P1CC arrived today and just taken it for a spin. Not disappointed at all. Only put it through some 18mm MDF so I don't think I taxed it much
The splinter guards are in no danger of ever falling out like others I've quickly lost on other saws. Once they're in they're not coming out without a fight. The dust connector is similarly tight fitting.
I also noted how accustomed I am to everything wired having a plug-it connection on the tool. That convenience will be restored once the conversion socket arrives.
The W1 blade is "not bad" at all!
I echo the same observations.
Yes the splinter guard goes in very tight. With the w1 blade unless you take out the splinter guard you can't remove the blade. Wish this mechanism was a bit smooth. Have to use brute force to take it off.
Also the dust extractor goes in very tight. Wish it was finer. May be with use it could get better.
After i opened the box i might have used the saw for 15 min and noticed it got warm..kinda hot that i noticed it. Also after 1st use a hex nut fell off. Glad i spotted it. Saved it. Reached out to Timber wolf.
Jeff responded immediately with the schematic and pointed that the hex nut was from the tilting base that secures the parallel fence. He was spot on with the observation. I have since put the nut back in.. but could it fall off again? I don't know. Wondering if I should secure it with a dab of glue.
On the heating part Jeff's response was ah well it's normal. Is a 900W motor and it's a barrel grip so you might feel it more. My point was i used it only for 15 min. Anyways i will continue to use it and if it's very noticeable will reach out again.
Point worth sharing is i did not get the feeling that the heating issue was acknowledged enough. Also i did not get the confidence come through to ease the customer. Rather the unsaid message was don't return the tool for this reason. If it's truly broken we will repair it for you.
Also my MT55 (corded) arrived. Beautiful tool. A lot more refined in build quality than the p1cc in my opinion. Superb cut quality. Ran it on the festool rail on my mft. Cut line is further away from the rubber lip. So no assist from the lip to prevent tear out... but absolutley no tear out.. glass smooth cuts. Sheer joy to work with the tool.
I have the ts75 at 13A that makes wayyy more noise when it cuts. The mt55 @ 13.5A is whisper smooth in comparison. While i can feel the ts75 labor through a cut, mt55 just glides thro and feels as if it is not even cutting. I think it's a combination of a little more power, thin kerf, and a great blade. Lovin it.
P1CC cuts great. Left me wanting a little more refinement. I will be putting it through bigger and longer cuts before i declare if the tool should go back for repair.
For now I'd say timber wolf service is ok. When i read between the lines the message is "you have bought a great tool. And it should work. If it truly is broken we will repair it, but don't return the tool for any reason". And that might throw off a few.
Just sharing my experience. Both Mafell and Timberwolf are great companies and have been around for many years. Im sure if the need arises they would service their customers well. We'll see.
