Author Topic: Mafell tilting base width measurement  (Read 938 times)
Offline morts10n
« on: September 03, 2019, 07:27 PM »
Can somebody tell me the distance from the blade to the shorter side of tilting base? Wondering how close I can get to a wall or other obstruction as it seems the standard base is fairly wide. Thanks
Re: Mafell tilting base width measurement
« Reply #1 on: September 03, 2019, 08:09 PM »
Track saw or jig saw?
Offline Blues
« Reply #2 on: September 03, 2019, 08:57 PM »
Offline Svar
« Reply #3 on: September 03, 2019, 09:01 PM »
Note, although the distance shown above is only 27 mm, the body of the saw is wider.
Offline morts10n
« Reply #4 on: September 03, 2019, 09:11 PM »
Sorry..I meant the jigsaw
« Reply #5 on: September 03, 2019, 09:38 PM »
As Svar noted, the release lever for the jig saw base is on the RH side of the saw, so from the side of the release lever dragging against the wall  [smile]  to the inside edge of the blade it's about 1 3/8" (35 mm).
Offline morts10n
« Reply #6 on: September 03, 2019, 11:22 PM »
Thanks... very helpful. Also I believe it is a reversible base, so is locking lever out of the way when installed the other direction?
« Reply #7 on: September 03, 2019, 11:32 PM »
Ya but that gives you a 3.4” offset.
Offline Svar
« Reply #8 on: September 04, 2019, 05:50 AM »
Yes, but there is another lever on the other side. So, about 35 mm either way.
Offline morts10n
« Reply #9 on: September 04, 2019, 09:58 AM »
Thanks guys...I was hoping for at least 1.5"...boooom!
