 08:59 PM »
Would anyone be able to tell me how similar the corded vs 36v versions are? I can only find the cordless one at a store nearby to look at and try out to see some sort of indication of if I would enjoy the corded one.
Offline sheperd80
« Reply #46 on: November 10, 2017, 08:38 AM »
Same here. I toyed with the cordless and liked it but found a few features that were deal breakers for me. The bevel locking knob is a horrible idea, and the button to bypass the 0 stop is in a bad spot so bevel adjustments are gonna be a constant pain. Also the fence wings being removable instead of sliding makes no sense. Sad, i was hoping this might be the next great saw.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Offline todd_fuller
« Reply #47 on: December 22, 2017, 04:06 PM »
To help add knowledge of the adjustment process, I was able to get my saw pretty close today.
I put a steel plate on the bed and put my magnetic dial indicator base with a 0.01mm dial indicator on the plate. I wanted something stable so it wouldn’t influence the measurement. I indicated on the blade near the centerline. Initially it was off by 0.4mm front to back. I moved the saw to the mid point and loosened the set screws. The idea was to move the rails to the point the midpoint was indicating 1/2 of the runout. In the end, it didn’t take as much effort to move the rails into position but it would be easier with a helper to check the runout and tighten the set screws once it’s close. I was able to get it down to 0.1mm over the travel. IMHO, that’s close enough for woodworking.
Offline Ostap
« Reply #48 on: January 28, 2018, 05:07 PM »
This thread helped me to finally understand why I can't get my old crappy sliding miter to cut straight -- yes, blade and rods do not align with each other. Will see if I can find a way to fix it.
Looking at the ls1019l schematics, loosening, adjusting and re-tightening the #169 can only change the rotary tension/preload of the rods. In theory the rods should held parallel by back arm #208 and #169 should provide only a stop for the sledge. Additional stiffness by it should be only a bonus.
I'm glad if playing with the #169 helped you guys, but Makita should have provided stiffer rods so that the saw would cut straight even without #169 attached.
Offline Ostap
« Reply #49 on: January 29, 2018, 02:27 PM »
Spent today an hour or two to tune up my old miter.
I used a precise digital angle box to measure rod parallelism and it worked really well. I attached it to a piece of steel that was wide enough to reach both rods and measured the angle in one end of the rods and compared it with the angle in the other end.
As it turned out, my saw has set screws only for one rod, another rod is held in place with tightening pins [mad] Well, what can you do...
As I could not loosen the rods fully, I connected wide-pad 1.5m long bessey clamps to both end of the rods. It gave me huge leverage to precicely and gently bend the rods to the position. Then tightened screws again, readjusted the fence (which now is in expected position) and voila. All the tuning without any test cuts. The result -- saw has never cut better.
With understanding the root cause of my miter problem, I now appreciate and understand why Kapex has the "stupid" centered handle to carry and plunge.
While I significantly improved my miter for now, I do not expect it to stay adjusted for long time. It is not designed to be adjusted and my tuning was pure vandalism. What I will do though, is stop using the carry handle and always use the leftmost part of the main handle for cuts (both handles are off center). Hope it helps.
« Reply #50 on: January 29, 2018, 05:03 PM »
Love the way you put that!  "If you can't make it perfect, make it adjustable" is the mantra I try to go by. If the manufacturers followed that we wouldn't have to resort to adjustment via pry bar.
Offline chrisfrantzdale
« Reply #51 on: March 21, 2018, 08:57 PM »
This is a side topic relating to this saw but has anyone had issues with the amount of slop in the detents? I haven't used this saw but using the Makita LS0815F I've had problems with the detents. If you loosen the miter-adjust knob and move the saw into any of the detent positions there is maybe 1/2 a degree of slop at each detent. If you jiggle it around there's that much play before you lock it down with the knob, so you could be out +/- 1/4 of a degree or so. Kapex has zero slop at the detents, old Hitachi is close. Has anyone experienced this with the LS1019LS?
Offline John1102
« Reply #52 on: March 22, 2018, 09:06 PM »
Can you post a photo of the screw adjustments on the makita LS1019L?
Offline bananacat
Thanks guys.
« Reply #53 on: March 25, 2018, 11:22 PM »
I noticed my saw was a bit off after 2 weeks of work. Musta got bumped or slid off a tiny bit. Now its back to normal after adjusting the screws on part #169 from the diagram and every so gently fiddeling and checking each cut. Rinsed and repeated the process until it was aligned again.  Did not take to long to adjust properly. Chopped up a few 2x12 cut off pieces i had laying around garage and got it cutting fine, dandy and straight as a arrow in no time at all.
Glad we have this option and know how to fix it now.  I really am loving this saw. So are my crew and co-workers.
Just signed up to say Thanks a million!   [smile]
Offline IOTrav
« Reply #54 on: March 27, 2018, 03:13 PM »
Hey Guys,
After reading this thread I bit the bullet and bought an LS1019L saw.  I've never been afraid of calibrating tools and doing a little extra to make an average tool do the job.  I just could not bring myself to spend 3x money on the Kapex no matter how bad I wanted it.
Short story is I was able to get the LS1019L just so close to working but I just can't quite seem to get it spot on.  If I cut a 12" wide board and then put that cut end of the board on a flat surface I get just a little rocking which drives me bat **** crazy.  I think I am adjusting this thing correctly but if someone would just post a couple of pics or short video showing exactly how to calibrate that would be aces.  I think I am doing what @glass1 is suggesting but just not 100%.
Thanks everyone.
Offline CumminsDiesel
« Reply #55 on: March 28, 2018, 03:14 AM »
The more I read about this saw,the more I want the Kapex!  [smile]
Now I understand why Kapex cost 2 or 3 times more than any other miter saws: pure engineering!
« Last Edit: March 28, 2018, 03:21 AM by VaDimZH »
Re: Thanks guys.
« Reply #56 on: March 28, 2018, 03:20 AM »
And because part #169 is NOT designed for adjusting,
adjusting it every time gives more room for the next errors.
« Last Edit: March 28, 2018, 03:44 AM by VaDimZH »
« Reply #57 on: March 28, 2018, 03:26 AM »
The bevel adjusting just crazy and unsafe: https://youtu.be/d8alXyFXTxQ?t=10m39s
Offline jokout
« Reply #58 on: May 02, 2018, 10:21 PM »
I know this is an old thread but I have to give a nod and a big thanks to Glass1!
Recently picked up the cordless version of this saw, XSL06 PT, and ran into this same issue on 2 consecutive saws! After several hours trying to make either workable, I was ready to write this saw off as a miss and go back to my old Bosch slider, 20# heavier and the size of an aircraft carrier, but I really liked this saw so much I didn't want to return it! In a bit of "what do I have to lose", I tried the Glass1 fix on the XSL06 rails and I was shocked how easy AND effective this is! This is NOT a big adjustment, it is more of a "tweak" to the rods, I actually over compensated on the first go and caused the same issue on the opposite side of the blade, again a fine adjustment! After a little trial and error, the chop cut and slide cut align perfectly!
Re-squared the saw again with a square and then fine tuned it using the 5 cut method on 12" and I called it good enough at .0003" for all 5 cuts!
 Really love everything about this saw, excellent ergonomics, power, dust collection, weight and footprint, and now accuracy!
  Thanks again to Glass1!
Cheers
Offline glass1
« Reply #59 on: May 31, 2018, 04:14 PM »
I am glad that the saw is working out.
Some thoughts on this saw. I do like it as the table is flat, tons of power, compact, smooth rails and motor, great dust collection, 60 degree both directions, detent override, excellent capacity as it can cut 5 1/2” vertical, once dialed in it has been accurate,  and more. Some things not as good as kapex, weight, not as elegant bevel adjust and small scale and awkward bevel detente pin, laser not as good and no shadow line like others.
Offline Duane Franks
« Reply #60 on: June 25, 2018, 03:12 PM »
Does anyone know if Makita has addressed the blade tracking issue? There is a local supplier who has these on sale for $449 ($100 off) and I am looking at this saw as a possible addition to my shop. Thanks, Duane
Offline RKA
« Reply #61 on: June 25, 2018, 03:18 PM »
Nothing that I've read about yet.  Seems like it's in the hands of the end user for now.  Where is this local source?  I've been keeping an eye out for a friend in the market for a SCMS and haven't seen a price that good yet.
-Raj
Offline jpmeunier
« Reply #62 on: June 25, 2018, 04:02 PM »
Has anyone seen a zero clearance insert available for this saw? If not, I guess I need to make a template.
Offline JYip
« Reply #63 on: June 25, 2018, 04:28 PM »
I bought this saw recently. The table was flat and the fence was square. However, like most others, the bars that the saw head travels along are not parallel. I discovered this when I had a cut mark on a board and was lining the mark up with the laser line. As I pulled the saw head back towards me, I noticed that the laser line would move laterally relative to my pencil mark. The final cut was not square. I decided to just return the saw instead of trying to align the bars.
Hope this helps.
Jeff
« Reply #64 on: June 29, 2018, 07:53 PM »
RKA, Sorry for the late response. The local supplier is Jerry's Home Improvement in Eugene, Oregon. I think the price is good until 8PM pacific time today, but may be worth a call to their tool department @ (541) 689-1911.
Offline RKA
« Reply #65 on: June 29, 2018, 09:55 PM »
Thanks!  Your on the other coast but hopefully someone else can benefit!
-Raj
Offline tewic
« Reply #66 on: April 15, 2019, 06:43 AM »
I just got a LS1019L as well. Seems like Makita still has the same issue with the slide being slightly off, even though the blade is square to the fences, on new unites.
I've tried loosening the screws on part #169 as suggested, but I'm unsure on how I actually adjust the rails. With the screws loose (even tried screwing them all the way off), #169 is still as fixed on the rails, as with the screws tightned. I haven't tried applying more force, as I'm unsure I'm actually doing the right thing.
When the screws are loose, is #169 supposed to be adjusted to an angle, or pulled forward/backwards. Or is it the rails that should be pulled or adjusted to an angle?
Offline RKA
« Reply #67 on: April 15, 2019, 07:35 AM »
@tewic It take a bit of force to realign the rails.  Once the screws are loosened, slip a 1x2 between the rails and use that to twist the rails so to speak.  Which way?  Try one direction with a small adjustment and see if it’s better or worse, then you’ll know.
-Raj
Offline tewic
« Reply #68 on: April 15, 2019, 08:08 AM »
Okay, so the rails need to be twisted/adjusted in relation each other, and not both in relation to #169 or their mount on the back of the stand.
I actually thought it was the blade that was not square to the rails, and thus when you square the blade to the fences, the rails are not square to the fences.
Offline tewic
« Reply #69 on: April 17, 2019, 04:00 AM »
I did as @RKA suggested and it actually worked. After half an hour of trail and error it was almost spot on. Thank you so much!
One thing I noticed. When twisting it one way, if I twisted it slightly too far and wanted to twist it just a tiny bit back again, it was prone to going back to it's out of factory position. I'm curious to see if after some time of use, if it will slowly slip back to the misaligned position, or if the bolts on #169 will keep it in place.
Online Mike Goetzke
« Reply #70 on: July 13, 2019, 10:16 AM »
Thanks guys - worked on my cordless.
Offline gearhound
« Reply #71 on: August 19, 2019, 09:33 PM »
Any updates on Makita fixing this issue yet? Really want to buy one, but not too fond of the thought of tweaking this part #169 when it wasn't meant to be adjustable in the 1st place.....
For those that have made the adjustment tweak, I'm curious how it's holding up over the months/years....does it require frequent adjustment. I'll be using it for furniture builds and don't want to be worrying all the time that it's not square.
Offline Jiggy Joiner
« Reply #72 on: August 20, 2019, 03:42 AM »
Once adjusted and locked up, they hold fine. We bought two of them at the same time a good while back.
Out of the box, one had good rail alignment but, the base angle detents were a little bit out. The other had spot on detents but, the rails needed tweaking.
Both saws have been fine since and I like them a lot, I am a Makita fan though but, have to say, my Kapex is a better saw, by a fair margin (at a price)
I honestly don’t know if Makita have sorted the issues now, a salesman told me they had, he also called me young man, despite me being old enough to be his grandfather  [blink]
I agree too, these saws should not need all these adjustments out of the box. When I‘ve mentioned this at the point of sale, they say it could be a transport issue.
Why not call Makita and ask them, I have called Makita UK on occasion and they’ve always been helpful.
They are nice saws for the money, when set up right, either from the factory, or by user adjustment.
Offline Francis_Beland
« Reply #73 on: September 19, 2019, 01:16 PM »
Anyone want to make a little video (or pictures) on how to realign the bars? I also have the problem and I tried doing it. However, I'm not sure what to do exactly and since I don't want to brake it, I will need to get graphic help to be sure I'm doing the right thing.
Thank you
Offline Maero
« Reply #74 on: February 08, 2020, 05:29 PM »
I just recently got my LS1219L.
Nice saw in every way... almost. The blade was not parallell to the rails, and the sliding cut was doing a curved motion.
I knew about the Wood Whisperer having an issue with this. And he had stated something about other people adjusting the rails. But he ended up returning the saw.
So I really tried to understand how this could be adjusted. I thought to myself that surely Makita can't make such a good saw with this basic fault. Also my saw is a somewhat updated version and manufactured late 2019.
But no. I could only conclude that this is a problem in the casting of the whole gantry. Adjusting the rails in any way could, in my mind, not change this fact.
I also read about others who had received the response from Makita that this can not be fixed without completely replace the saw unit.
I remembered that during my research for this saw I had seen some discussion about "two screws".. Which two screws!?!
Finally I found this thread again.
Voila! A minor tweak with twisting the rails a miniscule amount in relation to one another, drastically moved the blade position.
First I thought this had to change the bevel angle. And yes it probably does in theory. But #1 It's such a small amount, and #2 It's just as likely to also being adjusted in the correct direction.
A big thanks to this thread!
« Last Edit: February 08, 2020, 05:37 PM by Maero »
Offline John1102
« Reply #75 on: February 08, 2020, 08:40 PM »
Can anyone post a picture of which screws on the Makita saw are for the adjustment?  Thanks!
Offline Lbob131
« Reply #76 on: February 09, 2020, 09:17 AM »
It the two allen screws   at the end of  the slide  rails afaik.
Online Mike Goetzke
« Reply #77 on: February 09, 2020, 10:07 AM »
Go here:
https://www.protoolreviews.com/tools/power/cordless/saws-cordless/makita-10-cordless-miter-saw/34117/
See the black knob in center of picture on the top slide rail? To the left is a casting holding the upper/lower bars. See the two black spots on this casting? Those are the allen screw locations.
Offline Maero
« Reply #78 on: February 09, 2020, 04:47 PM »
The thing is that these are not adjustment screws. To me it doesn't even make sense. But it works.
Find something to use as leverage between the two rails. You need to twist them (in relation to each other) in a controlled and gently manner in the outwards end where the two screws are.
Loosen the screws and while tweaking the rails - screw them back in to "lock" the rail alignment.
You can think of the lower rail being pushed in the direction you want the blade to move at the end nearest to you. Maybe in a factor 2:1
I also want to add that the curved cut that my saw made previously also went away.
« Last Edit: February 09, 2020, 04:52 PM by Maero »
« Reply #79 on: April 08, 2020, 03:40 PM »
I'm connecting my 27mm Festool hose on it and I'm not quite satisfied with dust collection. I'm wondering if anyone have this saw and connected the 36mm hose. First does it fit on the saw and second, do you see an improvement like with the Kapex?
Offline jpmeunier
« Reply #80 on: April 08, 2020, 04:06 PM »
I use a 36mm on mine, it isn't perfect, but it does make a bit difference.
Offline Blues
« Reply #81 on: April 08, 2020, 04:16 PM »
I have the exact set up connected to a festool vac. Dust collection is quite decent. Surely not as good as kapex but almost there.  If you notice there are 2 input suction ports that combine to become one. Check if there is any blockage there. Also check if your vac bag is full. Cleaning them could help.  I think makita could have done a better job with their extraction.  Wish i had a 3d printer, could try and re engineer the port and connector.
« Reply #82 on: April 08, 2020, 04:25 PM »
Good Thank you. I was hesitating because I wanted to be sure it fit. That will be useful for my Makita, my TS55 and the cleaning kit. The last thing I must decide: AS or not. :)
Offline Paul Lande
« Reply #83 on: April 09, 2020, 01:51 PM »
New forum member here.  I purchased a new Makita LS1219L from Acme Tools in December and got a nice Makita promotion discount.  I stumbled on this thread today and encountered the same problem with my 12 inch as some of you and the The Word Whisperer.  The blade did not remain square to fence from back to front.  When the blade was all the way back it was square to the fence, when the blade was pulled all the way to the fromt it was not square, so my cut on a wide board would not be square back to front.
At the time I came across this video:
at 4:13 he addresses the problem where the blade is not square to the fence throughout its full travel back to fornt, which I understand to be the problem raised by a number of people in this thread.  In any case it was the problem with my saw and I adjusted the detente plate (miter angle scale) as recommend in the video and on p. 29 of the Makita Instruction Manual for this saw.  This solved my problem: the blade is square to the fence from throughout its full travel back to front.  I also tried this method suggested by glass1 before and after the adjustment
glass1:
"I have found the blade not perfectly parellel to the slides to be a common issue on almost all scms. It’s the first thing I look for. I clamp a wide blade board to the saw. It does not matter the miter angle. With thread pushed all the way back I do,a plunge cut and with the blade still running I lift the blade up and pull it all the way out without cutting. Than I plunge down and mate the cuts. If the do not perfectly line up than the blade is not parellel to the slides. Most saws have no adjustment to fix if the blade is not parellel to the slides. My ls1019l is perfectly parellel. Dust collection is very good. Power is excellent.  Slides are smooth. Detent override. Easy to use safety and one can hold the blade guard up with the thumb. Flat table. It’s a great saw. "
Before I made any changes, the front and back cuts were not in perfect alignment.  After adjusting the detente plate they were.  So in my book:  "problem solved".
So I'm wondering, is the problem of the rails not being aligned with the blade discussed here a different problem than I experienced?
Thanks.
Offline RKA
« Reply #84 on: April 09, 2020, 02:34 PM »
Yes, they are different issues.  If adjusting the miter detent plate fixed your issue, then the blade was in alignment with the guides to begin with.  All you did was adjust the 0 miter point which is the blade’s orientation to the fence.  If it wasn’t in alignment with the rails,  you would have seen problems checking the front and back of the blade across its travel.  No matter what you do, adjusting that miter plate won’t fix it.
To visualize the issue, imagine you set the blade up so it’s exactly 90 degrees to the fence.  It looks perfect and if you lower the blade to make a chop cut, it’s 90 degrees as expected.  Now imagine the rail is skewed 45 degrees relative to the blade.  That’s an extreme example that you would never see.  But as you pulled the blade out using the slides, it’s actually traveling sideways, remaining perpendicular to the fence.  But the front of the blade and back of the blade are traveling in two different paths.  Does that make sense?
-Raj
Offline Paul Lande
« Reply #85 on: April 09, 2020, 04:23 PM »
RKA,
Well I'm not sure we're communicating.  My problem, as I described above, was that the blade moved toward the end of the square (in exactly the same way as shown by The Wood Whisperer) as I moved the blade from back to front along the full travel along the guide rails.  This is also the phenomenon described by others in this thread (toward the end of the square blade, as in TWW, or away from the end of the square blade).
You seem to be saying that my problem is different than that described by The Wood Whisperer and some of those posting in this thread.  How so?  Is it not that when the blade is at the back of the rails (nearest the fence) it is in alignment with the fence, i.e. square to the fence, and when the blade is at the front of the rails it is not?  Do guide rails out of alignment produce a different problem?
If it is the same problem, why not adjust the miter detente plate first to bring the blade into alignment with the square along the full travel of the blade along the guide rails from back to front (or front to back)?
You said:
"If adjusting the miter detent plate fixed your issue, then the blade was in alignment with the guides to begin with.  All you did was adjust the 0 miter point which is the blade’s orientation to the fence."
The miter detente plate is circular, so adjusting it moves it in an arc in relation to the miter table.  What is actually happening is that the miter table is moving (in an arc) relative to the miter detente plate and relative to the fence at the back of the miter table.  We are therefore changing, by a small amount, the angle to the fence that the blade is moving back to front along the guide rails.
 If the blade moves toward (or away from) the end of the blade of the square (as shown by TWW) it is not moving a 90o to the fence.  Adjusting the detente plate changes the angle at which the blade moves away from the fence as moves back to front along the guide rails because the miter detente plate moves in relation to miter table and changes the 0 (zero) angle relative to the fence.
You said:
"Now imagine the rail is skewed 45 degrees relative to the blade.  That’s an extreme example that you would never see.  But as you pulled the blade out using the slides, it’s actually traveling sideways, remaining perpendicular to the fence.  But the front of the blade and back of the blade are traveling in two different paths.  Does that make sense?"
Well, I suppose that could be happening, but I don't think that's what TWW is describing.  If that did happen, then I would agree that the blade and rails are not parallel to each other.  If that were the case I would think that there would be binding and/or burning as the blade moved through the wood much like a table saw blade that is not parallel to miter slot.  As I look at what TWW showed in his video and read the description of others in this thread, I think it is merely that the blade and rails are parallel, but are not square to the fence when the blade reaches its furthermost point as it moves from front to back.
In any case, when I got my saw, I had the same problem TWW showed in his video and adjusting the miter detente plate in the manner shown in the video I linked fixed it.  I wonder if TWW could have fixed his problem the same way.
Online Mike Goetzke
« Reply #86 on: April 09, 2020, 04:38 PM »
RKA,
@Paul Lande
It is a different issue. This is a long thread did you read through all the posts or at least ones helping how to find and correct the issue?
I had the problem on my new Makita and this thread was very helpful to verify I had the issue and told me how to correct it.
Look above and read how to do the wide board cut test - if you pass it yes the wood whisperer video is for you. If not read on further to find out how to correct it.
Mike
Offline jakoblund
« Reply #87 on: June 10, 2020, 09:40 PM »
RKA,
I've tried to draw an explanation to the two scenarios. Hope I've got it right:)
