It does work with Festool rails. There's a black Delrin insert held in with 4 screws that needs to be removed first.
I'm curious if the Mafell can be adjusted relative to the Festool splinter strip and if it can also be adjusted for fit on the Festool rail.
So here's the skinny with photos.
A photo of the sole plate of the MT 55 with the black Delrin insert still installed.
A photo of the sole plate with the Delrin insert removed, this will now ride on the Festool rail. The remaining black Delrin piece in the photo is an adjuster in the neutral position to fine tune the fit for use on a Mafell rail or a Festool rail. It's a rather clever twist.
One edge of the adjuster contacts the Festool rail while the other edge of the adjuster contacts the Mafell rail. Obviously one size doesn't fit all.
![Smile [smile]](https://www.festoolownersgroup.com/Smileys/default/smile.gif)
Here the adjuster is tweaked slightly, potentially applying pressure to both the Festool rail slot on the bottom and to the Mafell rail slot on the top.
And finally, here's the adjustment screws that will position the Mafell saw closer to or further away from the splinter strip. Again, one size doesn't fit all.
In my situation, I'll probably just adjust the MT 55 to fit the Festool splinter strip so it will work with the TSC & the HKC.
I'll then purchase a Mafell rail to use with the P1cc and the MT 55cc and the Mafell will cut the splinter strip as it is won't to do.
As a side note, the track engagement adjusters on the Mafell are really slick. They're detented so that each adjustment is a positive step and you can go forwards or backwards one small step at a time. Pretty slick.
As noted before, this saw really raises the bar on most every item.
The MT 55 blade spins at 6250 rpm vs the TS 55 blade at 5200 rpm.
The MT 55 blade has a kerf of 1.8 mm vs the TS 55 blade of 2.2 mm.
The MT 55 draws 1620 watts vs the TS 55 at 1200 watts.
The only nit I can pick is that the MT 55 does not have a riving knife. I'm thinking however, that the combination of the increased blade speed, decreased kerf thickness and higher amperage draw will negate the advantage of a riving knife as it will continue to soldier on cutting through the wood when the TS 55 has stalled out. We'll see...time will tell.
